ubuntu host PC rs232 to usb:
Target board nrf9160:
get log from /dev/ttyACM0 change to /dev/ttyUSB0
PC Tx ---- target rx p0.00
PC Rx ---- target tx p0.01
ubuntu PC host:
the /dev/ttyUSB0 will receive from nrf9160
SEGGER Embedded Studio for ARM
Release 5.34a Build 2021011401.44914
Nordic Edition
Linux x64
1.
Hardware support for boardname:
nrf9160dk_nrf9160ns -> Sw10 -> NRF91
2.
nrf9160dk_nrf9160ns:
~/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig
#add in last line
CONFIG_DEBUG=y
the CONFIG_DEBUG=y help you trace into ~/ncs/zephyr/drivers/serial/uart_nrfx_uarte.c
3.
create file nrf9160dk_nrf9160ns.overlay in ~/ncs/zephyr/samples/hello_world
add follows setting
&uart0 {
current-speed = <115200>;
status = "okay";
tx-pin = <1>;
rx-pin = <0>;
rts-pin = <0xFFFFFFFF>;
cts-pin = <0xFFFFFFFF>;
&uart1 {
status = "okay";
tx-pin = <27>;
rx-pin = <26>;
4.
add ${BOARD}.overlay in ~/ncs/zephyr/samples/hello_world/CMakeLists.txt
cmake_minimum_required(VERSION 3.13.1)
#add this line
set(DTC_OVERLAY_FILE "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(hello_world)
target_sources(app PRIVATE src/main.c)
(you do not need to change ~/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts)
(overlay file will do it)
5.
SEGGER Embedded Studio open hello_world project
BoardName: nrf9160dk_nrf9160ns
6.
/root/ncs/zephyr/samples/hello_world/build_nrf9160dk_nrf9160ns/zephyr/zephyr.dts
there are uart0 and uart1 setting same as overlay file
uart0: uart@8000 {
reg = < 0x8000 0x1000 >;
interrupts = < 0x8 0x1 >;
status = "okay";
label = "UART_0";
current-speed = < 0x1c200 >;
tx-pin = < 0x1 >;
rx-pin = < 0x0 >;
rts-pin = < 0xffffffff >;
cts-pin = < 0xffffffff >;
uart1: uart@9000 {
reg = < 0x9000 0x1000 >;
interrupts = < 0x9 0x1 >;
status = "okay";
label = "UART_1";
tx-pin = < 0x1b >;
rx-pin = < 0x1a >;
7. set breakpoint
switch (cfg->flow_ctrl) { //------------------>set breakpoint at this can see it use CTS RTC or not
case UART_CFG_FLOW_CTRL_NONE:
uarte_cfg.hwfc = NRF_UARTE_HWFC_DISABLED;
case UART_CFG_FLOW_CTRL_RTS_CTS:
if (get_dev_config(dev)->rts_cts_pins_set) {
uarte_cfg.hwfc = NRF_UARTE_HWFC_ENABLED;
} else {
return -ENOTSUP;
return -ENOTSUP;
All done and successfully
