Zigbee and Serial communication issue
Hello Nordic!
I have been developing a Zigbee application and now, I need to connect via Serial communication with another device. I just need to listen to the port, not send any data. Unfortunately I don't have that device so I am simulating it with an Arduino Uno. It is configured as the original device at 19200baud, 8bit, 1 stop bit. First of al, is there any other better way to read data through RX/TX? Any other libraries instead of libuarte?
I found the libuarte example which I modified and make it work for my needs. It reads my Arduino via Serial communication correctly and I obtain the characters nicely. My problem occurs when I try to implement the libuarte code into mine. I have had several problems with the sdk_config file. But once the errors have faded out and the code have compiled, I have flashed it into the nrf52840DK board but the Zigbee and Serial communication suddenly stopped working. Could it be that they share some timer or some other peripheral?
I have tried changing the timer for the serial communication but achieved nothing. What may be causing this issue?
The modified code of the libuarte's example is as follows:
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup libuarte_example_main main.c
 * @ingroup libuarte_example
 * @brief Libuarte Example Application main file.
 * This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started.\r\n Loopback:\r\n";
static uint8_t text_size = sizeof(text);
static volatile bool m_loopback_phase;
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            bsp_board_led_invert(0);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            if (ret == NRF_ERROR_BUSY)
                buffer_t buf = {
                    .p_data = p_evt->data.rxtx.p_data,
                    .length = p_evt->data.rxtx.length,
                ret = nrf_queue_push(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
            bsp_board_led_invert(1);
            m_loopback_phase = true;
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            bsp_board_led_invert(2);
    ret_code_t ret = nrf_drv_clock_init();
    ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_19200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
    err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
    while (true)
        NRF_LOG_FLUSH();
Thanks to all in advance!
Cheers!
    Perhaps you can look into the Zigbee CLI example found in:
    SDK_for_thread_and_zigbee_v4.1.0\examples\zigbee\experimental\cli\cli_agent_router, which is an example where a lot of the zigbee api is serialized.
    If you want to continue on the libuarte path, did you try writing something to the log? Try adding:
    NRF_LOG_INFO("starting application"); right after NRF_LOG_DEFAULT_BACKENDS_INIT(). Do you see the log anywhere? (RTT perhaps, if you are using UART for your application).
    If you see the log, does the log say anything when your application isn't working?
    BR,
    Edvin
  • Hello Edvin!
    Thanks for your quick reply!
    Could you specify a bit more what should I look at in the cli_agent_router example? The code is too short...
    About the log, I haven't had time to learn how to use the NRF_LOG so what I am using is the printf function to show some info via Debug Terminal (in Segger). May you link some information about how to use it? I guess it is more useful than the printf function that I am currently using.
    Anyway, I placed the printf function right under the NRF_LOG_DEFAULT_BACKENDS_INIT() call and it didn't show in the debug terminal... What could be causing this  issue?
    What I found is that the call to nrf_drv_clock_init() is failing, it is returning 0x85 error code. I will debug a bit more this...
    EDIT: I just found out that the error code 0x0085 means that the module is already initialized. So I think I can either remove that call or remove the call to the APP_ERROR_CHECK function. Am I right? Unfortunately the code still fails in the call to NRF_LOG_DEFAULT_BACKENDS_INIT()... I will continue to investigate this issue...
    Thanks in advance!
  • It may not be clear what this does based on the main.c file, but check the test description:
    https://infocenter.nordicsemi.com/topic/sdk_tz_v4.1.0/zigbee_example_cli_agent.html?cp=7_3_3_8_5_1_3#zigbee_example_cli_agent_testing
     The reason I asked about this is that it will print the error information in the log.
    Try to run any of the examples that are already using the log, e.g. ble_app_uart (NB: You need to flash the sofdevice manually if you are not using Segger Embedded Studio). Then either open JLink RTT Viewer, or if you are using Segger Embedded Studio, then change this define in sdk_config.h from 1 to 0:
    #define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1
    to
    #define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0
    and click "build and debug".
    Then look at how this is set up in that project, and try to do the same in your project. If you get the log up and running it is a useful tool for debugging, since the error handler will print errors in the log. Please define DEBUG in your preprocessor definitions to see extra logging information from the error handler. Let me know what IDE you are using if you don't know how to add preprocessor definitions.
    I am not sure. printf doesn't use the NRF_LOG.
     Perhaps you are trying to use the UART for both NRF_LOG and printf (not possible). Try to set the RTT backend in sdk_config.h. If you don't know how to do it, see ble_app_uart's sdk_config.h file (since it uses the RTT backend for logging by default).
  • Hello Edvin!
    I'm using Segger and I've got NRF_LOG working. I am going to change all my printf functions to NRF_LOG_INFO and NRF_LOG_ERROR.
    I have been reading and understanding the cli_agent code but I have some doubts about it. The cli_agent uses the nrf_drv_uart libraries and macros. I just need to read the serial port and wait for a specific string to arrive. I thought about using interruptions for that, so I think I don't need to implement DMA. Am I right? Do you recommend using it anyway? What are the differences between the nrf_drv_uart and libuarte libraries?
    Thanks!
    Cheers!
    Sorry for the late reply. I have been out of office for the last 8 days.
    Just to sort out a couple of things. If the NRF_LOG is using the UART backend, then I think you will have a hard time reading the UART, because it is occupied by the log module. But in this example, the log uses the RTT backend.
     the libuarte is tailored for fast UART transfers. If it is not very fast, I suggest you stick to the nrf_drv_uart.
    I suggest you check out the ble_app_uart example from the SDK. This doesn't use Zigbee, but perhaps you can get some inspiration from the UART handler in that example.
    Alternatively, you can add the commands you need in the pool of CLI commands. Look at how it sets up the CLI commands. That is why I initially mentioned the CLI example.
    BR,
    Edvin
