Scanning for Bluetooth 5 device using nRF52840 dongle
I have a situation where a customer needs to DFU some nRF52840 custom boards that we shipped. The firmware that I wrote used extended advertising and thus appears as a Bluetooth 5.0 device when scanned by my BLE 5 enabled smartphone.
The problem is that my customer does not wish to purchase a smartphone with BLE 5 to perform the DFU, so I supplied him with an nrf52840 dongle and instructed him to scan for the devices with the nRFConnect app for WIndows. However, the devices failed to appear on the scan list. I performed the same action on my side and discovered the same thing. I could scan for BLE 4.2 devices but not BLE 5.0 ones. Is this a limitation of the connectivity firmware or the dongle?
  • I was not aware that was the case for nRF Connect for Desktop. I'll report it to our nRF Connect for Desktop team.
    I have not tested this either on nRF Connect for Desktop, or nrfutil, but perhaps you can try using nrfutil to transfer your packet? It may not work if nRF Connect for Desktop doesn't, but it is worth a shot. You don't have to create a second DFU image. Just use the command:
    nrfutil dfu ble -pkg <dfu_image>.zip -ic NRF52 -p (COM port) -n <advertising name> -f
    NB: you may need to call this two times, because the first time it will flash the dongle with the connectivity firmware because of the -f flag. Flashing this firmware may change the COM port, so you may need to call it again with the new COM port. This time you may skip the "-f" flag.
    If you don't have an advertising name, you can use the address of the device by using -a instead of -n. It may also be that nrfutil is able to connect to an address, but not the name if the device is using extended advertisements.
    If that doesn't work, I am afraid there isn't much I can do. I can tell the developers, but I have no idea how long it will take to add this feature to nRF Connect (if it will be added).
    Can you please tell me what sort of extended advertising you are using?
    I assume your device doesn't have a button, and that the bootloader is set up to enter DFU mode when this button is held down on reset? By default, the bootloader project is configured to enter DFU mode if pin 25 is grounded while resetting. Please check the NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN and NRF_BL_DFU_ENTER_METHOD_BUTTON definitions in sdk_config.h of your bootloader project.
    The last option, as I see it is to write a custom application that your customer can flash to the dongle that will look for your device, connect to it and perform the DFU.
    Is there some way that I can reproduce this? Can you modify the application to run on an nRF52DK/nRF52840DK? At least the advertisement part, so that I can check whether I can perform the DFU using nrfutil? And confirm that it doesn't work on nRF Connect for Desktop?
  • I have just tested nrfutil and here are the results:
    First attempt with -f flag
    Second attempt without after connectivity firmware was flashed.
    The sample device was advertising according to my phone's nRFConnect app.
    I am hesitant to recommend nrfutil's use to my client as they aren't technically inclined and prefer a GUI.
    These are my some of my advertising params:
        init.config.ble_adv_directed_enabled            = true;
    	init.config.ble_adv_directed_interval           = 0x0200;
    	init.config.ble_adv_directed_timeout			= 10;
    	init.config.ble_adv_fast_enabled                = true;
    	init.config.ble_adv_fast_interval               = 0x0200;
    	init.config.ble_adv_fast_timeout                = 0;
    	init.evt_handler								= NULL;
    	init.config.ble_adv_primary_phy = ATTR_MESH_BLE_GAP_PHY;   // Default 1M
    	init.config.ble_adv_secondary_phy = ATTR_MESH_BLE_GAP_PHY; // Default 1M
    	init.config.ble_adv_extended_enabled = true;
    	m_advertising.adv_data.scan_rsp_data.p_data = NULL;
    	m_advertising.adv_data.scan_rsp_data.len = 0;
    Here you go:
    #ifndef NRF_BL_DFU_ENTER_METHOD_BUTTON
    #define NRF_BL_DFU_ENTER_METHOD_BUTTON 1
    #ifndef NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN
    #define NRF_BL_DFU_ENTER_METHOD_BUTTON_PIN 25
    I am considering allocating some development time to do this, but it shall be my last resort as I'm busy developing other products at the moment.
    Here is a test hex file that I use, it's for a nRF52840 device. It advertises as LynxMesh and in DFU mode it advertises as X12Dfu. If you need the passkey to bond with it and perform the DFU, for security purposes I request that you pm me.
    The application and bootloader versions are set to 0. Softdevice is included (s140 7.2.0). Let me know how it goes.
    test_combined.hex
  • Yes, it looks like nrfutil can't find it either.
    Is pin 25 connected to anything? A button? Is there a way for the customer to short P0.25 to GND while resetting the device? I tested this on a DK with your FW, and that puts it in DFU mode. Then I can use nrfutil or nRF Connect for Desktop:
    Please note that this increments the address by 1. My DK typically has the address EF:1D:3E:56:18:9A, but it is changed to EF:1D:3E:56:18:9B when in DFU mode.
    If he manages to put it in DFU mode, you might want to consider adding an advertisement packet every now and then that doesn't use advertising extensions, so that most phones can find it.
    BR,
    Edvin
  • Unfortunately a space on the PCB was provisioned but a button was not mounted on the production version of the device. The devices tend to be installed in places that are out of reach for the most part so we cut some costs there. I proceeded with a fully buttonless DFU implementation instead.
    I will consider implementing your suggestion with additional advertising packets but it would be better for the connectivity firmware to be updated instead, because I can forsee that other developers may inadvertently run into the same problem.
    Thanks a lot for your help,
    Arif
