OTA DFU Thread: merge with NCP.hex
Hi all,
in my current platform I have:
  1. a DK (we are working to implement HW modifications to use a nrf52 dongle for this purpose) that is performing as a Thread DFU server (following this example https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v3.2.0%2Fthread_example_dfu.html)
  2. a nrf52 dongle that is running the NCP example under <SDK folder>/examples/thread/ncp/ftd/usb/hex
We would like to merge the two functionalities to use one single board to handle both.
Do you have any suggestions?
I think the easiest way is to have:
  • the source code of the NCP example (SDK/examples/thread/ncp/ftd/usb/hex)
  • the source code of the connectivity fw for Thread DFU purpose that is automatically flash by nrfutil ('-f') when you run the line:
    nrfutil dfu thread -f -pkg app_dfu_package.zip -p COMx --channel 11 --panid 43981 -r 4 -rs 5000 -a FF03::1
 so that we can merge them manually.
Is it possible? Am I missing something? Are there any issues that I'm not considering?
Thanks in advace,
Alessio
(nrfutil version: 6.1
SDK version: nRF5_SDK_for_Thread_and_Zigbee_v4.1.0_32ce5f8)
    Actually, the NCP example is the one being used when running the command "nrfutil dfu thread -f -pkg app_dfu_package.zip -p COMx --channel 11 --panid 43981 -r 4 -rs 5000 -a FF03::1". However, it is the uart version, and not the USB version.
    Try manually compiling the dongle using nRF Connect for Desktop -> Programmer, and then call your nrfutil call "nrfutil dfu thread -pkg app_dfu_package.zip -p COMx --channel 11 --panid 43981 -r 4 -rs 5000 -a FF03::1" without the "-f" flag. Does that work?
    Please note that the COM port may change after you program it with the NCP example.
    Edvin
