I am using Nordic nRF52832. I wrote the simplest code for entering system off mode. My code does nothing except system off (see below). I built the solution, downloaded it to the target board, then disconnected the Jlink cable, and then powered cycles several times.
I than measured current. The current was 6mA from the Nordic IC (that's 6 mili Amps, not micro amps). According to the data sheet, in System Off, the IC should consume less than 2uA. I verified that I am measuring only the current that goes to the Nordic IC and not to other ICs.
Can you tell me what I am doing wrong?
// main.c
#include "nrf_log_ctrl.h"
sd_power_system_off();
