Issues NCS(1.3.2) and Nordic BLE LL implementation
Hi Nordic team,
I'm having a custom board and custom application made for that board. Application is based on the zephyr v2.3.0.
I decided to move to the NCS because i want to try out your Nordic BLE LL controller instead of zephyr BLE controller.
Since the NCS version v1.3.2 uses the same zephyr v2.3.0 underhood i was able to run my application without any problems, but only if i use zephyr BLE LL (CONFIG_BT_LL_SW_SPLIT=y) config.
When configured my application to use Nordic BLE Link Layer implementation (CONFIG_BT_LL_NRFXLIB=y) my device didn't want to bootup at all.
After debugging the issue i have found that the device asserts on some condition inside the hci_core.c file:
[00:00:01.675,140] <inf> bt_ctlr_hci_driver: BLE controller build revision:
6b 05 51 03 45 62 05 0e  65 d1 a0 45 8d a7 b6 24 |k.Q.Eb.. e..E...$
3a 17 ea 5c                                      |:..\
ASSERTION FAIL [!bt_hci_evt_is_prio(hdr->evt)] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:5238
[00:00:01.675,872] <err> os: r0/a1:  0x00000003  r1/a2:  0x2002bf50  r2/a3:  0x00000000
[00:00:01.675,903] <err> os: r3/a4:  0x20030cf4 r12/ip:  0xaaaaaaaa r14/lr:  0x0005f763
[00:00:01.675,903] <err> os:  xpsr:  0x61000000
[00:00:01.675,933] <err> os: Faulting instruction address (r15/pc): 0x0005f76e
[00:00:01.675,933] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:01.675,964] <err> os: Current thread: 0x20019140 (BT RX)
The event code that it asserts on is the 0x0e. Looking in the hci.h file the 0x0e is the BT_HCI_EVT_CMD_COMPLETE code.
My questions would be:
  1. Am i missing some of the configuration options for the BLE in order to utilize your Nordic BLE Link Layer implementation?
  2. Or using Nordic BLE Link Layer is still not supported with the NCS(1.3.2) version i'm using?
My environment:
  • NCS version: v1.3.2
  • Hardware used:
    •  Custom board with nrf52840 chipset
  • BLE stack configuration
    • CONFIG_BT_LL_NRFXLIB=y
    • CONFIG_BT_LL_NRFXLIB_DEFAULT=y
    • CONFIG_BT_LL_NRFXLIB_VS_INCLUDE=y
Thank you in advance!
