Attempted to compile SDK 17 with the c ++ compiler
Hi everyone, I have some problem with SDK 17, when I try compile it by C++ compiler.  Compiler detected many errors, for example:
  • nrf_fprintf,c problem with va_lista
va_list should never be initialized. It's standard in C and C++ that it is just left uninitialized until va_start() is called
  • ble_lbs.c (and many services example)
Problem wit missing assignament to variable VERIFY_SUCCESS(error_code);
  • nrf_atflags.h
Missing on top
#ifdef __cplusplus
extern "C" {
  • nrf_sdh.h, nrf_sdh_soc.h, nrf_sdh_ble.h
Problem with construction for example:
typedef struct
} const nrf_sdh_req_observer_t
I m not sure that construction with const is acceptable, please give me reason for using such a structure.
According to: https://en.cppreference.com/w/cpp/language/typedef
“The typedef specifier cannot be combined with any other specifier except for type-specifiers.”
  • Many files for example gatt_cache_manager.c
Problem with order inicjalization.
pm_evt_t event =
                .evt_id      = PM_EVT_SERVICE_CHANGED_IND_CONFIRMED,
                .peer_id     = im_peer_id_get_by_conn_handle(conn_handle),
                .conn_handle = conn_handle,
error: designator order for field ‘pm_evt_t::conn_handle’ does not match declaration order in ‘pm_evt_t’
According to: https://en.cppreference.com/w/cpp/language/aggregate_initialization
“The syntax forms (3,4) are known as designated initializers: each designator must name a direct non-static data member of T, and all designators used in the expression must appear in the same order as the data members of T.”
  • There are plenty of previous posts on this
    Nordic do not claim that the SDK is C++
    You can compile the SDK as C, and link to C++ code ...
  • Hi
    I think it some misunderstand in general.
    point some constructions what are at least doubt (but be honest possibly bug or for sure bug) not only related to C++ but also C.
    1. initialize instance of va_list by 0?? it is not related to C++
    2. macro VERIFY_SUCCESS return value in context of function void??
    3. I know it is not stack-overflow when we may ask general programming question but could you refer to key word "const" in construct quoted below? is it valid according any C standard?
    In my opinion it us quite odd/uncommon so if you point me paragraph in Ansi C standard what allow on it, I will appreciate. If not why nordic use such construct?
    typedef struct
    I think we may refactor this topic into kind of source code quality if you prefer in order to address some issue into nordic source code.
    Best Regards
    /Greg
