Is it possible to program an application on nRF52832 using SES if I have Buttonless DFU implemented?
Hello!
I am working on a project where we want over the air updates for the finished product. To make that possible I implemented the buttonless DFU and it is working great!
My current issue is that now that a bootloader has been added to the device if I change the application at all it no longer matches what is expected. If I program the application using SES it will immediately go into the bootloader and display as DFUTarg instead of booting into the newly flashed application.
Is there a way to program the device using SES while the bootloader is present? For example a setting that I could set up while creating the bootloader settings file that tells it to ignore changes made in the application?
I am using the following:
Secure Bootloader for s132, Softdevice 7.2.0 S132, and my custom application.
SDK 17.0.2
NRF52832
    You need to generate a HEX file that contains the Bootloader Settings page. See the nrfutil documentation for instructions. To program a bootloader settings HEX file, use mergehex (part of the nRF5x Command Line Tools) to merge the bootloader HEX file and the bootloader settings HEX file.
    -Amanda H.
  • Thanks for your response Amanda,
    I have previously generated a bootloader settings page, but the problem persists. I'll upload that settings hex along with the command that I used to generate it to see if you can find the setting I missed.
    :020000040007F3
    :10E00000AF7BBD8E0200000058020000000000003F
    :10E010000000000000000000A4830100DA38366729
    :10E0200001000000000000000000000000000000EF
    :10E03000000000006C490200000000000000000029
    :10E0400000000000000000000000000000000000D0
    :10E0500000000000000000000000000000000000C0
    :10E0600000000000000000000000000000000000B0
    :10E0700000000000000000000000000000000000A0
    :10E080000000000000000000000000000000000090
    :10E090000000000000000000000000000000000080
    :10E0A0000000000000000000000000000000000070
    :10E0B0000000000000000000000000000000000060
    :10E0C0000000000000000000000000000000000050
    :10E0D0000000000000000000000000000000000040
    :10E0E0000000000000000000000000000000000030
    :10E0F0000000000000000000000000000000000020
    :10E10000000000000000000000000000000000000F
    :10E1100000000000000000000000000000000000FF
    :10E1200000000000000000000000000000000000EF
    :10E1300000000000000000000000000000000000DF
    :10E1400000000000000000000000000000000000CF
    :10E1500000000000000000000000000000000000BF
    :10E1600000000000000000000000000000000000AF
    :10E17000000000000000000000000000000000009F
    :10E18000000000000000000000000000000000008F
    :10E19000000000000000000000000000000000007F
    :10E1A000000000000000000000000000000000006F
    :10E1B000000000000000000000000000000000005F
    :10E1C000000000000000000000000000000000004F
    :10E1D000000000000000000000000000000000003F
    :10E1E000000000000000000000000000000000002F
    :10E1F000000000000000000000000000000000001F
    :10E20000000000000000000000000000000000000E
    :10E2100000000000000000000000000000000000FE
    :10E2200000000000000000000000000000000000EE
    :10E2300000000000000000000000000000000000DE
    :10E2400000000000000000000000000000000000CE
    :10E25000000000000000000000000000EB401AA6D3
    :10E2600001432AE3D5000000000000000000000088
    :10E27000000000000000000000000000000000009E
    :10E28000000000000000000000000000000000008E
    :10E29000000000000000000000000000000000007E
    :10E2A0000001DA38366700000000000000000000BE
    :10E2B000000000000000000000000000000000005E
    :10E2C000000000000000000000000000000000004E
    :10E2D000000000000000000000000000000000003E
    :10E2E000000000000000000000000000000000002E
    :10E2F000000000000000000000000000000000001E
    :10E30000000000000000000000000000000000000D
    :10E3100000000000000000000000000000000000FD
    :03E32000000000FA
    :10F00000AF7BBD8E0200000058020000000000002F
    :10F010000000000000000000A4830100DA38366719
    :10F0200001000000000000000000000000000000DF
    :10F03000000000006C490200000000000000000019
    :10F0400000000000000000000000000000000000C0
    :10F0500000000000000000000000000000000000B0
    :10F0600000000000000000000000000000000000A0
    :10F070000000000000000000000000000000000090
    :10F080000000000000000000000000000000000080
    :10F090000000000000000000000000000000000070
    :10F0A0000000000000000000000000000000000060
    :10F0B0000000000000000000000000000000000050
    :10F0C0000000000000000000000000000000000040
