force enter the dfu with command
is there any command to forcethe app to enter the dfu mode
i do know the dfu buttonless but this time i want it to use it on uart dfu
    Yes, you can force it to enter DFU mode by writing the BOOTLOADER_DFU_START flag to GPREGRET0 followed by a system reset similiar to how it's done in the ble buttonless template example.
    Example
    void enter_dfu_mode (void)
        uint32_t err_code = sd_power_gpregret_clr(0, 0xffffffff);
        err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
        NVIC_SystemReset();
  • I know this but my question is using a command to force enter dfu mode
    and i found a way to do this
    but this is a one way force in the dfu mode
    basically i just erase the setting.hex section to make the board caanot enter the app mode
    this is a way to force enter the dfu mode although it is a one way method
    use in urgent time
    @ECHO ON
     nrfjprog --family nrf52 --erasepage 0xFE000-0xFF001
    @ECHO ON
     nrfjprog --family nrf52 --memrd 0xFF000
    @ECHO ON
     nrfjprog --family nrf52 --memwr 0xFF000 --val 1
    @ECHO ON
    nrfjprog -f nrf52 --reset
    @ECHO ON
  • Yes, erasing the settings page is one way to do it. I did not know you had a debugger connected. I assumed you wanted to enter DFU mode after receiving a specific command over UART.
