Hello Everyone,
I am developing one product using nRF52840 MCU, in this project my master controller is nRF52840 MCU and the host is STM-based MCU.
My goal is to make master and host communicate with each other using UART protocol.
So, here I referred UART peripheral example to study the same from SDK. I just simply ran the code on nRF52840 Dev-kit, And it uses default Tx and Rx pin P0.6 and P0.8. I can see that if type anything on Putty (Serial tool) it displays back.
But as my requirement, I tried to connect UART pins of nRF to the UART pin of the STM board then I am not able to print the data on putty. To get familiar with this from nRF I put data using app_uart_put() function and on the other side means STM board, I get the data using get() function and trying to put () data and display on putty similarly vice versa. But I am unable to print data.
So below attached is the code snippet that I am trying to,
if I just keep app_uart_put and write some data then it stops at the below line,
- NRF_BREAKPOINT_COND;
// On assert the system can only recover with a reset.
main snippet,
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
#if defined (UART_PRESENT)
NRF_UART_BAUDRATE_115200
#else
NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
#ifndef ENABLE_LOOPBACK_TEST
printf("\r\nUART example started.\r\n");
while (true)
uint8_t cr;
//while (app_uart_get(&cr) != NRF_SUCCESS);
while (app_uart_put(cr) != NRF_SUCCESS);
if (cr == 'q' || cr == 'Q')
printf(" \r\nExit!\r\n");
while (true)
// Do nothing.
#else
// This part of the example is just for testing the loopback.
while (true)
uart_loopback_test();
Also, with reference to the driver library, I tried to establish the same below is a snippet,
main.c file
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup uart_example_main main.c
* @ingroup uart_example
* @brief UART Example Application main file.
* This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_drv_uart.h"
//#define ENABLE_LOOPBACK_TEST /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
//static const NRF_UART_Type *p_reg;
const nrf_drv_uart_t UART0 = NRF_DRV_UART_INSTANCE(0);
uint8_t ui8UART0Rx = 0;
void uart0_handle(nrf_drv_uart_event_t *p_event, void *p_contextr)
nrf_drv_uart_rx(&UART0,&ui8UART0Rx,sizeof(ui8UART0Rx));
nrf_drv_uart_tx(&UART0,&ui8UART0Rx,sizeof(ui8UART0Rx));
uint32_t err_code;
nrf_drv_uart_config_t uart0_cfg = NRF_DRV_UART_DEFAULT_CONFIG;
uart0_cfg.baudrate = NRF_UART_BAUDRATE_115200;
// uart0_cfg.hwfc = NRF_UART_HWFC_DISABLED;
// uart0_cfg.interrupt_priority = 0;
// uart0_cfg.parity = NRF_UART_PARITY_EXCLUDED;
err_code = nrf_drv_uart_init(&UART0,&uart0_cfg,uart0_handle);
nrf_drv_uart_rx_enable(&UART0);
sdk_config.h file for the above snippet,
// </e> // </e> // <e> NRFX_UARTE_ENABLED - nrfx_uarte - UARTE peripheral driver //========================================================== #ifndef NRFX_UARTE_ENABLED #define NRFX_UARTE_ENABLED 0 #endif // <o> NRFX_UARTE0_ENABLED - Enable UARTE0 instance #ifndef NRFX_UARTE0_ENABLED #define NRFX_UARTE0_ENABLED 0 #endif // <o> NRFX_UARTE1_ENABLED - Enable UARTE1 instance #ifndef NRFX_UARTE1_ENABLED #define NRFX_UARTE1_ENABLED 0 #endif // <o> NRFX_UARTE_DEFAULT_CONFIG_HWFC - Hardware Flow Control // <0=> Disabled // <1=> Enabled #ifndef NRFX_UARTE_DEFAULT_CONFIG_HWFC #define NRFX_UARTE_DEFAULT_CONFIG_HWFC 0 #endif // <o> NRFX_UARTE_DEFAULT_CONFIG_PARITY - Parity // <0=> Excluded // <14=> Included #ifndef NRFX_UARTE_DEFAULT_CONFIG_PARITY #define NRFX_UARTE_DEFAULT_CONFIG_PARITY 0 #endif // <o> NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE - Default Baudrate // <323584=> 1200 baud // <643072=> 2400 baud // <1290240=> 4800 baud // <2576384=> 9600 baud // <3862528=> 14400 baud // <5152768=> 19200 baud // <7716864=> 28800 baud // <8388608=> 31250 baud // <10289152=> 38400 baud // <15007744=> 56000 baud // <15400960=> 57600 baud // <20615168=> 76800 baud // <30801920=> 115200 baud // <61865984=> 230400 baud // <67108864=> 250000 baud // <121634816=> 460800 baud // <251658240=> 921600 baud // <268435456=> 1000000 baud #ifndef NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE #define NRFX_UARTE_DEFAULT_CONFIG_BAUDRATE 30801920 #endif // <o> NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY #define NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY 6 #endif // <e> NRFX_UARTE_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef NRFX_UARTE_CONFIG_LOG_ENABLED #define NRFX_UARTE_CONFIG_LOG_ENABLED 0 #endif // <o> NRFX_UARTE_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef NRFX_UARTE_CONFIG_LOG_LEVEL #define NRFX_UARTE_CONFIG_LOG_LEVEL 3 #endif // <o> NRFX_UARTE_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_UARTE_CONFIG_INFO_COLOR #define NRFX_UARTE_CONFIG_INFO_COLOR 0 #endif // <o> NRFX_UARTE_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_UARTE_CONFIG_DEBUG_COLOR #define NRFX_UARTE_CONFIG_DEBUG_COLOR 0 #endif // </e> // </e> // <e> NRFX_UART_ENABLED - nrfx_uart - UART peripheral driver //========================================================== #ifndef NRFX_UART_ENABLED #define NRFX_UART_ENABLED 1 #endif // <o> NRFX_UART0_ENABLED - Enable UART0 instance #ifndef NRFX_UART0_ENABLED #define NRFX_UART0_ENABLED 1 #endif // <o> NRFX_UART_DEFAULT_CONFIG_HWFC - Hardware Flow Control // <0=> Disabled // <1=> Enabled #ifndef NRFX_UART_DEFAULT_CONFIG_HWFC #define NRFX_UART_DEFAULT_CONFIG_HWFC 0 #endif // <o> NRFX_UART_DEFAULT_CONFIG_PARITY - Parity // <0=> Excluded // <14=> Included #ifndef NRFX_UART_DEFAULT_CONFIG_PARITY #define NRFX_UART_DEFAULT_CONFIG_PARITY 0 #endif // <o> NRFX_UART_DEFAULT_CONFIG_BAUDRATE - Default Baudrate // <323584=> 1200 baud // <643072=> 2400 baud // <1290240=> 4800 baud // <2576384=> 9600 baud // <3866624=> 14400 baud // <5152768=> 19200 baud // <7729152=> 28800 baud // <8388608=> 31250 baud // <10309632=> 38400 baud // <15007744=> 56000 baud // <15462400=> 57600 baud // <20615168=> 76800 baud // <30924800=> 115200 baud // <61845504=> 230400 baud // <67108864=> 250000 baud // <123695104=> 460800 baud // <247386112=> 921600 baud // <268435456=> 1000000 baud #ifndef NRFX_UART_DEFAULT_CONFIG_BAUDRATE #define NRFX_UART_DEFAULT_CONFIG_BAUDRATE 30924800 #endif // <o> NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY #define NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY 6 #endif // <e> NRFX_UART_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef NRFX_UART_CONFIG_LOG_ENABLED #define NRFX_UART_CONFIG_LOG_ENABLED 0 #endif // <o> NRFX_UART_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef NRFX_UART_CONFIG_LOG_LEVEL #define NRFX_UART_CONFIG_LOG_LEVEL 3 #endif // <o> NRFX_UART_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_UART_CONFIG_INFO_COLOR #define NRFX_UART_CONFIG_INFO_COLOR 0 #endif // <o> NRFX_UART_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_UART_CONFIG_DEBUG_COLOR #define NRFX_UART_CONFIG_DEBUG_COLOR 0 #endif // </e> // </e> // <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver - legacy layer //========================================================== #ifndef UART_ENABLED #define UART_ENABLED 1 #endif // <o> UART_DEFAULT_CONFIG_HWFC - Hardware Flow Control // <0=> Disabled // <1=> Enabled #ifndef UART_DEFAULT_CONFIG_HWFC #define UART_DEFAULT_CONFIG_HWFC 0 #endif // <o> UART_DEFAULT_CONFIG_PARITY - Parity // <0=> Excluded // <14=> Included #ifndef UART_DEFAULT_CONFIG_PARITY #define UART_DEFAULT_CONFIG_PARITY 0 #endif // <o> UART_DEFAULT_CONFIG_BAUDRATE - Default Baudrate // <323584=> 1200 baud // <643072=> 2400 baud // <1290240=> 4800 baud // <2576384=> 9600 baud // <3862528=> 14400 baud // <5152768=> 19200 baud // <7716864=> 28800 baud // <10289152=> 38400 baud // <15400960=> 57600 baud // <20615168=> 76800 baud // <30801920=> 115200 baud // <61865984=> 230400 baud // <67108864=> 250000 baud // <121634816=> 460800 baud // <251658240=> 921600 baud // <268435456=> 1000000 baud #ifndef UART_DEFAULT_CONFIG_BAUDRATE #define UART_DEFAULT_CONFIG_BAUDRATE 30801920 #endif // <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 6 #endif // <q> UART_EASY_DMA_SUPPORT - Driver supporting EasyDMA #ifndef UART_EASY_DMA_SUPPORT #define UART_EASY_DMA_SUPPORT 1 #endif // <q> UART_LEGACY_SUPPORT - Driver supporting Legacy mode #ifndef UART_LEGACY_SUPPORT #define UART_LEGACY_SUPPORT 1 #endif // <e> UART0_ENABLED - Enable UART0 instance //========================================================== #ifndef UART0_ENABLED #define UART0_ENABLED 1 #endif // <q> UART0_CONFIG_USE_EASY_DMA - Default setting for using EasyDMA #ifndef UART0_CONFIG_USE_EASY_DMA #define UART0_CONFIG_USE_EASY_DMA 1 #endif // </e> // <e> UART1_ENABLED - Enable UART1 instance //========================================================== #ifndef UART1_ENABLED #define UART1_ENABLED 0 #endif // </e>
Let me know what I did wrong here.
And also, I would perform the UART operation using other GPIO pins, can anyone suggest to me how to the configuration for this.
Thanks and Regards
Rohit R
