BLE lost messages
Hi, as part of my project i have 2 nordic 52dks one as a pheripheral (sending) and on as a client (recieving). where i am sening a buffer of 8, in the order
buffer[0] = 10
buffer[1}= X gyro lsb
buffer[2] = X gyro msb
buffer[3] = y gyro lsb
buffer[4] = y gyro msb
buffer[5] = z gyro lsb
buffer[6] = z gyro msb
buffer[7] = 36   //terminator $
however sometimes i seem to lose a byte over ble such that the next byte received will be less and hence the order is correupted thus making processing rather and unpredictable for a large sample size like 1000000 samples.
how may i ensure that my ble settings are correct such that i ensure to limit this issue.
my code was based of the examples ble_app_uart and ble_app_uart_c for the peripheral and client respectivly.
thank u in advance
  •  i would like to have a similar approach to this, such that i send a packet at a tie will i recive the flag is finished
  • NikTheNordicUser said:
    as previously mentioned i would like to remove the delay such that i make it interrupt based and use the BLE_GATTS_EVT_HVN_TX_COMPLETE event which should ensure no resetting of the mcu .
    As previously mentioned you have to implement the handling for the BLE_GATTS_EVT_HVN_TX_COMPLETE event in the ble_evt_handler. For more detail please see the answer by my colleague Einar in your other ticket. If anything still is unclear on how you should proceed with this, please try to be more specific in your questions.
    Please try to implement this as I have said previously - when a NRF_ERROR_RESOURCES is returned from ble_app_data_send, have the data placed in a buffer and set a flag to indicate that the buffer holds data. Then implement the BLE_GATTS_EVT_HVN_TX_COMPLETE event that checks whether the buffer holds data, and if it does, queues it for transfer.
    Furthermore, the MCU does not have to reset when the NRF_ERROR_RESOURCES error code is returned from the call to ble_nus_data_send. This is the default error handling - you are free to implement specific error handling for your specific application, so that the device is able to handle the error without having to reset.
    but anything i change results in the central not connecting so i am very confused at what is going on and ideally i would like to have the configuration of the fastest transfer
    ideally i would use a throughput of 2 PHy
    i currently have this configuration
    The central determines the connection parameters. The peripheral may only either accept the parameters that the central send, or disconnect. If there is a mismatch between the preference of the central and the peripheral, the peripheral will send a parameter update request. This request can be declined by the central, and the peripheral may then either accept this or disconnect.
    If you with to change your connection parameters you will therefore have to change them on the central side.
    Then, you should also update the preference of the peripheral to match the changes you've made on the central side, or make sure that the peripheral does not disconnect if its preferences are not met.
    If you wish to set the connection interval to a specific number, like 50 ms, then you have to set both _MIN and _MAX to 50 ms, forcing this particular interval.
    To send multiple notification packets back-to-back in the connection event, the event length needs to be configured to be the same as the connection interval, like mentioned directly before the throughput table you've shared a screenshot of. What is your event length?
    Try these two things, and let me know if anything is unclear, or if you encounter any issues.
    Karl
  • Hi , karl , firslt i would like to thank you and i finally solved the error 19 issue , apologies for being unclear at times as i still a student and this project is for my final year project which is due very soon so i may come accross as unclear. now my only 'issue' is speed.. as i would like to make it abit faster.
    my current pheripheral settings are as follows
    are there any other settings that i may be missing. also just to be sure im understanding the connection interval is the connection between central and pheripheral right? and the app_adv_interval is how long the data paket takes? or is that the duration.
    in the peripheral it is set to 6.
    to ensure i understood.. so i need to make the pheripheral and client equal parameters and the client paramters are changes in the sdk config header right?
    also is there a way to measure the sepad of the bluetooth using my oscilloscope. you have previously sugggested to download nrf_sniffer and i attempted to but i honeslty couldnt manage to donwloaded as i never used pyton and got stuck in the very beiging when it said to open the command promt in the folder.
    once again i apologies for the constant messages and larger questions
    Thank you in advance
    No problem at all, I am happy to help! I am also glad to hear that you have resolved the NRF_ERROR_RESOURCES error code being returned from ble_nus_data_send!
    Did you manage to implement the _HVN handling to queue the failed notification as I suggested?
    No need to apologize, I try to understand as best I can. Thank you for the understanding though! :)
    The connection interval is the time between each connection event. A connection event is the event in which the devices actually communicate.
    The BLE protocol is low power because the radio is active as little as possible (among other things). The radio consumes a lot of power, so minimizing the time it is on reduces overall power consumption. So, in BLE the devices agree on specific intervals in which they will both turn on their radios to communicate - so that it does not have to be on all the time, and waste power. By lowering the connection interval you are increasing power consumption, but gain reduced latency and increased throughput.
    Please let me know if any part of this should be unclear.
    With units of 1.25 ms, this translates to a 7.5 ms connection interval window.
    In the screenshot you have shared(which is the peripheral side, so it is still just the peripherals preference) you have configured the minimal connection interval to 20 ms, and the max to 75 ms - so you are not doing what the throughput documentation has told you to do, which is to have the event length be equal to the connection interval length.
    It is important that you read the documentation properly, if you hope to achieve the results it detail.
    The connection event length is the time the devices are allowed to stay talking each connection event. So, in the case that the devices have 'infinite'(for all practical purposes) information to communicate, they will still only communicate back and forth for 7.5 ms each 20th ms (if they use the lowest possible connection interval).
    If you set the event length to be equal to the connection interval length, they may communicate all the way up until the next connection event. This is essential for throughput (but consumes more power).
    The app_ADV_interval is the advertising interval, which specifies how frequently the device will send out advertising packets. Once a connection is established, the advertising stops(if the peripheral device only wants to hold 1 concurrent connection). The advertising interval does not matter for the throughput in your connection.
    The corresponding words are peripheral and central, and client and server, but yes. You need to make sure that the connection parameters are the same on both sides to ensure that the connection will use those specific parameters because the central have to determine them (tell the peripheral what to use), and the peripheral has to accept them (not disconnect).
    This depends. Without complex monitoring you can use the oscilloscope to measure the activity on the antenna (following all the procedures and using required equipment to measure on the antenna without distorting the signals). This will at least tell you that the devices are filling up their connection event with packets back and forth. It is however not an accurate (by any means) way to measure throughput, since you will not know if a packet is being retransmitted, for example.
    To measure throughput you could instead create a setup that always have more data to send, and then see how much data the other device receives in a given timespan. For example, setup a timer that triggers a disconnect (or just logs how much is received) after a given time, starting when the first packet is received. This way, you can much more accurately estimate your throughput.
    However, the method I would recommend you is to setup the sniffer tool that I mentioned earlier, and see the on-air BLE traffic for yourself. This way, you can see exactly what is being sent between the two devices, what connection parameters is being used, how big each packet is, how much of the connection event is spent communication, etc. You would then have the answer to all this, immediately.
    If you still dont feel confident that the sniffer is worthwhile to install you should instead do as I detail above and create a setup to measure the achieved throughput - it is not a lot of work (neither is setting up the sniffer).
    You can open a command prompt in a given folder by writing 'cmd' into the file explorer address line. There is also not a lot that needs doing in python, please see the steps detailed in the nRF Sniffer documentation for details.
    Karl
