could you provide me an example codes for SPI (serial peripheral communication), SPIM(serial peripheral communication master) and SPIS(serial peripheral communication slave) for nRF5340 SoC.
Thanks & Regards,
Srinivas.
Thanks & Regards,
Srinivas.
Thanks for the response.
My problem is resolved. I am confused in pin connection. After change the pin connections it's working fine.
Srinivas Rao
Hi! I'm trying to build the example (SPI Master) but I was not able to compile without errors.
My environment is SDK 2.2.0, the board choosed is the Nordic 5340dk (I have an Ublox NORA EVK 106-B that is pretty similar & I have also the device tree). The output is:
Building spi_master
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Users/cirincione/nordic/spi_master/build c:/Users/cirincione/nordic/spi_master --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Users/cirincione/nordic/spi_master/prj.conf" -DBOARD_ROOT:STRING="c:/users/cirincione/nordic/peripheral_lbs;c:/users/cirincione/nordic/peripheral_lbsx;c:/users/cirincione/nordic/peripheral_lbs_int;c:/users/cirincione/nordic/testselcom""
CMake Warning at C:/ncs/v2.2.0/zephyr/cmake/app/boilerplate.cmake:20 (message):
Loading of Zephyr boilerplate.cmake directly is deprecated, please use
'find_package(Zephyr)'
CMakeLists.txt:9 (include)
-- Application: C:/Users/cirincione/nordic/spi_master
-- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
-- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.2.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Users/cirincione/nordic/spi_master/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/cirincione/nordic/spi_master/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/cirincione/nordic/spi_master/build/zephyr/dts.cmake
Parsing C:/ncs/v2.2.0/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.2.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/Users/cirincione/nordic/spi_master/prj.conf'
error: NRFX_SPIM (defined at C:/ncs/v2.2.0/zephyr/modules/hal_nordic\nrfx/Kconfig:190,
modules\hal_nordic\nrfx/Kconfig:190) is assigned in a configuration file, but is not directly user-
configurable (has no prompt). It gets its value indirectly from other symbols. See
docs.zephyrproject.org/.../kconfig.html and/or look up NRFX_SPIM in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
CMake Error at C:/ncs/v2.2.0/zephyr/cmake/modules/kconfig.cmake:328 (message):
command failed with return code: 1
C:/ncs/v2.2.0/nrf/cmake/modules/kconfig.cmake:29 (include)
C:/ncs/v2.2.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
C:/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.2.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
C:/ncs/v2.2.0/zephyr/cmake/app/boilerplate.cmake:25 (find_package)
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' '-DWEST_PYTHON=C:\ncs\toolchains\v2.2.0\opt\bin\python.exe' '-Bc:\Users\cirincione\nordic\spi_master\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=c:/Users/cirincione/nordic/spi_master/prj.conf '-DBOARD_ROOT:STRING=c:/users/cirincione/nordic/peripheral_lbs;c:/users/cirincione/nordic/peripheral_lbsx;c:/users/cirincione/nordic/peripheral_lbs_int;c:/users/cirincione/nordic/testselcom' '-Sc:\Users\cirincione\nordic\spi_master'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
The same output if I try with the Ublox Board.
I didn't understand the modifications that I need to do in the project to make it buildable.
The target is to build a working example for the Ublox EVK & SPI4 in order to test the SPIM API.
Could anyone support me?
Many Thanks & Best Regards
Other info:
I noticed that several inclusion files like as zephyr.h or nrf.h, for example, introduced fatal errrors.
I can include <nrfx.h>, <nrfx_spim.h> and <nrfx_gpiote.h> instead of.
Seems that the 2.2.0 SDK does not permit that.
Update 2023/07/13 - 12:06 AM:
- I try to port one piece at time into my project in wich I have a DT che define the SPI4.
- The inclusions are: #include <nrfx.h>, #include <nrfx_spim.h>, #include <nrfx_gpiote.h>
- I tested a declaration of a spi's type
static nrfx_spim_config_t spim_config = NRFX_SPIM_DEFAULT_CONFIG(APP_SPIM_SCK_PIN, APP_SPIM_MOSI_PIN, APP_SPIM_MISO_PIN, APP_SPIM_CS_PIN); . And it coimpile with success.
- If I insert the ISR:
The building failed because the SPIM3_SPIS3_TWIM3_TWIS3_SPI3_TWI3_IRQn is not declarated.
Thanks Again
Please post your issue in a new thread, instead of this closed ticket. We will then help you look into it.
ok I do it, Thanks
