trying to read input pwm signal (pulse width and period) using nRF9160 PWM.h driver
Hello All,
I am trying to figure out how to use the PWM.h driver for the nRF9160 to read an input pwm signals pulse width and period (im currently working with the nRF9160 DK using the SDK version 1.5.0) but I can't find any examples to start from (are there any sample projects that demonstrate this that would be a good starting place?) and as I'm still a little green when it comes to embedded work I'm sure what've I've tried so far on my own is wrong.
The driver I'm referencing can be found:
          - in the ncs directory here → ncs\v1.5.0\zephyr\include\drivers\pwm.h
          - inserted as code below
          - attached at the bottom of this post as a pwm.h
note: I have (CONFIG_PWM_CAPTURE=y) set in my prj.conf file
I'm looking for guidance on how to set up the pwm handler (*pwm_capture_callback_handler_t in the driver) as well as whether I need to set up the configure capture and enable capture api's (*pwm_pin_configure_capture_t and *pwm_pin_enable_capture_t in the driver) in my main.c or if upon setting up the pwm handler am i able to just call the pwm_pin_configure_capture() and  pwm_pin_enable_capture() methods in my main.c to get my board set up to read in a pwm signal.
         Side questions:
                 - what is the difference between the function labels pwm_pin_enable_capture() and z_impl_pwm_pin_enable_capture() in the driver? Which should I be using?
                 - is the *user_data variable in the pwm handler unused (ie should I call ARG_UNUSED(user_data) when defining my pwm handler)
Any help or suggestions is greatly appreciated!
 * Copyright (c) 2016 Intel Corporation.
 * Copyright (c) 2020-2021 Vestas Wind Systems A/S
 * @file
 * @brief Public PWM Driver APIs
#ifndef ZEPHYR_INCLUDE_DRIVERS_PWM_H_
#define ZEPHYR_INCLUDE_DRIVERS_PWM_H_
 * @brief PWM Interface
 * @defgroup pwm_interface PWM Interface
 * @ingroup io_interfaces
#include <errno.h>
#include <zephyr/types.h>
#include <stddef.h>
#include <sys/math_extras.h>
#include <device.h>
#include <dt-bindings/pwm/pwm.h>
#ifdef __cplusplus
extern "C" {
 * @name PWM capture configuration flags
/** @cond INTERNAL_HIDDEN */
/* Bit 0 is used for PWM_POLARITY_NORMAL/PWM_POLARITY_INVERTED */
#define PWM_CAPTURE_TYPE_SHIFT		1U
#define PWM_CAPTURE_TYPE_MASK		(3U << PWM_CAPTURE_TYPE_SHIFT)
#define PWM_CAPTURE_MODE_SHIFT		3U
#define PWM_CAPTURE_MODE_MASK		(1U << PWM_CAPTURE_MODE_SHIFT)
/** @endcond */
/** PWM pin capture captures period. */
#define PWM_CAPTURE_TYPE_PERIOD		(1U << PWM_CAPTURE_TYPE_SHIFT)
/** PWM pin capture captures pulse width. */
#define PWM_CAPTURE_TYPE_PULSE		(2U << PWM_CAPTURE_TYPE_SHIFT)
/** PWM pin capture captures both period and pulse width. */
#define PWM_CAPTURE_TYPE_BOTH		(PWM_CAPTURE_TYPE_PERIOD | \
					 PWM_CAPTURE_TYPE_PULSE)
/** PWM pin capture captures a single period/pulse width. */
#define PWM_CAPTURE_MODE_SINGLE		(0U << PWM_CAPTURE_MODE_SHIFT)
/** PWM pin capture captures period/pulse width continuously. */
#define PWM_CAPTURE_MODE_CONTINUOUS	(1U << PWM_CAPTURE_MODE_SHIFT)
 * @brief Provides a type to hold PWM configuration flags.
typedef uint8_t pwm_flags_t;
 * @typedef pwm_pin_set_t
 * @brief Callback API upon setting the pin
 * See @a pwm_pin_set_cycles() for argument description
typedef int (*pwm_pin_set_t)(const struct device *dev, uint32_t pwm,
			     uint32_t period_cycles, uint32_t pulse_cycles,
			     pwm_flags_t flags);
 * @typedef pwm_capture_callback_handler_t
 * @brief PWM capture callback handler function signature
 * @note The callback handler will be called in interrupt context.
