NRFX_TIMER3_INST_IDX' undeclared (first use in this function), SDK enabled
I'm uploading a BLE & TWI code to nRF52 DK. Now, I'm getting this error:
According to other similar posts, I have enabled timers in SDK.
// <e> NRFX_TIMER_ENABLED - nrfx_timer - TIMER periperal driver
#ifndef NRFX_TIMER_ENABLED
#define NRFX_TIMER_ENABLED 1
// <q> NRFX_TIMER0_ENABLED  - Enable TIMER0 instance
#ifndef NRFX_TIMER0_ENABLED
#define NRFX_TIMER0_ENABLED 1
// <q> NRFX_TIMER1_ENABLED  - Enable TIMER1 instance
#ifndef NRFX_TIMER1_ENABLED
#define NRFX_TIMER1_ENABLED 1
// <q> NRFX_TIMER2_ENABLED  - Enable TIMER2 instance
#ifndef NRFX_TIMER2_ENABLED
#define NRFX_TIMER2_ENABLED 1
// <q> NRFX_TIMER3_ENABLED  - Enable TIMER3 instance
#ifndef NRFX_TIMER3_ENABLED
#define NRFX_TIMER3_ENABLED 1
// <q> NRFX_TIMER4_ENABLED  - Enable TIMER4 instance
#ifndef NRFX_TIMER4_ENABLED
#define NRFX_TIMER4_ENABLED 1
// <o> NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY  - Timer frequency if in Timer mode
// <0=> 16 MHz
// <1=> 8 MHz
// <2=> 4 MHz
// <3=> 2 MHz
// <4=> 1 MHz
// <5=> 500 kHz
// <6=> 250 kHz
// <7=> 125 kHz
// <8=> 62.5 kHz
// <9=> 31.25 kHz
#ifndef NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY
#define NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY 0
// <o> NRFX_TIMER_DEFAULT_CONFIG_MODE  - Timer mode or operation
// <0=> Timer
// <1=> Counter
#ifndef NRFX_TIMER_DEFAULT_CONFIG_MODE
#define NRFX_TIMER_DEFAULT_CONFIG_MODE 0
// <o> NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH  - Timer counter bit width
// <0=> 16 bit
// <1=> 8 bit
// <2=> 24 bit
// <3=> 32 bit
#ifndef NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH
#define NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH 0
// <o> NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY
#define NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 6
// <e> NRFX_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_TIMER_CONFIG_LOG_ENABLED
#define NRFX_TIMER_CONFIG_LOG_ENABLED 1
// <o> NRFX_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRFX_TIMER_CONFIG_LOG_LEVEL
#define NRFX_TIMER_CONFIG_LOG_LEVEL 3
// <o> NRFX_TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_TIMER_CONFIG_INFO_COLOR
#define NRFX_TIMER_CONFIG_INFO_COLOR 0
// <o> NRFX_TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_TIMER_CONFIG_DEBUG_COLOR
#define NRFX_TIMER_CONFIG_DEBUG_COLOR 0
In my nrfx_timer.c file. timer3 section is the only part that is NOT greyed out.
Any idea, please? Thank you!
    Have you defined both the legacy and NRFX TIMER definitions?
    If you leave the legacy TIMER#_ENABLED defined in your SDK config, it will overwrite your NRFX definition.
    Please make sure that only the NRFX_TIMER#_ENABLED is defined, and none of the TIMER#_ENABLED are defined, and see if this resolves the issue.
    For a more in-depth discussion of this apply_old_config issue, please see this ticket.
    If this does not resolve the issue, could you share your entire sdk_config file?
    Karl
  • Thanks, Karl.
    I tried your method, unfortunately, the problem didn't solve. Here is how I solved the issue today by 2 steps:
    Step 1) For the error "NRFX_TIMER3_INST_IDX' undeclared (first use in this function)", my solution is: in sdk_config.h, I enabled both "TIMER#_ENABLED" and "legacy TIMER#_ENABLED".
