We're working on a product that is able to store around 400uC of charge (two 220uF capacitors). There is a constant input of 21 uA minimum coming from a small solar panel. We are using the secure_bootloader example
When testing the DFU, the prevalidation check will take around 600uC of charge in 125 ms. We're able to get normal operation if we comment out prevalidation check (lines 548-555 of file nrf_dfu_validation.c) the device is able to recieve the firmware binary. However, once the DFU gets completes transmission of the binary it will take too much power again during the postvalidation check.
Commenting out postvalidation check (lines 563-569 of nrf_dfu_req_handler) allows the DFU to state it was "complete" but it will fail to boot into the application and advertise as dfutarg.
Eventually we are thinking of changing the uECC.c file to allow for a delay as it is processing through uECC_verify function in order to reduce the average current usage and allow the solar panel to recharge the capacitors.
Is there a way to disable these validation checks?
