How to map nrf_cli to custom UARTE
I am using the radio test example code where in the interface is through cli. Our custom board has a serial port in UARTE1 instance
how do I configure the cli to work with UARTE1 instance?
What are the configurations and initializations to be done for this?
  • It looks to me to be handled in NRF_CLI_UART_DEF(), the second parameter is the UART instance (change from '0' to '1'). Also set #define UART1_ENABLED 1 in sdk_config.h.
    But not sure if I understand what you mean by "Our custom board has a serial port in UARTE1 instance", you can modify the pins for UARTE0, there is no need to change from UARTE0 to UARTE1 just because you use different pins.
    Kenneth
