I2C gets stuck with -EBUSY if i2c_* function calls timeout on zephyr (NCS) for nRF52840
To reproduce this problemm Ive added a device to the I2C that does not respond to a read command.
The `i2c_read` call first returns `-EOI` (-5) and for every other i2c funcion calls it will return `-EBUSY` (-16).
Apparently it locks the i2c subsystem, a `sys_reboot` makes the i2c BUS available again.
I wonder if this is a known issue, and if there is a way of recovering the i2c subsystem? `i2c_recover_bus` is useless for this effect.
a similar issues were posted here:
https://devzone.nordicsemi.com/f/nordic-q-a/70481/what-means-errno--16-for-nrf52832/289628
- https://devzone.nordicsemi.com/f/nordic-q-a/66928/zephyr-i2c-locked-into-ebusy
  • If I understand it correctly you have tried both twim and twi. Are you able to try slightly older versions of ncs for test (e.g. 1.4.0, and possible also even 1.3)?
    Kenneth
  • I can confirm that the behaviour is the same for v1.4.0.
    For v1.3.0, it hangs forever on read. I guess this is due to some change/addition of a timeout code?
    The following is a short code to test (considering you have a device on the other end that doesn't write back):
    uint8_t r_buff;
    uint8_t w_buff = 0x02;
    const struct device *i2c1_dev;
    i2c1_dev = device_get_binding("I2C_1");
    while (true)
    	r_buff = 0;
    	// Write something to device at 0x05
    	ret = i2c_write(i2c1_dev, &w_buff, 1, 0x05);
    	if(ret != 0) {
    		printk("error write: %d\n", ret);
    	// Read byte from device at 0x05, this is where it is problematic
    	// if the device doesnt write back
    	ret = i2c_read(i2c1_dev, &r_buff, 1, 0x05);
    	if(ret != 0) {
    		printk("error read: %d\n", ret);
    	printk("r_buff: %u\n", r_buff);
    	k_msleep(2000);
    So far I've noticed that the bus gets stuck forever if:
    • i2c_read times out
    • i2c SDA and SCL are shorted for a short amount of time
    My main problem is not being able to recover the bus, If I was able to do that in runtime without resetting I could have that workaround. Is there any way I can do this in the meanwhile?
  • I assume you can try to do some low level calls, like:
    NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
    NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos;
    Assuming you are using TWI1.
    You can even add a power cycle of the TWI1 peripheral by adding the following between the two lines above:
    *(volatile uint32_t *)0x40004FFC = 0;
    *(volatile uint32_t *)0x40004FFC;
    *(volatile uint32_t *)0x40004FFC = 1;
    I can't see how this should not reset TWI1 instance and release the pins.
    If you are using TWI0 you should use address 0x40003FFC instead.
    But I am not sure how the zephyr driver will like that.
    Kenneth
  • Just tried that after I receiving a -EBUSY error, no difference from the i2c api perspective afterwards...
    It will apparently returns -EBUSY because the driver gets stuck with NRFX_ERROR_BUSY from the
    nrfx_twi_xfer call from the line I previously mentioned.
    How will Nordic proceed with this issue? Will this be filled in as a bug?
  • I can add it as a bug internally, I am wondering does the suggestion release the pins? If the pins return to normal pull-up state, then the next step would be to make the driver also return to "default" state.
    Kenneth