 * @note @option{CONFIG_PWM_CAPTURE} must be selected to enable PWM capture
 * support.
 * @param dev Pointer to the device structure for the driver instance.
 * @param pwm PWM pin.
 * @param period_cycles Captured PWM period width (in clock cycles). HW
 *                      specific.
 * @param pulse_cycles Captured PWM pulse width (in clock cycles). HW specific.
 * @param status Status for the PWM capture (0 if no error, negative errno
 *               otherwise. See @a pwm_pin_capture_cycles() return value
 *               descriptions for details).
 * @param user_data User data passed to @a pwm_pin_configure_capture()
typedef void (*pwm_capture_callback_handler_t)(const struct device *dev,
					       uint32_t pwm,
					       int status,
					       void *user_data);
 * @typedef pwm_pin_configure_capture_t
 * @brief Callback API upon configuring PWM pin capture
 * See @a pwm_pin_configure_capture() for argument description
typedef int (*pwm_pin_configure_capture_t)(const struct device *dev,
					   uint32_t pwm,
					   pwm_flags_t flags,
					   pwm_capture_callback_handler_t cb,
					   void *user_data);
 * @typedef pwm_pin_enable_capture_t
 * @brief Callback API upon enabling PWM pin capture
 * See @a pwm_pin_enable_capture() for argument description
typedef int (*pwm_pin_enable_capture_t)(const struct device *dev,
					uint32_t pwm);
 * @typedef pwm_pin_disable_capture_t
 * @brief Callback API upon disabling PWM pin capture
 * See @a pwm_pin_disable_capture() for argument description
typedef int (*pwm_pin_disable_capture_t)(const struct device *dev,
					 uint32_t pwm);
 * @typedef pwm_get_cycles_per_sec_t
 * @brief Callback API upon getting cycles per second
 * See @a pwm_get_cycles_per_sec() for argument description
typedef int (*pwm_get_cycles_per_sec_t)(const struct device *dev,
					uint32_t pwm,
					uint64_t *cycles);
/** @brief PWM driver API definition. */
__subsystem struct pwm_driver_api {
	pwm_pin_set_t pin_set;
#ifdef CONFIG_PWM_CAPTURE
	pwm_pin_configure_capture_t pin_configure_capture;
	pwm_pin_enable_capture_t pin_enable_capture;
	pwm_pin_disable_capture_t pin_disable_capture;
#endif /* CONFIG_PWM_CAPTURE */
	pwm_get_cycles_per_sec_t get_cycles_per_sec;
 * @brief Set the period and pulse width for a single PWM output.
 * Passing 0 as @p pulse will cause the pin to be driven to a constant
 * inactive level.
 * Passing a non-zero @p pulse equal to @p period will cause the pin
 * to be driven to a constant active level.
 * @param period Period (in clock cycle) set to the PWM. HW specific.
 * @param pulse Pulse width (in clock cycle) set to the PWM. HW specific.
 * @param flags Flags for pin configuration (polarity).
 * @retval 0 If successful.
 * @retval Negative errno code if failure.
__syscall int pwm_pin_set_cycles(const struct device *dev, uint32_t pwm,
				 uint32_t period, uint32_t pulse, pwm_flags_t flags);
static inline int z_impl_pwm_pin_set_cycles(const struct device *dev,
					    uint32_t pwm,
					    pwm_flags_t flags)
	struct pwm_driver_api *api;
	api = (struct pwm_driver_api *)dev->api;
	return api->pin_set(dev, pwm, period, pulse, flags);
 * @brief Configure PWM period/pulse width capture for a single PWM input.
 * After configuring PWM capture using this function, the capture can be
 * enabled/disabled using @a pwm_pin_enable_capture() and @a
 * pwm_pin_disable_capture().
 * @note This API function cannot be invoked from user space due to the use of a
 * function callback. In user space, one of the simpler API functions (@a
 * pwm_pin_capture_cycles(), @a pwm_pin_capture_usec(), or @a
 * pwm_pin_capture_nsec()) can be used instead.
