Immutable bootloader minimal config does not fit
I noticed the minimal b0 immutable bootloader build does not fit anymore.
I used the example here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bootloader/README.html
And the same one is here, btw: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_bootloader.html
Firstly, overlay-minimal-size.conf does not seem to exist anymore, but it looks like it's called "prj_minimal.config" now.
When adjusting the example command to this:
west build -b nrf52840dk_nrf52840 zephyr/samples/hello_world -- -DCONFIG_SECURE_BOOT=y -Db0_OVERLAY_CONFIG=prj_minimal.conf
instead of:
west build -b nrf52840dk_nrf52840 zephyr/samples/hello_world -- -DCONFIG_SECURE_BOOT=y -Db0_OVERLAY_CONFIG=overlay-minimal-size.conf
This results in a b0 bootloader too big for the 12kB partition size:
/home/vinz/gnuarmemb/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: zephyr/zephyr_prebuilt.elf section `text' will not fit in region `FLASH'
/home/vinz/gnuarmemb/gcc-arm-none-eabi-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: region `FLASH' overflowed by 2340 bytes
Memory region Used Size Region Size %age Used
FLASH: 14628 B 12 KB 119.04%
SRAM: 38560 B 256 KB 14.71%
IDT_LIST: 8 B 2 KB 0.39%
collect2: error: ld returned 1 exit status
I suspect that "prj_minimal.conf" is not meant as an overlay, and the original "overlay-minimal-size.conf" has disappeared.
What does work, however, is to go to the nrf/samples/bootloader directory,
and build it explicitly using "prj_minimal.conf", like this:
west build -p=always -b nrf52840dk_nrf52840 -- -DCONF_FILE=prj_minimal.conf
Can this be fixed? Or at least the documentation?
Thanks!
