Filter on custom manufacturer data with BLE on Zephhyr/NCS
Hello!
I'm working on a project communicationg using two BLE devices (central and peripheral).  On the central side we want to scan and connect to a peripheral that advertises a certain manufacturer data, but I struggle to configure the scan filter on the central side correctly.  I'm using NCS version v1.5.0 on central and peripheral.
I have verified using nRF Connect that our Beacon (peripheral) advertise the manufacturer data we are looking for:
On the central side I have the following scan_init fuction:
static void scan_init(void) {
  int err;
  struct bt_scan_init_param scan_init = {
      .connect_if_match = 1,
      .scan_param = NULL,
      .conn_param = BT_LE_CONN_PARAM_DEFAULT};
  struct bt_scan_manufacturer_data manufacturer_data = {
        .data =  (uint8_t *){0x00, 0x01, 0x02, 0x03},
        .data_len = (uint8_t) 4};
  bt_scan_init(&scan_init);
  bt_scan_cb_register(&scan_cb);
  err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_MANUFACTURER_DATA, &manufacturer_data);
  if (err) {
    printk("Scanning filters cannot be set (err %d)\n", err);
    return;
  err = bt_scan_filter_enable(BT_SCAN_MANUFACTURER_DATA_FILTER, false);
  if (err) {
    printk("Filters cannot be turned on (err %d)\n", err);
Is this looking correct? Should the BT_DATA_MANUFACTURER_DATA flag (0xFF) be inclueded in the .data array above?
I have the following prj.conf:
#Bluetooth
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
#Custom central scanning
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=1
CONFIG_BT_PRIVACY=y
#Flash settings for storage of security keys
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
I have the following advertising array on the peripheral side:
#define BT_CUSTOM_DATA 0xfe  // containing custom data
static const struct bt_data ad[] = {
    BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    BT_DATA_BYTES(BT_DATA_MANUFACTURER_DATA, 0x00, 0x01, 0x02, 0x03)
    BT_DATA_BYTES(BT_CUSTOM_DATA, 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF, 0x00, 0x01, 0x02),
In a different test, I was able to find the peripheral filtering on a custom UUID, but we want to avoid broadcasting this, since it take up a lot of  bytes in a standard BLE advertising frame. Not sure why the manufacturer data filter doesn't  work.
Looking forward to your response.
