Receiving only one char through uart interrupt in Serial_uartes
Hi there,
I'm using nrf52840 DK and Custom board, SDK 15.1.0, Segger Embedded Studio(SES v5.20)
my issue is when i receive data from uart interrupt based on serial uartes example, i can only receive one char at a time. that means if i store that data in a char variable and should add to the char array then its works fine, but i want to read the complete data on single shot, so how can i do that,? i'm i doing anything wrong.
void GSM_InterruptHandler(nrf_serial_t const *p_serial, nrf_serial_event_t event)
static uint8_t index1=0;
char bb;
switch (event)
    case NRF_SERIAL_EVENT_RX_DATA:
      if((nrf_serial_read(&serial0_uarte, &bb, sizeof(bb), &readed_size, 500))==NRF_SUCCESS)
      gsm_d.RxBuf[index1++] = bb;
      rx_done = true;
    case NRF_SERIAL_EVENT_TX_DONE:
      tx_done = true;
    case NRF_SERIAL_EVENT_DRV_ERR:
      APP_ERROR_CHECK(nrf_serial_uninit(&serial0_uarte));
      APP_ERROR_CHECK(nrf_serial_init(&serial0_uarte, &m_uarte1_drv_config, &serial0_config));
    case NRF_SERIAL_EVENT_FIFO_ERR:
Im reading the rx buff like this, but its triggers multiple times for every rx event, and i need like this
      if((nrf_serial_read(&serial0_uarte, &gsm_d.RxBuf, sizeof(gsm_d.RxBuf), &readed_size, NRF_SERIAL_MAX_TIMEOUT))==NRF_SUCCESS)
      rx_done = true;
so please help me
Thanks in advance
Best Regards
Raj
  • I could not take a look at this before the easter holiday, i will take a look at this early next week when i come back to office.
  • Hi susheel,
    ok we can wait till next weeek, but please make sure to complete ASAP
    Best Regards,
    Raj
  • Hi Rajender, I am back from vacation and will look into this tomorrow. I suspect that the issue is that GSM_InterruptHandler might have higher priority than UART interrupt and is triggering faster than the byte received inthe UART RX FIFO. Or the uart traffic is slower than the frequency of the GSM interrupt frequency?
    if none is the case, then we need to debug as to why you are not able to receive multiple received bytes from FIFO.
    Before i can try to dig more into the nrf_serial library, could you tell me
    1) GSM interrupt frequency
    2) UART characters on the RX line in single transaction (logic analyzer snapshots would be helful)
    3) UART and GSM interrupt priority
  • Hi Susheel,
    1) GSM Interrupt occurs when we request the data from gsm like sending any AT command to the GSM (most likely around 1 second)
    2) RX Characters on the RX line --> i dont have the Logic analyser(CRO) in with me but i can say minimum RX characters are "OK"-2 characters,  MAX characters are around 255 characters.
    3)If we talk about any interrupt priority, i have not changed any interrupt priority its default as the example only (Mostly Priority 7)
    I am not sure my answers are correct as you expected but please help and correct me.
    Best Regards
    Raj.
  • Hi susheel,
    I know i have given very late replay last time, im sory for that but i need to solve this issue ASAP, this issue effecting the complete project development so please replay soon.
    Please understand the urgency.....
    Best Regards,
    Raj
