Reduce LEDs consumption Thingy91 - Asset tracker
I am trying to reduce the consumption of my Thingy91 device in idle mode. I am working with NCSv1.3 and the example asset_tracker.
I am currently registering 0.60mA but if I disable the LEDs I get a 0.10mA idle consumption.
I would like to be able to keep the LEDs on but reduce their consumption.
How could I lower the brightness power of the LEDs?
How can I reduce the frequency at which the LEDs turn on?
Thanks!
Raquel.
  • Hi!
    Thanks for reaching out! A good place to start would be to investigate how the LEDs are used by the asset_tracker, specifically the UI module and the led_pwm code. I suggest experimenting a bit with the defines in ui.h, for example by setting UI_LED_MAX to a lower value. You can also find the defines UI_LED_ON_PERIOD_NORMAL and UI_LED_OFF_PERIOD_NORMAL here, that can be used to limit how long the LEDs stay on/off. If you want even more control you can use the led_pwm code.
    I'd also suggest moving to NCS version 1.4.x or 1.5.x if possible.
    Carl Richard
  • Hi Carl,
    It was just what I was looking for. I have managed to reduce consumption by adjusting
    UI_LED_MAX
    Thank you very much!!
