HOW TO CONVERT SGTL5000 DATA INTO WAV FILE?
Hello Team,
First Thanks to all Nordic support:)
My problem :
I have interfaced SGTL5000 with Nrf52832 (used SDK 16) I'm getting the audio data on aux connector and also getting data in form of integer value ( negative and positive values )
Now I have take a log of this integer values using jlink RTT viewer but I don't know how to convert this values into wav file?
{ I played one song and based on that I take log on RTT viewer  }
2) I also want to transmit this data on ble Nordic uart service and from android I want to convert this data into wav file ( live streaming - some real time delay is acceptable) but I don't how to convert data into wav file?
Thanks!
    This repository may provide some useful tips and links.
    I'm not aware of any specific libraries for converting to WAV format, but as far as I can see, the input from SGTL5000 is PCM format, so any PCM to WAV converters should do the job.
    Jørgen
  • Thanks for the reply!
    Actually, I already used this example in my customize code but I don't know how to convert integer data into a .wav file
    I have spent lots of time behind this but still, I have not got success!
    I have attached the recorded data file please let me know if is it the right file for .wav conversion or not?
    Please help me out with this
    Thanks!
  • If this file format is not right then please let me know how to generate the right file format for .wav file
    I spoke with our developers that made the Python script to convert the WAV file to C in the GitHub repository. They recommend using the built in package "wave" in Python to convert from PCM array to WAV, for instance like this:
    import wave
    # Raw uint8 values
    pcm = [0x01, 0x02, etc.]
    # Assume 1 channel, 16-bits (2 bytes), 16 kHz
    # w = open("my_file.wav", "wb")
    w.setparams((1, 2, 16000, len(pcm)/2, 'NONE', 'not compressed'))
    w.writeframes(bytes(pcm))
    w.close()
    This should likely work with the endianness used by nRF52 without any explicit converting, but if not, you just needs to re-arrange the bytes in the pcm-array:
    pcm = [0x01, 0x02, 0x03, 0x04]
    to:
    pcm = [0x02, 0x01, 0x04, 0x03]
    Jørgen
  • HellO,
    Here is the my I2S setting .
    //@@@@@@   I2S setting  @@@@@@@@@@@@@@@@@@@
    #define AUDIO_FRAME_WORDS 320
    #define I2S_BUFFER_SIZE_WORDS AUDIO_FRAME_WORDS * 2 // Double buffered - I2S lib will switch between using first and second half
    static uint32_t m_i2s_tx_buffer[I2S_BUFFER_SIZE_WORDS];
    static uint32_t m_i2s_rx_buffer[I2S_BUFFER_SIZE_WORDS];
    /* Include car sample to demonstrate that sample can be played from application as well */
    #define SAMPLE_LEN 67200
    extern const uint8_t car_sample[SAMPLE_LEN];
    static uint8_t * p_sample = (uint8_t *)car_sample;
    static uint32_t sample_idx = 0;
    int16_t data_audio[(AUDIO_FRAME_WORDS/2)];
    //@@@@@@@@@@@@@@ i2c event handler @@@@@@@@@@@@@@@@@
    static bool i2s_sgtl5000_driver_evt_handler(drv_sgtl5000_evt_t * p_evt)
    bool ret = false;
    //NRF_LOG_INFO("i2s_sgtl5000_driver_evt_handler %d", p_evt->evt);
    //NRF_LOG_INFO("%d",p_evt->param.rx_buf_received.p_data_received);
    switch (p_evt->evt)
    case DRV_SGTL5000_EVT_I2S_RX_BUF_RECEIVED:
    uint16_t * p_buffer = (uint16_t *) p_evt->param.rx_buf_received.p_data_received;
    i2s_buffer_size_words = p_evt->param.rx_buf_received.number_of_words;
    int16_t pcm_stream[i2s_buffer_size_words]; // int16_t - i2s_buffer_size_words size; means we only cover half of data_to_send_buffer, which is fine since we are only using LEFT channel
    memcpy(data_audio, p_buffer, i2s_buffer_size_words);
    ret = true;
    case DRV_SGTL5000_EVT_I2S_TX_BUF_REQ:
    //NRF_LOG_INFO("i2s_sgtl5000_driver_evt_handler TX BUF REQ");
    /* Play sample! 16kHz sample played on 32kHz frequency! If frequency is changed, this approach needs to change. */
    /* Playback of this 16kHz sample depends on I2S MCK, RATIO, Alignment, format, and channels! Needs to be DIV8, RATIO 128X, alignment LEFT, format I2S, channels LEFT. */
    uint16_t * p_buffer = (uint16_t *) p_evt->param.tx_buf_req.p_data_to_send;
    uint32_t i2s_buffer_size_words = p_evt->param.rx_buf_received.number_of_words;
    /* Clear pcm buffer */
    memset(pcm_stream, 0, sizeof(pcm_stream));
    /* Check if playing the next part of the sample will exceed the sample size, if not, copy over part of sample to be played */
    if (sample_idx < SAMPLE_LEN)
    /* Copy sample bytes into pcm_stream (or remaining part of sample). This should fill up half the actual I2S transmit buffer. */
    /* We only want half becuase the sample is a 16kHz sample, and we are running the SGTL500 at 32kHz; see DRV_SGTL5000_FS_31250HZ */
    uint32_t bytes_to_copy = ((sample_idx + sizeof(pcm_stream)) < SAMPLE_LEN) ? sizeof(pcm_stream) : SAMPLE_LEN - sample_idx - 1;
    memcpy(pcm_stream, &p_sample[sample_idx], bytes_to_copy);
    sample_idx += bytes_to_copy;
    ret = true;
    /* End of buffer reached. */
    sample_idx = 0;
    ret = false;
    /* Upsample the decompressed audio */
    /* i < i2s_buffer_size_words * 2 because we have a uint16_t buffer pointer */
    for (int i = 0, pcm_stream_idx = 0; i < i2s_buffer_size_words * 2; i += 2)
    for (int j = i; j < (i + 2); ++j)
    p_buffer[j] = pcm_stream[pcm_stream_idx];
    ++pcm_stream_idx;
    return ret;
    //@@@@@@@@@@@@@@ Here I am logging the my audio data @@@@@@@@@@@
    // Enter main loop.
    for (;;)
    idle_state_handle();
    for(int i = 0; i < (AUDIO_FRAME_WORDS / 2) ; i++)
    NRF_LOG_RAW_INFO("%d\n,",data_audio[i]);
    NRF_LOG_FLUSH();
    }//FOR LOOP CLOSED BRACKET
    }//MAIN LOOP CLOSED BRACKET
    Please let me know the right settings for getting audio data.
