I've been given the task of porting an existing application from the nRF52840DK to a nFR52840 Dongle.
Simplified, the application uses the Shell functionality from Zephyr to control external devices using Thread. The application works satisfactorily on the DK, but I cannot find any resource describing which changes I need to make in order to make the Dongle function in the same way.
I've found this thread describing an approach to using the Dongle for logging using the CLI.
I've also found this thread touching on an eerily similar issue.
Unfortunately no matter how hard I try to search around looking for the magic configuration option, I can't seem to get anything working.
Here's the prj.conf which works just fine on the DK.
#Enable C++17 support CONFIG_STD_CPP17=y # OpenThread settings and dependencies CONFIG_NETWORKING=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_POLL_MAX=4 CONFIG_NET_CONNECTION_MANAGER=y # Kernel options CONFIG_MAIN_STACK_SIZE=2048 # CONFIG_ENTROPY_GENERATOR=y CONFIG_INIT_STACKS=y # Increase set for threads with meta-irq priority CONFIG_NUM_METAIRQ_PRIORITIES=1 # Logging CONFIG_NET_LOG=y CONFIG_LOG=y CONFIG_NET_STATISTICS=y # Network buffers CONFIG_NET_PKT_RX_COUNT=16 CONFIG_NET_PKT_TX_COUNT=16 CONFIG_NET_BUF_RX_COUNT=80 CONFIG_NET_BUF_TX_COUNT=80 # Network shell CONFIG_NET_SHELL=y CONFIG_SHELL_ARGC_MAX=26 CONFIG_SHELL_CMD_BUFF_SIZE=416 CONFIG_CPLUSPLUS=y CONFIG_LIB_CPLUSPLUS=y CONFIG_NEWLIB_LIBC=y CONFIG_MINIMAL_LIBC=n CONFIG_NET_CONFIG_SETTINGS=y CONFIG_NET_IPV6_NBR_CACHE=n CONFIG_NET_IPV6_MLD=n CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_NET_TX_STACK_SIZE=2048 CONFIG_NET_RX_STACK_SIZE=5120 CONFIG_SHELL_STACK_SIZE=3072 CONFIG_NET_L2_OPENTHREAD=y CONFIG_OPENTHREAD_DEBUG=y CONFIG_OPENTHREAD_L2_DEBUG=y CONFIG_OPENTHREAD_L2_LOG_LEVEL_INF=y CONFIG_OPENTHREAD_CHANNEL=11 CONFIG_OPENTHREAD_MANUAL_START=y # Thread by default registers quite a lot addresses. CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=6 CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=8 # nRF board library CONFIG_DK_LIBRARY=y # Enable CoAP utils and CoAP protocol CONFIG_COAP_UTILS=y CONFIG_OPENTHREAD_COAP=y # Configure sample logging setting CONFIG_COAP_CLIENT_LOG_LEVEL_DBG=y CONFIG_COAP_CLIENT_UTILS_LOG_LEVEL_DBG=y CONFIG_COAP_UTILS_LOG_LEVEL_DBG=y CONFIG_COAP_SERVER_LOG_LEVEL_DBG=y CONFIG_OT_COAP_UTILS_LOG_LEVEL_DBG=y # Set optimization level CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_COMPILER_OPT="-Wno-psabi" ## USB # Usb CONFIG_USB_DEVICE_PRODUCT="USB central interface" CONFIG_USB_DEVICE_VID=0xA552 CONFIG_USB_DEVICE_PID=0x01A4 CONFIG_USB=y CONFIG_USB_CDC_ACM=y CONFIG_USB_UART_CONSOLE=n CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_USB_DEVICE_LOG_LEVEL_INF=y # Uart CONFIG_SERIAL=y # CONFIG_USE_SEGGER_RTT=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0" CONFIG_UART_LINE_CTRL=y CONFIG_CONSOLE=y CONFIG_GPIO=y CONFIG_STDOUT_CONSOLE=y # CONFIG_LOG=y CONFIG_UART_ASYNC_API=y # Nordic/Soc CONFIG_ARM_MPU=y CONFIG_SOC_SERIES_NRF52X=y # CONFIG_SOC_NRF52840_QIAA=y CONFIG_NRFX_TIMER=y CONFIG_NRFX_TIMER0=y CONFIG_NRFX_PPI=y # Ram CONFIG_HEAP_MEM_POOL_SIZE=16384 CONFIG_IDLE_STACK_SIZE=2048 CONFIG_ISR_STACK_SIZE=4096 CONFIG_UART_MUX_RX_STACK_SIZE=1024 CONFIG_HW_STACK_PROTECTION=y
Some changes I've tried:
Added CONFIG_UART_SHELL_ON_DEV_NAME="CDC_ACM_0"
Disabled interrupt-driven UART
Enabled and disabled all sorts of CONSOLE related options
I've tried to run quite a few samples on the Dongle. All console-related samples work, but shell-samples refuse to cooperate.
Could someone point me in the direction of a configuration setting I'm overlooking?
Many thanks for any help
-Robin G
