Hi everyone.
I am developing a product with nRF5340. But I found some problems with the power consumption of the device.
I'm not sure what I am doing wrong.
Condition
When disable button Interrups : ~5uA
When enable button interrups : ~100uA
#include <zephyr.h>
#include <device.h>
#include <drivers/gpio.h>
#include <sys/util.h>
#include <sys/printk.h>
#include <inttypes.h>
#include <stdio.h>
#include <init.h>
#include <power/power.h>
#include <hal/nrf_gpio.h>
#define BT_PORT "GPIO_0"
#define LED_1 28
#define BUTTON_1 23
#define BUTTON_2 24
const struct device *gpio_0;
void button_pressed(const struct device *dev, struct gpio_callback *cb,
uint32_t pins)
printk("Button pressed ^_^\n");
if (pins & BIT(BUTTON_1))
printk("Button pressed BUTTON_1\n");
gpio_pin_set_raw(gpio_0, LED_1, 1);
}else if (pins & BIT(BUTTON_2))
printk("Button pressed BUTTON_2\n");
gpio_pin_set_raw(gpio_0, LED_1, 0);
static void configure_button(void)
int ret;
static struct gpio_callback button_cb;
gpio_0 = device_get_binding(BT_PORT);
gpio_pin_configure(gpio_0, BUTTON_1, GPIO_INPUT | GPIO_PULL_UP);
gpio_pin_configure(gpio_0, BUTTON_2, GPIO_INPUT | GPIO_PULL_UP);
ret = gpio_pin_interrupt_configure(gpio_0, BUTTON_1, GPIO_INT_EDGE_FALLING);
if (ret != 0)
printk("Error %d: failed to configure interrupt pin %d\n" , ret, BUTTON_1);
return;
ret = gpio_pin_interrupt_configure(gpio_0, BUTTON_2, GPIO_INT_EDGE_FALLING);
if (ret != 0)
printk("Error %d: failed to configure interrupt pin %d\n" , ret, BUTTON_2);
return;
gpio_init_callback(&button_cb, button_pressed,
BIT(BUTTON_1) |
BIT(BUTTON_2) );
gpio_add_callback(gpio_0, &button_cb);
printk("OK:configure_button\n");
void main(void)
int ret;
if (gpio_0 == NULL) {
printk("Error: didn't find device port_0\n");
return;
printk("OK: Found device port_0\n");
//configure_button();
while(1)
k_msleep(20000);
project configCONFIG_GPIO=y
CONFIG_SYS_POWER_MANAGEMENT=y
CONFIG_DEVICE_POWER_MANAGEMENT=y
CONFIG_PM=y
CONFIG_PM_DEEP_SLEEP_STATES=y
CONFIG_PM_SLEEP_STATES=y
# Required to disable default behavior of deep sleep on timeout
CONFIG_PM_STATE_LOCK=y
CONFIG_PM_DEVICE=y
CONFIG_USE_SEGGER_RTT=n
CONFIG_RTT_CONSOLE=n
CONFIG_SERIAL=n
CONFIG_LOG=y
CONFIG_CONSOLE=n
CONFIG_BT_DEBUG_LOG=n
CONFIG_STDOUT_CONSOLE=n
CONFIG_PRINTK=n
Source Code: Link Zephyr_OS_BUTTON
Board: NRF5340-DK
SDK: nRF Connect SDK V1.5.0
