sometimes PWM signal is reversed .
Hi Nordics!
I am using app_pwm.c file in SDK 8.1, and when I use it with softdevice(advertising or data transfer event), sometimes pwm signal is reversed.
I guess, reversed signal's reason is the BLE interrupt. Because this problem is not occurred, when I don't use softdevice ( advertising or data transfer event)
And I need your advice for overcome this problem.
These are my development environment.
SDK 8.1
SD 8.0
nRF51822 AA G0
custom board
Timer1- 2channels
Timer2-1 channel.
3 PWM channels - Red led, Green led, Blue led.
first, I used app_pwm library. (100Hz )
static void pwm_init(void)
    ret_code_t err_code;
    /* 2-channel PWM, 100Hz, output on LED pins. */
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(10000L, GPIO_LED_RED, GPIO_LED_GREEN);
    app_pwm_config_t pwm2_cfg = APP_PWM_DEFAULT_CONFIG_1CH(10000L, GPIO_LED_BLUE);
    /* Set the polarity of the channel. */
    pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
    pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
    pwm2_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
    /* Initialize and enable PWM. */
    err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_1_ready_callback);
    err_code = app_pwm_init(&PWM2,&pwm2_cfg,pwm_2_ready_callback);
    app_pwm_enable(&PWM1);
    app_pwm_enable(&PWM2);
void pwm_1_ready_callback(uint32_t pwm_id)
    pwm_1_ready_flag = true;
void pwm_2_ready_callback(uint32_t pwm_id)
    pwm_2_ready_flag = true;
second, I set the pwm chanel duty by using below code.
(in this function, I didn't wait callback. I just keep trying until PWM is ready)
static void color_setting(uint8_t red, uint8_t green, uint8_t blue)
    color_red=red;
    color_green=green;
    color_blue=blue;
    pwm_1_ready_flag = false;
    pwm_2_ready_flag = false;
    /* Set the duty cycle - keep trying until PWM is ready... */
    while (app_pwm_channel_duty_set(&PWM1, 0, (uint32_t)(sin_table[color_red]/2.55)) == NRF_ERROR_BUSY);
    while (app_pwm_channel_duty_set(&PWM1, 1, (uint32_t)(sin_table[color_green]/2.55)) == NRF_ERROR_BUSY);
    while (app_pwm_channel_duty_set(&PWM2, 0, (uint32_t)(sin_table[color_blue]/2.55)) == NRF_ERROR_BUSY);
    /* ... or wait for callback. */
   //    while(!pwm_1_ready_flag);
sin_table's value is from 0 to 255. so I divided it by 2.55
And this color_setting function is called in app_timer call_back function.
my app timer's interval is 40ms.
In other words, PWM values is changed in every 40ms, and it repeat 0~100 value.
This "PWM signal reversed" issue is not appeared, when I don't use softDevice.
Is there any idea for avoiding this problem??
This problem is critical issue on my project.
Please help me.
Thanks.
  • Yes, the 110 Softdevice. The connection interval is between 20 and 75 ms. My use case is a bit different possibly... I connect to a iOS device and stay connected for awhile. Then it might not connect for days, all the while the PWM is constantly changing. I am updating the duty now every 4ms, nearly constantly. My period is 64us, or 15.625kHz. I was having almost constant inversions if I would change the duty value by only one clock tick. I changed the code so that it would only update if it the new duty value was 2 ticks away and that is working fine, no issues that I have seen. I am using the updated PWM library included above, with one additional function that lets me set the duty from 0-512 because I need the resolution. I want to set it from 0-1024, but at my frequency I would need to set it at 1 clock tick intervals, and that isn't working. Hope that helps.
  • I set it to a constant duty cycle of 25%. Don't change it constant 25% and inversions still happen. Very infrequently, but they do.
  • I was having the same issue with SDK 9.0.0: on power-up the PWM polarity would sometimes flip. Based on my previous experience finding a bug in the PWM library, I decided to set values to all of the fields in the app_pwm_cb_t struct created by APP_PWM_INSTANCE() (they aren't initialized right away in the code). As far as I can tell, the problem went away entirely.
    My workaround looks like this:
    APP_PWM_INSTANCE(PWM1, 1);
    PWM1.p_cb->channels_cb[0].gpio_pin = 0;
    PWM1.p_cb->channels_cb[0].pulsewidth = 0x00000000;
    PWM1.p_cb->channels_cb[0].ppi_channels[0] = NRF_PPI_CHANNEL26;
    PWM1.p_cb->channels_cb[0].ppi_channels[1] = NRF_PPI_CHANNEL27;
    PWM1.p_cb->channels_cb[0].polarity = APP_PWM_POLARITY_ACTIVE_LOW ;
    PWM1.p_cb->channels_cb[0].initialized = 0;
    PWM1.p_cb->channels_cb[1].gpio_pin = 1;
    PWM1.p_cb->channels_cb[1].pulsewidth = 0x00000000;
    PWM1.p_cb->channels_cb[1].ppi_channels[0] = NRF_PPI_CHANNEL28;
    PWM1.p_cb->channels_cb[1].ppi_channels[1] = NRF_PPI_CHANNEL29;
    PWM1.p_cb->channels_cb[1].polarity = APP_PWM_POLARITY_ACTIVE_LOW;
    PWM1.p_cb->channels_cb[1].initialized = 0;
    PWM1.p_cb->period = 0xFFFFFFFF;
    PWM1.p_cb->p_ready_callback = pwm_ready_callback;
    PWM1.p_cb->ppi_channels[0] = NRF_PPI_CHANNEL30;
    PWM1.p_cb->ppi_channels[1] = NRF_PPI_CHANNEL31;
    PWM1.p_cb->ppi_group = NRF_PPI_CHANNEL_GROUP3;
    PWM1.p_cb->state = NRF_DRV_STATE_UNINITIALIZED;
    I guessed at many of the values (mainly the PPI values), so YMMV.
  • Hey Lucas - are you using updated driver (pwm_20150708) from this topic?
  • Yes, but I had to back port it to SDK 8.0. SDK 8.1 broke bluetooth connectivity for select android phones our Google Nexus 5 doesn't work with SDK 8.1 GG. Iphone and Google Nexus 4 dont seem to have a problem.
