[EDITED after more investigation]
I am using workflow 4, where I have my own application's manifest "west.yml" (See https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.5.0/nrf/dm_adding_code.html#workflow-4-application-as-the-manifest-repository)
The file structure is like this:
application
├── bootloader
│ └── mcuboot
├── manifest
│ └── west.yaml -> my own west.yml, which imports nrf-sdk and where 'mcuboot' is defined as a project, too
├── nrf
│ └── west.yaml -> ncs's west.yml, which is being "imported" (which also contains the 'mcuboot' project)
When overriding the "mcuboot" project inside my own west.yaml, I cannot seem to properly build a multi-image hex including MCUboot anymore.
Simple test project, on ncs v1.5.0:
west build -b nrf52840dk_nrf52840 zephyr/samples/hello_world -- -DCONFIG_BOOTLOADER_MCUBOOT=y
This results in:
CMake Error at /home/vinz/Work/git/snt_zephyr/nrf/modules/mcuboot/CMakeLists.txt:112 (add_child_image):
Unknown CMake command "add_child_image".
Full terminal output:
-- west build: generating a build system Including boilerplate (Zephyr base): /home/vinz/Work/git/snt_zephyr/zephyr/cmake/app/boilerplate.cmake -- Application: /home/vinz/Work/git/snt_zephyr/zephyr/samples/hello_world -- Zephyr version: 2.4.99 (/home/vinz/Work/git/snt_zephyr/zephyr) -- Found Python3: /usr/bin/python3.9 (found suitable exact version "3.9.2") found components: Interpreter -- Found west (found suitable version "0.10.1", minimum required is "0.7.1") -- Board: nrf52840dk_nrf52840 -- Cache files will be written to: /home/vinz/.cache/zephyr -- Found dtc: /usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (/home/vinz/gnuarmemb/gcc-arm-none-eabi-10-2020-q4-major) -- Found BOARD.dts: /home/vinz/Work/git/snt_zephyr/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts -- Generated zephyr.dts: /home/vinz/Work/git/snt_zephyr/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /home/vinz/Work/git/snt_zephyr/build/zephyr/include/generated/devicetree_unfixed.h -- Generated device_extern.h: /home/vinz/Work/git/snt_zephyr/build/zephyr/include/generated/device_extern.h Parsing /home/vinz/Work/git/snt_zephyr/zephyr/Kconfig Loaded configuration '/home/vinz/Work/git/snt_zephyr/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig' Merged configuration '/home/vinz/Work/git/snt_zephyr/zephyr/samples/hello_world/prj.conf' Merged configuration '/home/vinz/Work/git/snt_zephyr/build/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/home/vinz/Work/git/snt_zephyr/build/zephyr/.config' Kconfig header saved to '/home/vinz/Work/git/snt_zephyr/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 10.2.1 -- The CXX compiler identification is GNU 10.2.1 -- The ASM compiler identification is GNU -- Found assembler: /home/vinz/gnuarmemb/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-gcc CMake Error at /home/vinz/Work/git/snt_zephyr/nrf/modules/mcuboot/CMakeLists.txt:112 (add_child_image): Unknown CMake command "add_child_image". -- Configuring incomplete, errors occurred! See also "/home/vinz/Work/git/snt_zephyr/build/CMakeFiles/CMakeOutput.log". See also "/home/vinz/Work/git/snt_zephyr/build/CMakeFiles/CMakeError.log".
I am on Arch Linux, with CMake 3.19.7.
I tried using ARM GCC Embedded, Zephyr SDK 0.11.3, 0.12.3, but to no avail.
Also tried to remove zephyr cache (rf -rf ~/cache/zephyr), but the result is the same.
When I remove my own "mcuboot" project from my west.yml, and therefor the one imported from nrf/west.yml is used instead, everything works as expected.
Except of course, then I cannot use my custom "mcuboot" softfork.
Is this a known issue? How can I use my own "mcuboot" softfork, without having to fork the "nrf-sdk" repo as well?
