Scanning with filtering
Hi everybody.
Now I trying to make BLE central device.
I'm using nrf52832.
SDK : 17.0.2
SoftDevice :S132 7.2.0
(I'm completely new at nrf52 product.)
In case of app_uart_c example, scanning is filtered by UUID to find peripheral device that example program written(ble_app_uart).
So now I'm trying to filtering by name.
Specifically...
I added
static char const m_target_periph_name[] = "Nordic_UART";
and instead of filtering by UUID, added in scan_init() function.
// Setting filters for scanning.(By UUID)
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
// Setting filters for scanning.(By Name)
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
( I referred this post of the forum.
https://devzone.nordicsemi.com/f/nordic-q-a/40686/where-to-change-name-for-the-scanning-peripheral-name-in-the-uart-central-code/158193#158193)
When I run the debugger, it break at NRF_BREAKPOIN_COND in app_error_weak.c.
then I continue, it keep at same line.
On the Debug Terminal, "app: Fatal error" is displayed.
I checked which line is causing this problem by debugger.
Then I found that it is jump to NRF_BREAKPOIN_COND after "APP_ERROR_CHECK()" of "nrf_ble_scan_filter_set()".
When I tried this example project without modification, It was working correctly.
then the Debug Terminal,"app: BLE UART central example started" was displayed.
Anybody can teach me why this problem is happening?
How can I solve it?
Thank you.
    The error here is probably that NRF_BLE_SCAN_NAME_CNT is set to 0 in sdk_config.h, so you need to adjust it to 1.
    Also, I recommend you use a debug build when testing (by selecting Debug from the build configuration dropdown if using SES, or defining DEBUG and DEBUG_NRF if using another toolchain), as that will give you a more sensible error report:
    <error> app: ERROR 7 [NRF_ERROR_INVALID_PARAM] at C:\Users\eith\SDK\nRF5_SDK_17.0.2_d674dde\examples\ble_central\ble_app_uart_c\main.c:194
    PC at: 0x00030447
    <error> app: End of error report
    Einar
  • Hi, Einar.
    Thank you for your reply.
    Your indication is effective.
    As you said, when I have this error, "NRF_BLE_SCAN_NAME_CNT" was set to 0 in my sdk_config.h.
    By changing this macro 0 to 1, now example program that I changed filter part is working correctly.
    Scanning with filter by name is working.
    Also, thank you for your advise about Debug Build.
    by changing Build Configuration from "Release" to "Build", detailed information about error is displayed in Debug Console when having error.
    Currently I'm in testing stage so this is good for me.
    Thank you very much!