    // <e> TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver - legacy layer
    #ifndef TIMER_ENABLED
    #define TIMER_ENABLED 1
    // <o> TIMER_DEFAULT_CONFIG_FREQUENCY  - Timer frequency if in Timer mode
    // <0=> 16 MHz
    // <1=> 8 MHz
    // <2=> 4 MHz
    // <3=> 2 MHz
    // <4=> 1 MHz
    // <5=> 500 kHz
    // <6=> 250 kHz
    // <7=> 125 kHz
    // <8=> 62.5 kHz
    // <9=> 31.25 kHz
    #ifndef TIMER_DEFAULT_CONFIG_FREQUENCY
    #define TIMER_DEFAULT_CONFIG_FREQUENCY 0
    // <o> TIMER_DEFAULT_CONFIG_MODE  - Timer mode or operation
    // <0=> Timer
    // <1=> Counter
    #ifndef TIMER_DEFAULT_CONFIG_MODE
    #define TIMER_DEFAULT_CONFIG_MODE 0
    // <o> TIMER_DEFAULT_CONFIG_BIT_WIDTH  - Timer counter bit width
    // <0=> 16 bit
    // <1=> 8 bit
    // <2=> 24 bit
    // <3=> 32 bit
    #ifndef TIMER_DEFAULT_CONFIG_BIT_WIDTH
    #define TIMER_DEFAULT_CONFIG_BIT_WIDTH 0
    // <o> TIMER_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef TIMER_DEFAULT_CONFIG_IRQ_PRIORITY
    #define TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 6
    // <q> TIMER0_ENABLED  - Enable TIMER0 instance
    #ifndef TIMER0_ENABLED
    #define TIMER0_ENABLED 1
    // <q> TIMER1_ENABLED  - Enable TIMER1 instance
    #ifndef TIMER1_ENABLED
    #define TIMER1_ENABLED 1
    // <q> TIMER2_ENABLED  - Enable TIMER2 instance
    #ifndef TIMER2_ENABLED
    #define TIMER2_ENABLED 1
    // <q> TIMER3_ENABLED  - Enable TIMER3 instance
    #ifndef TIMER3_ENABLED
    #define TIMER3_ENABLED 0
    // <q> TIMER4_ENABLED  - Enable TIMER4 instance
    #ifndef TIMER4_ENABLED
    #define TIMER4_ENABLED 0
    // </e>
    Step 2) For the error "in nrfx_timer.c file. Timer3 section is the only part that is NOT greyed out. " I simply deleted the code in the red box (see below image). I guess it's because I accidentally deleted some timer 3 code elsewhere. I will share the answer with you if I could find it (Because I shouldn't delete the below red box code). But if you have any idea, please share your answer, too. Thank you very much!
    Thank you for your patience with this - we are short staffed due to the national easter holidays here in Norway.
    If you have left the apply_old_config file unchanged, this would mean that NRFX_TIMER_ENABLED is redefined to 0, since you also define TIMER_ENABLED
    I agree, you definitely should not have to delete the offending section - this is often just deleting the symptoms of the real issue.
    In general I would have to say that this approach is a short-term solution.
    Are you speculating whether you might have deleted code accidentally elsewhere, or are you stating that you have accidentally deleted code elsewhere?
    I would recommend that you redownload the SDK, to make sure you have a functional and complete version. The code you might have deleted could break other functionality in the SDK.
    Could I ask you to remove the legacy definitions of TIMER_ENABLED and TIMER#_ENABLED all together from your sdk_config, and see if this changes the issue of the greyed out sections?
    As in, do not  just change their definition to 0 (that will still leave them defined to 0), but either comment them out, or remove them entirely from the file.
    Do this, and see if the greyed out NRFX_CHECK is no longer grayed out, after cleaning the build and rebuilding the project.
    Karl
