I try to obtain from IMSI number for a GATT Characteristic. However, by using AT+CIMI it returns valid result only after network connection established.
Could you please let me know how to read IMSI number from SIM card?
IIRC, it isn't stored on the SIM - it's an association that's managed within the network ?
Thank you for your response.
I am not sure about it. Since I can read IMEI number, I thought IMSI can be readable as well.
IMEI = International Mobile Equipment Identity (or Identifier); it is embedded in the module - not the SIM.
A different SIM could be inserted, and the IMEI would remain the same.
IMSI = International Mobile Subscriber Identity (or Identifier); it identifies the service "user".
AT+CCID should give you the SIM card serial number (ICCID) - which the network associates with the IMSI
I would like to confirm whether there is any conditions in order to acquire IMSI.
For example, when I use AT+CIMI to acquire IMSI, it returns valid result only when the network connection is established, which means acquisition of IMSI requires a network connection.
Please confirm.
Query the SIM just after enabling the modem (CFUN=1), as the power to the SIM card is normally turned off to ensure low power consumption, especially in sleep modes (eDRX/PSM). Alternatively, you can issue AT+CFUN=41.
Håkon