 * @note @option{CONFIG_PWM_CAPTURE} must be selected for this function to be
 * available.
 * @param flags PWM capture flags
 * @param cb Application callback handler function to be called upon capture
 * @param user_data User data to pass to the application callback handler
 *                  function
 * @retval -EINVAL if invalid function parameters were given
 * @retval -ENOTSUP if PWM capture is not supported or the given flags are not
 *                  supported
 * @retval -EIO if IO error occurred while configuring
 * @retval -EBUSY if PWM capture is already in progress
static inline int pwm_pin_configure_capture(const struct device *dev,
					    uint32_t pwm,
					    pwm_flags_t flags,
					    void *user_data)
	const struct pwm_driver_api *api = (struct pwm_driver_api *)dev->api;
	if (!api->pin_configure_capture) {
		return -ENOTSUP;
	return api->pin_configure_capture(dev, pwm, flags, cb, user_data);
 * @brief Enable PWM period/pulse width capture for a single PWM input.
 * The PWM pin must be configured using @a pwm_pin_configure_capture() prior to
 * calling this function.
 * available.
 * @retval -EIO if IO error occurred while enabling PWM capture
__syscall int pwm_pin_enable_capture(const struct device *dev, uint32_t pwm);
static inline int z_impl_pwm_pin_enable_capture(const struct device *dev,
						uint32_t pwm)
	if (!api->pin_enable_capture) {
		return -ENOTSUP;
	return api->pin_enable_capture(dev, pwm);
 * @brief Disable PWM period/pulse width capture for a single PWM input.
 * available.
 * @retval -EIO if IO error occurred while disabling PWM capture
__syscall int pwm_pin_disable_capture(const struct device *dev, uint32_t pwm);
static inline int z_impl_pwm_pin_disable_capture(const struct device *dev,
						 uint32_t pwm)
	if (!api->pin_disable_capture) {
		return -ENOTSUP;
	return api->pin_disable_capture(dev, pwm);
 * @brief Capture a single PWM period/pulse width in clock cycles for a single
 *        PWM input.
 * This API function wraps calls to @a pwm_pin_configure_capture(), @a
 * pwm_pin_enable_capture(), and @a pwm_pin_disable_capture() and passes the
 * capture result to the caller. The function is blocking until either the PWM
 * capture is completed or a timeout occurs.
 * available.
 * @param flags PWM capture flags.
 * @param period Pointer to the memory to store the captured PWM period width
 *               (in clock cycles). HW specific.
 * @param pulse Pointer to the memory to store the captured PWM pulse width (in
 *              clock cycles). HW specific.
 * @param timeout Waiting period for the capture to complete.
 * @retval -EBUSY PWM capture already in progress.
 * @retval -EAGAIN Waiting period timed out.
 * @retval -EIO IO error while capturing.
 * @retval -ERANGE If result is too large.
__syscall int pwm_pin_capture_cycles(const struct device *dev, uint32_t pwm,
				     pwm_flags_t flags,
				     uint32_t *period,
				     uint32_t *pulse,
				     k_timeout_t timeout);
 * @brief Get the clock rate (cycles per second) for a single PWM output.
 * @param cycles Pointer to the memory to store clock rate (cycles per sec).
 *		 HW specific.
__syscall int pwm_get_cycles_per_sec(const struct device *dev, uint32_t pwm,
				     uint64_t *cycles);
static inline int z_impl_pwm_get_cycles_per_sec(const struct device *dev,
						uint32_t pwm,
						uint64_t *cycles)
	return api->get_cycles_per_sec(dev, pwm, cycles);
 * @param period Period (in microseconds) set to the PWM.
