Using ring buffer to store 16 bits ADC data
Ring buffer operates on uint8_t , but I would like to use ring buffer to store 16 bits ADC data.  What is the simplest  solution?
Converting 16 bits data into 8 bits, store the data into ring buffer, get data back from ring buffer and then convert the data back to 16 bits, seems like a lot of work.
Is it possible to modify the ring buffer to use 16 bits instead of 8 bit for data storage?   Is it simpler to just write a simple ring buffer;  do you have an example?
I just need a simple ring buffer to store certain amount of ADC data before I process the data.   A simple buffer would not work.
    That depends, how advanced do you need the buffer? The simplest implementation of a ring buffer takes a very short time to implement, and there are multiple implementations and guides written about this.
    However, typecasting the 16 bit data to two 8 bit ones, and having the ring buffer skip twice the memory distance, also shouldnt take too long to implement - but this will also warrant some testing of the modified library, to check that the modification did you break anything else.
    You could of course modify the ring buffer library, but you would need to test and verify that you changes makes sense and achieve the desired functionality without breaking the library in any other unexpected way. Its hard for me to gauge which of these will be the best for you, since I neither know the required ring-buffer functionality, nor your programming skill level and familiarity with the existing library.
    Please elaborate on what you mean by this, do you need a simple ring buffer or not?
    If you just need a simple ring buffer I would suggest making your own implementation of this, as this saves you the time it takes to get into the existing library's source code, and testing of the modified version.
    Please do not hesitate to ask if any part of my answer is unclear, or if you have any other issues or questions!
    Karl
  • I need to put in 640 bytes into the ring buffer at a time and take out 1400 bytes once the buffer exceeds 1400 bytes.  Do you have any example?
    Also do you have an example of typecasting the 16 bit data into 8 bit, store the data in ring buffer, take out the date and then typecast the data back to 16 bits.
    I am a beginner in C.
    Thank You
    No problem at all! :)
    If so, I would suggest that you look into creating the ring-buffer yourself (or finding an existing 16 bit ring buffer implementation) instead of modifying the 8bit ring buffer from the SDK. I recommend this because you will have much more control over what is actually happening in your own implementation, and so that you may avoid the testing of the modified ring buffer to ensure that you did not break it.
    I do not have any other implementation of a ring buffer other than the one we provide in the SDK, unfortunately.
    A brief google search yielded this article on how to implement a simple ring buffer in C, that might be helpful for you to take a look at.
    Unfortunately I do not have an example that showcases this, but it follows the regular syntax for typecasting in C.
    However, typecasting between uint8_t and uint16_t may prove cumbersome due to endianness in C.
    Are you familiar with bit shifting? Bit shifting would be the easiest way for you to do this.
    It is an important concept in embedded C programming. To avoid the edianness pitfalls, you should instead use bit shifting to convert your uint8_t to uint16_t, and reverse. A brief google search yielded this tutorial, which might be useful for you to have a look at. This way, you can create a function for merging two uint8_t to an uint16_t, and a function for the opposite.
    Please do not hesitate to ask if any part of my comment is unclear, or if you have any other issues or questions!
    Karl
