what command should I send via BLE to disable the pressure, gas, and light/color intensity sensor?
Hello!
In this documentation:
nordicsemiconductor.github.io/.../firmware_architecture.html
written:
"The environment module is responsible for reading the temperature, pressure, humidity, air quality/gas, and light intensity/color sensors, as well as for sending data and configuration. It is running on top of the environment BLE service (ble_tes), the environment sensor drivers, and the environment flash storage with base UUID EF68xxxx-9B35-4933-9B10-52FFA9740042. The configuration is stored in flash. To turn on sensor reading, enable notifications from the desired characteristic by writing 0x0001 to the Client Characteristic Configuration Descriptor (CCCD) for that characteristic."