 * @param pulse Pulse width (in microseconds) set to the PWM.
static inline int pwm_pin_set_usec(const struct device *dev, uint32_t pwm,
				   pwm_flags_t flags)
	uint64_t period_cycles, pulse_cycles, cycles_per_sec;
	if (pwm_get_cycles_per_sec(dev, pwm, &cycles_per_sec) != 0) {
		return -EIO;
	period_cycles = (period * cycles_per_sec) / USEC_PER_SEC;
	if (period_cycles >= ((uint64_t)1 << 32)) {
		return -ENOTSUP;
	pulse_cycles = (pulse * cycles_per_sec) / USEC_PER_SEC;
	if (pulse_cycles >= ((uint64_t)1 << 32)) {
		return -ENOTSUP;
	return pwm_pin_set_cycles(dev, pwm, (uint32_t)period_cycles,
				  (uint32_t)pulse_cycles, flags);
 * @param period Period (in nanoseconds) set to the PWM.
 * @param pulse Pulse width (in nanoseconds) set to the PWM.
static inline int pwm_pin_set_nsec(const struct device *dev, uint32_t pwm,
				   pwm_flags_t flags)
		return -EIO;
	period_cycles = (period * cycles_per_sec) / NSEC_PER_SEC;
		return -ENOTSUP;
	pulse_cycles = (pulse * cycles_per_sec) / NSEC_PER_SEC;
		return -ENOTSUP;
 * @brief Convert from PWM cycles to microseconds.
 * @param cycles Cycles to be converted.
 * @param usec Pointer to the memory to store calculated usec.
 * @retval -EIO If cycles per second cannot be determined.
static inline int pwm_pin_cycles_to_usec(const struct device *dev, uint32_t pwm,
					 uint32_t cycles, uint64_t *usec)
	uint64_t cycles_per_sec;
	uint64_t temp;
		return -EIO;
	if (u64_mul_overflow(cycles, (uint64_t)USEC_PER_SEC, &temp)) {
		return -ERANGE;
	*usec = temp / cycles_per_sec;
	return 0;
 * @brief Convert from PWM cycles to nanoseconds.
 * @param nsec Pointer to the memory to store the calculated nsec.
static inline int pwm_pin_cycles_to_nsec(const struct device *dev, uint32_t pwm,
					 uint32_t cycles, uint64_t *nsec)
	uint64_t temp;
		return -EIO;
	if (u64_mul_overflow(cycles, (uint64_t)NSEC_PER_SEC, &temp)) {
		return -ERANGE;
	*nsec = temp / cycles_per_sec;
	return 0;
 * @brief Capture a single PWM period/pulse width in microseconds for a single
 *        PWM input.
 * This API function wraps calls to @a pwm_pin_capture_cycles() and @a
 * pwm_pin_cycles_to_usec() and passes the capture result to the caller. The
 * function is blocking until either the PWM capture is completed or a timeout
 * occurs.
 * available.
 *               (in usec).
 *              usec).
static inline int pwm_pin_capture_usec(const struct device *dev, uint32_t pwm,
				       pwm_flags_t flags,
				       uint64_t *period,
				       uint64_t *pulse,
	uint32_t period_cycles;
	uint32_t pulse_cycles;
	int err;
	err = pwm_pin_capture_cycles(dev, pwm, flags, &period_cycles,
				     &pulse_cycles, timeout);
	if (err) {
		return err;
	err = pwm_pin_cycles_to_usec(dev, pwm, period_cycles, period);
	if (err) {
		return err;
	err = pwm_pin_cycles_to_usec(dev, pwm, pulse_cycles, pulse);
	if (err) {
		return err;
	return 0;
 * @brief Capture a single PWM period/pulse width in nanoseconds for a single
 *        PWM input.
 * pwm_pin_cycles_to_nsec() and passes the capture result to the caller. The
 * occurs.
 * available.
 *               (in nsec).
 *              nsec).
static inline int pwm_pin_capture_nsec(const struct device *dev, uint32_t pwm,
				       pwm_flags_t flags,
				       uint64_t *period,
				       uint64_t *pulse,
	int err;
	if (err) {
		return err;
	err = pwm_pin_cycles_to_nsec(dev, pwm, period_cycles, period);
	if (err) {
		return err;
	err = pwm_pin_cycles_to_nsec(dev, pwm, pulse_cycles, pulse);
	if (err) {
		return err;
	return 0;
#ifdef __cplusplus
#include <syscalls/pwm.h>
#endif /* ZEPHYR_INCLUDE_DRIVERS_PWM_H_ */
pwm.h
