Loss of connection between rf24 transmitter & receiver
Loss of comms between nRF24L01+ transmitter and receiver after successful data transfer.
One rf24 is configured as a PTX (sensor device) communicating in a simple point-point link with a second in PRX mode (base unit) over pipe 0. Both are connected to a small
microcomputer (not an Arduino). Example Code used for them to ping-pong between each other works well. But modified code when used in this Tx ->Rx mode fails after a random period?
My intended operational mode is for the PTX to send a radio code when a sensor is triggered - which could be every few minutes to every few hours.  At first this works on the bench with
PTX and PRX side by side, but despite a sequence of successful transmissions over a period between 5 minutes to 30 minutes, the PTX generally freezes first, sometime it's the Base PRX
which freezes first.  So my code seems to work ok until it suddendly doesn't. As far as I can tell, my code correctly implements the RF24 state diagrams, the registers appear to be correctly
configured and the TX-FIFO & RX-FIFO are flushed as necessary. After device power up I do leave the PTX in Tx mode and the PRX in Rx mode the whole time and don't set the
power-down but? This random freezing of communication suggests a timing issue somewhere, but I've tried various code modifications without success.
Question: Could there be an un-documented issue with these radios that may explain the sudden freezing of communication after a sequence of good operation, or am I missing
sometime more obvious.  Your help would be greatly appreciated!
I can send the configs if there's not an obvious answer.
thanks
