I'm trying to get LittleFS up and running while also using Openthread. I've encountered an issue regarding the SETTINGS subsystem that is enabled by Openthread. I've tried opening a private ticket regarding this but it does not seem to get answer so I try with a public one.
First I built the littleFS sample in the zephyr tree and flashed a nrf52840dk which worked as expected.
When I add openthread to the sample using
CONFIG_NET_L2_OPENTHREAD=y CONFIG_NETWORKING=y
The build fails stating
In file included from ../../../../../include/storage/flash_map.h:244,
from C:/ncs/v1.4.0/zephyr/subsys/storage/flash_map/flash_map_default.c:11:
C:/ncs/v1.4.0/nrf/include/flash_map_pm.h:29:2: error: #error "Not supported"
29 | #error "Not supported"
Which seesm to be due to NVS and LittleFS not being able to be enabled at the same time.
I tried to work around this using
CONFIG_SETTINGS_FS=y
And it makes the project build successfully.
However, when I flash the device I get the following error:
*** Booting Zephyr OS build v2.4.0-ncs1 ***
[00:00:00.394,561] <inf> mcuboot: Starting bootloader
[00:00:00.401,031] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
[00:00:00.411,437] <inf> mcuboot: Boot source: none
[00:00:00.417,205] <inf> mcuboot: Swap type: none
[00:00:00.481,262] <inf> mcuboot: Bootloader chainload address offset: 0xc000
[00:00:00.489,257] <inf> mcuboot: Jumping to the first image slot
Area 6 at 0xf4000 on NRF_FLASH_DRV_NAME for 24576 bytes
/lfs mount: 0
/lfs: bsize = 16 ; frsize = 4096 ; blocks = 6 ; bfree = 4
/lfs/boot_count stat: -2
/lfs/boot_count read count 0: 0
/lfs/boot_count seek start: 0
/lfs/boot_count write new boot count 1: 4
/lfs/boot_count close: 0
/lfs opendir: 0
F 4 boot_count
End of files
/lfs unmount: 0
[00:00:00.621,673] <err> fs: fs_open:mount point not found!!
[00:00:00.623,016] <err> fs: fs_open:mount point not found!!
[00:00:00.626,861] <err> fs: fs_open:mount point not found!!
[00:00:00.632,232] <err> fs: fs_open:mount point not found!!
[00:00:00.636,505] <err> fs: fs_open:mount point not found!!
[00:00:00.637,420] <inf> littlefs: LittleFS version 2.2, disk version 2.0
[00:00:00.637,634] <inf> littlefs: FS at NRF_FLASH_DRV_NAME:0xf4000 is 6 0x1000-byte blocks with 512 cycle
[00:00:00.637,634] <inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32
[00:00:00.637,756] <err> littlefs: WEST_TOPDIR/modules/fs/littlefs/lfs.c:997: Corrupted dir pair at {0x0, 0x1}
[00:00:00.637,756] <wrn> littlefs: can't mount (LFS -84); formatting
[00:00:00.809,265] <inf> littlefs: /lfs mounted
[00:00:00.809,326] <err> fs: fs_open:mount point not found!!
[00:00:00.812,622] <err> fs: fs_open:mount point not found!!
[00:00:00.817,810] <err> fs: failed get file or dir stat (-2)
[00:00:00.837,738] <inf> littlefs: /lfs unmounted
[00:00:01.181,518] <err> fs: fs_open:mount point not found!!
My prj,conf is the following:
# # Copyright (c) 2019 Peter Bigot Consulting, LLC # # SPDX-License-Identifier: Apache-2.0 # # Optionally force the file system to be recreated #CONFIG_APP_WIPE_STORAGE=y # fs_dirent structures are big. CONFIG_MAIN_STACK_SIZE=2048 # Let __ASSERT do its job CONFIG_DEBUG=y CONFIG_LOG=y CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_LITTLEFS=y CONFIG_SETTINGS_FS=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NET_L2_OPENTHREAD=y CONFIG_NETWORKING=y
I am running on a nrf52840dk and using NCS1.4.
What do I have to do to get Openthread and LittleFS to run without any errors?
