Unable to Decrypt the Friendship Packets between Low Power Node and Friend Node
I am able to sniff  and decrypt all the packets in Mesh Network as per NRF_Sniff Procedure Manual.
But unable to decrypt the packets received between the Low Power Node and Friend Node. As I have gone through Mesh Profile Specification, it is mentioned the security credentials are different for Friendship PDU and Network PDU.
So, what are the necessary changes should i have make to decrypt those packets also.
Devices used for Sniffing are:
nRF52832 DK
nRF52840 DK
nRF52840 Dongle
with given sniffer hex files.
Tool used: Wireshark (as per specfied in nRF_sniffing Procedure Manual)
Thanks in Advance
K Chandu
  • Hi Chandu,
    We haven't tried to use the nRF Sniffer to decrypt friendship communication (we usually just use the logs on both sides for debugging, instead of sniffing the communication).
    But I would suggest you to have a look at section 3.6.6.2 Friendship security in Mesh Profile specification v1.0.1 for more information about encryption in friendship communication.
  • Thanks Hung,
    I have gone through the specification, the security credentials  are different for both Mesh Network and Friendship Network.
    The master security material is derived from the master security credentials using:
    NID || EncryptionKey || PrivacyKey = k2(NetKey, 0x00)
    The friendship security material is derived from the friendship security credentials using:
    NID || EncryptionKey || PrivacyKey = k2(NetKey, 0x01 || LPNAddress || FriendAddress ||
    LPNCounter || FriendCounter)
    Referred from section 3.8.6.3.1
    Can u suggest any fields to be updated in Wireshark, to decrypt the data.
