I'm going to play NCS, but I can't find toolchain manager while Getting Started Assistant is depricated.
Your app list seems generally outdated, because you also have other outdated apps (the BLE app has newer versions) which do not show an “Update” button.
Please go to the Settings. I assume you have “Check for updates at startup” disabled there. Click on “Check for updates” in the settings. This should update the app list, which should then include the toolchain manager and also show you existing updates for other apps.
I think it is a network issue.
Yes, you are correct that it is most likely a network issue. We have had reports of problems with the network between mainland China and Github, which might cause this error to appear. This can also be the result of using a proxy server or using a company's internal network, which might block some ports for security reasons.
Are you able to open the webpage in your screenshot, https://raw.githubusercontent.com/NordicSemiconductor/pc-nrfconnect-launcher/master/apps.json in a browser? If you are unable to open it, then it is a network problem on your side. If you are using a proxy server, please follow the instructions found here. Please also try to change your network environment.
If none of this works, you can also try installing NCS manually instead of through the Toolchain Manager, using this guide.
Marte
Yes, it's the BETWEEN problem.
Thanks, I have to do it manually.
