Hi folks,
do you supply a BT Test-SW to set a module with your NRF51822 in different test modes like continuous FH etc. or to change the device to low, mid, high channel etc. ?
This is required for EN300328 certification.
BR Thomas
Hi folks,
BR Thomas
In order to test the radio, the easiest example to use is the radio_test example in the SDK.
It can be found in the following folder: ..\nRF51_SDK_8.1.0_b6ed55f\examples\peripheral
From the radio_test example, it should be possible to make the firmware do continuous frequency hopping.
@Thomas: Did the reply from Kristin answer your question? If it does, please mark the answer as correct and we can close the case.
