NRF9160 Low power
I was testing 9160 power consumption, the specifications says it is the minimum consumption current 7µA, but when I test on the DK board, the minimum current is 2ma, my test code in addition to the initialization of a button, there is no other operations, in the while i used the k_cpu_idle(), and didn't open the modem, why current would be so big?
my main() function code like this:
void key_init(void)
	int err;
	LOG_INF("key_init\n");
	err = buttons_init(button_handler);
	if (err)
		LOG_INF("Could not initialize buttons, err code: %d\n", err);
		return;
	k_timer_init(&g_long_press_timer_id, long_press_timer_handler, NULL);
void system_init(void)
	key_init();
	system_init();
	while(1)
		k_cpu_idle();
my prj.conf file like this:
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_GPIO=n
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# Log
CONFIG_LOG=n
# Modem info
CONFIG_MODEM_INFO=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# Flash
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# NVS
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# GPS
CONFIG_AT_CMD=y
CONFIG_AT_NOTIF=y
# AT_CMD
CONFIG_AT_HOST_LIBRARY=y
# Console
CONFIG_CONSOLE_SUBSYS=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_CONSOLE_GETCHAR=n
CONFIG_CONSOLE=n
CONFIG_RTT_CONSOLE=n
CONFIG_UART_CONSOLE=n
# Enable SUPL client support AGPS
CONFIG_SUPL_CLIENT_LIB=n
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_USE_FALLBACK=n
CONFIG_LTE_NETWORK_TIMEOUT=600
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=n
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
CONFIG_LTE_LEGACY_PCO_MODE=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_MQTT_CLIENT_ID="devzone_client"
CONFIG_MQTT_BROKER_HOSTNAME="test.mosquitto.org"
CONFIG_MQTT_BROKER_PORT=8884
CONFIG_SEC_TAG=51966
CONFIG_PEER_VERIFY=1
# Library for buttons and LEDs
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_INVERT_LEDS=n
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HW_STACK_PROTECTION=y
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
# UART
CONFIG_SERIAL=y
# Use smaller buffers for net_buf as CANBUS packets are quite small.
CONFIG_NET_BUF_DATA_SIZE=64
CONFIG_NET_BUF_USER_DATA_SIZE=1
