TWI / I2c device unable to read / write the device ? irrespective of following reference manual.
Here are my functions which i wrote for reading / writing the i2c slave device ( after reading reference manual (nrf51422) . Unfortunately they are not working. Plz help me with the code.
void twi_init_slz(void )
	(*(unsigned volatile int *)0x040003500)= 0x00;               //Disable SPI AND TWI
	//(*(unsigned volatile int *)0x040003200)= 0x00; 							//SHORTCUT REGISTER
	(*(unsigned volatile int *)0x040003508)= 30U;								 //PSELSCL
	(*(unsigned volatile int *)0x04000350C)= 7U;									//PSELSDA
	(*(unsigned volatile int *)0x050000518)= ~((1UL<<30)|(1UL<<7));
	(*(unsigned volatile int *)0x050000778)= (6UL<<8)|(3UL<<2);		//set pin
	(*(unsigned volatile int *)0x05000071C)= (6UL<<8)|(3UL<<2);		//set pin
	//(*(unsigned volatile int *)0x040003300)= (1UL<<2)|(1UL<<7)|(1UL<<7)|(1UL<<9)|(1UL<<14);	//INTEN
	(*(unsigned volatile int *)0x040003304)= (1UL<<2)|(1UL<<7)|(1UL<<7)|(1UL<<9)|(1UL<<14);	//INTENSET
	(*(unsigned volatile int *)0x040003524)= 0x01980000;				//FREQUENCY
	(*(unsigned volatile int *)0x040003124)= 1UL;				//ERROR
	(*(unsigned volatile int *)0x040003500)= 0x05;     //ENABLE TWI
void set_address_twi_slz(int address)
	(*(unsigned volatile int *)0x040003588)= address;				//I2C ADDRESS
int read_twi_slz(void)
	nrf_delay_ms(10);
	printf("In read\n");
	//(*(unsigned volatile int *)0x40003588)|= 1UL;
	(*(unsigned volatile int *)0x40003000)= 1;						//STARTRX
	nrf_delay_ms(10); while(!((*(unsigned volatile int *)0x40003108))); //wait for RXREADY EVENT
	nrf_delay_ms(10);
	int read_i2c_value = (*(unsigned volatile int *)0x40003518); //copying RX Register
	nrf_delay_ms(10);
	(*(unsigned volatile int *)0x40003014)= 1;		 //Stop
	return read_i2c_value;
bool write_twi_slz(int data)
	(*(unsigned volatile int *)0x40003008)=1;
	(*(unsigned volatile int *)0x4000351C)=data;
	int check =(*(unsigned volatile int *)0x04000351C);
	if(check)
			return 1; // successfully sent
			return 0; //Sent error
