USB BOS descriptor (vendor specific)
I have tried to add support for BOS descriptor by appending a custom class generated from the Dummy example. The "main" class is the HID generic class, but with the NRF USBD driver not supporting vendor specific requests I want to hook onto events and process this in my own class.
I append my custom class and It enumerates fine and the BOS descriptor is read correctly. So far so good. And the code needed is minimal. But there is an upper limit to everything. The USBD driver now reports two interfaces being present and that causes Windows not to load the MS generic HID driver. Apparently the Windows generic HID driver expects one interface only (both Windows enumeration and my Ellisys USB Explorer reports that every is OK).
So, my question is: How can I add a custom class (to hook onto unhandled events), which sole purpose is to grab unhandled requests, without the USBD driver starts shouting about additional interfaces? I can't see how adding additional interfaces can be avoided. You can't set the feed_descriptors to NULL as you then get an assert. You can't omit the feed_descriptors entry from app_usbd_class_methods_t. Is there a smart way to do this?
You see, the idea is not the re-write the USBD but to use it as is, thereby making it easier to update to new versions of the SDK.
I just tried to clear the feed_descriptors function so that the only thing it does it to return false, and to copy the class to RAM and change the iface.cnt to 0. Then it works. But it just doesn't seem so neat to have to copy it to RAM. Maybe I could create the class directly in RAM but then I wouldn't be using the same procedure as the SDK.
Looking forward to hearing good suggestions on how to go about it :-)
Christian
