Hello ,
NRF52840
sdk 15.2
In my application using ble central example in nrf52840 , i am able to write data in led characteristics and getting notification on HVX using Button cccd handle and now i m trying to get notification data on led handle instead of button handle , is this possible to get notification on led handle from peripheral to central ?i have changed to led characteristics as below
static void on_hvx(ble_lbs_c_t * p_ble_lbs_c, ble_evt_t const * p_ble_evt)
// Check if the event is on the link for this instance
if (p_ble_lbs_c->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
return;
// Check if this is a Button notification.
// if (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_lbs_c->peer_lbs_db.button_handle)
(p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_lbs_c->peer_lbs_db.led_handle)
// if (p_ble_evt->evt.gattc_evt.params.hvx.len == 1)
ble_lbs_c_evt_t ble_lbs_c_evt;
ble_lbs_c_evt.evt_type = BLE_LBS_C_EVT_DISCOVERY_COMPLETE;
ble_lbs_c_evt.conn_handle = p_ble_lbs_c->conn_handle;
ble_lbs_c_evt.params.button.button_state = p_ble_evt->evt.gattc_evt.params.hvx.data[0];
// p_ble_lbs_c->evt_handler(p_ble_lbs_c, &ble_lbs_c_evt);
/**@brief Function for handling Disconnected event received from the SoftDevice.
* @details This function check if the disconnect event is happening on the link
* associated with the current instance of the module, if so it will set its
* conn_handle to invalid.
* @param[in] p_ble_lbs_c Pointer to the Led Button Client structure.
* @param[in] p_ble_evt Pointer to the BLE event received.
static void on_disconnected(ble_lbs_c_t * p_ble_lbs_c, ble_evt_t const * p_ble_evt)
if (p_ble_lbs_c->conn_handle == p_ble_evt->evt.gap_evt.conn_handle)
p_ble_lbs_c->conn_handle = BLE_CONN_HANDLE_INVALID;
p_ble_lbs_c->peer_lbs_db.button_cccd_handle = BLE_GATT_HANDLE_INVALID;
p_ble_lbs_c->peer_lbs_db.button_handle = BLE_GATT_HANDLE_INVALID;
p_ble_lbs_c->peer_lbs_db.led_handle = BLE_GATT_HANDLE_INVALID;
void ble_lbs_on_db_disc_evt(ble_lbs_c_t * p_ble_lbs_c, ble_db_discovery_evt_t const * p_evt)
// Check if the Led Button Service was discovered.
if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
p_evt->params.discovered_db.srv_uuid.uuid == LBS_UUID_SERVICE &&
p_evt->params.discovered_db.srv_uuid.type == p_ble_lbs_c->uuid_type)
ble_lbs_c_evt_t evt;
evt.conn_handle = p_evt->conn_handle;
for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
const ble_gatt_db_char_t * p_char = &(p_evt->params.discovered_db.charateristics[i]);
switch (p_char->characteristic.uuid.uuid)
case LBS_UUID_LED_CHAR:
evt.params.peer_db.led_handle = p_char->characteristic.handle_value;
case LBS_UUID_BUTTON_CHAR:
evt.params.peer_db.button_handle = p_char->characteristic.handle_value;
evt.params.peer_db.button_cccd_handle = p_char->cccd_handle;
NRF_LOG_DEBUG("Led Button Service discovered at peer.");
//If the instance has been assigned prior to db_discovery, assign the db_handles
if (p_ble_lbs_c->conn_handle != BLE_CONN_HANDLE_INVALID)
if ((p_ble_lbs_c->peer_lbs_db.led_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_lbs_c->peer_lbs_db.button_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_lbs_c->peer_lbs_db.button_cccd_handle == BLE_GATT_HANDLE_INVALID))
p_ble_lbs_c->peer_lbs_db = evt.params.peer_db;
p_ble_lbs_c->evt_handler(p_ble_lbs_c, &evt);
uint32_t ble_lbs_c_init(ble_lbs_c_t * p_ble_lbs_c, ble_lbs_c_init_t * p_ble_lbs_c_init)
uint32_t err_code;
ble_uuid_t lbs_uuid;
ble_uuid128_t lbs_base_uuid = {LBS_UUID_BASE};
VERIFY_PARAM_NOT_NULL(p_ble_lbs_c);
VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init);
VERIFY_PARAM_NOT_NULL(p_ble_lbs_c_init->evt_handler);
p_ble_lbs_c->evt_handler = p_ble_lbs_c_init->evt_handler;
err_code = sd_ble_uuid_vs_add(&lbs_base_uuid, &p_ble_lbs_c->uuid_type);
if (err_code != NRF_SUCCESS)
return err_code;
VERIFY_SUCCESS(err_code);
lbs_uuid.type = p_ble_lbs_c->uuid_type;
lbs_uuid.uuid = LBS_UUID_SERVICE;
return ble_db_discovery_evt_register(&lbs_uuid);
void ble_lbs_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
if ((p_context == NULL) || (p_ble_evt == NULL))
return;
ble_lbs_c_t * p_ble_lbs_c = (ble_lbs_c_t *)p_context;
case BLE_GATTC_EVT_HVX:
on_hvx(p_ble_lbs_c, p_ble_evt);
case BLE_GATTC_EVT_WRITE_RSP:
// NRF_LOG_INFO("Write resp");
on_write_rsp(p_ble_lbs_c, p_ble_evt);
on_disconnected(p_ble_lbs_c, p_ble_evt);
/**@brief Function for configuring the CCCD.
* @param[in] conn_handle The connection handle on which to configure the CCCD.
* @param[in] handle_cccd The handle of the CCCD to be configured.
* @param[in] enable Whether to enable or disable the CCCD.
* @return NRF_SUCCESS if the CCCD configure was successfully sent to the peer.
static uint32_t cccd_configure(uint16_t conn_handle, uint16_t handle_cccd, bool enable)
// NRF_LOG_INFO("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d",
// handle_cccd,conn_handle);
tx_message_t * p_msg;
uint16_t cccd_val = enable ? BLE_GATT_HVX_NOTIFICATION : 0;
p_msg = &m_tx_buffer[m_tx_insert_index++];
m_tx_insert_index &= TX_BUFFER_MASK;
p_msg->req.write_req.gattc_params.handle = handle_cccd;
p_msg->req.write_req.gattc_params.len = WRITE_MESSAGE_LENGTH;
p_msg->req.write_req.gattc_params.p_value = p_msg->req.write_req.gattc_value;
p_msg->req.write_req.gattc_params.offset = 0;
p_msg->req.write_req.gattc_params.write_op = BLE_GATT_OP_WRITE_REQ;
p_msg->req.write_req.gattc_value[0] = LSB_16(cccd_val);
p_msg->req.write_req.gattc_value[1] = MSB_16(cccd_val);
p_msg->conn_handle = conn_handle;
p_msg->type = WRITE_REQ;
tx_buffer_process();
return NRF_SUCCESS;
uint32_t ble_lbs_c_button_notif_enable(ble_lbs_c_t * p_ble_lbs_c)
if (p_ble_lbs_c->conn_handle == BLE_CONN_HANDLE_INVALID)
printf("invalid");
return cccd_configure(p_ble_lbs_c->conn_handle,
//p_ble_lbs_c->peer_lbs_db.button_cccd_handle,
// p_ble_lbs_c->peer_lbs_db.led_handle,
true);
// return NRF_SUCCESS;