    :10F0D0000000000000000000000000000000000030
    :10F0E0000000000000000000000000000000000020
    :10F0F0000000000000000000000000000000000010
    :10F1000000000000000000000000000000000000FF
    :10F1100000000000000000000000000000000000EF
    :10F1200000000000000000000000000000000000DF
    :10F1300000000000000000000000000000000000CF
    :10F1400000000000000000000000000000000000BF
    :10F1500000000000000000000000000000000000AF
    :10F16000000000000000000000000000000000009F
    :10F17000000000000000000000000000000000008F
    :10F18000000000000000000000000000000000007F
    :10F19000000000000000000000000000000000006F
    :10F1A000000000000000000000000000000000005F
    :10F1B000000000000000000000000000000000004F
    :10F1C000000000000000000000000000000000003F
    :10F1D000000000000000000000000000000000002F
    :10F1E000000000000000000000000000000000001F
    :10F1F000000000000000000000000000000000000F
    :10F2000000000000000000000000000000000000FE
    :10F2100000000000000000000000000000000000EE
    :10F2200000000000000000000000000000000000DE
    :10F2300000000000000000000000000000000000CE
    :10F2400000000000000000000000000000000000BE
    :10F25000000000000000000000000000EB401AA6C3
    :10F2600001432AE3D5000000000000000000000078
    :10F27000000000000000000000000000000000008E
    :10F28000000000000000000000000000000000007E
    :10F29000000000000000000000000000000000006E
    :10F2A0000001DA38366700000000000000000000AE
    :10F2B000000000000000000000000000000000004E
    :10F2C000000000000000000000000000000000003E
    :10F2D000000000000000000000000000000000002E
    :10F2E000000000000000000000000000000000001E
    :10F2F000000000000000000000000000000000000E
    :10F3000000000000000000000000000000000000FD
    :10F3100000000000000000000000000000000000ED
    :03F32000000000EA
    :00000001FF
    Command:
    • nrfutil settings generate --softdevice s132_nrf52_7.2.0_softdevice.hex --key-file PRIVATE KEY LOCATION --family NRF52 --application APPLICATION HEX --application-version-string "VERSION NUMBER" --bl-settings-version 2 --bootloader-version 0 OUTPUT HEX FILE
    Using mergehex I then merged that file with the bootloader and the softdevice, and in turn merged those files with the application to generate the file that I program. I'll detail the steps I followed below.
    • mergehex --merge BOOTLOADER SETTINGS HEX secure_bootloader_ble_s132_pca10040.hex s132_nrf52_7.2.0_softdevice.hex --output OUTPUT HEX FILE
    • mergehex --merge (OUTPUT FROM LAST STEP) ( APPLICATION HEX) --output (OUTPUT FILE NAME)
    Again the issue I'm having is that I cannot use SES to load new application versions once the I've programmed this file. This makes debugging very time consuming as for each change I need to follow all of these steps to create a new version instead of simply pressing build and run from SES.
    What setting did I miss?
  • Try the command to generate the bootloader setting:
    nrfutil settings generate --family NRF52 --application app.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex
    merge Softdevice and bootloader:
    mergehex -m softdevice.hex bootloader.hex -o merged_SD_bootloader.hex
    nrfjprog --program merged_SD_bootloader.hex --chiperase
    merge bootloader setting with app image:
    mergehex -m app.hex settings.hex -o merged.hex
    nrfjprog --program merged.hex --sectorerase
    Amanda H
  • I performed the steps as you have them outlined here. The device programmed correctly, just as I was able to do previously, but is still showing the same behavior as before when I try to program a slightly altered version of the application firmware without reprogramming the entire device.
    This goes back to my original question: Now that I have the bootloader and the DFU service implemented, is it no longer possible to simply program the application via Segger embedded studio? How can we get the bootloader to not assert itself when the application changes, but the rest of the firmware (bootloader, softdevice, bl_settings) dont?
    Do I have to create a new bootloader settings file each time I want to program the device?
    Programming the softdevice, bootloader and bootloader settings before you load the app via segger.
    You can skip the integrity check. Note that SDK 17 added optional skipping of application CRC check. CRC check can be skipped on wakeup from System Off or on special value written to GPREGRET2 register (when bit 1 (0-indexed) is set in the GPREGRET2 register).
    No, if you skip the integrity check, you don't need to do this. See this post.
    -Amanda H.
