ISSUE (connect error 45) on HTTPS_Client example to amazon CloudFront using Custom SSL Certificate (socket.nouslogic.com) with SNI support
I'm getting error on connect to cloud server (socket.nouslogic.com:443) with error code is 45 ( EOPNOTSUPP).
Here are detail:
1. Using https_client example on nRF Connect NCS v1.5.0, modem_fw 1.1.4, network mode is NB-IoT on nRF9160 DK
2. Set TLS_PEER_VERIFY via "verify" value to NONE ( =0) to discard the certificate verifying ( eliminate wrong certificate file)
3. Host is "socket.nouslogic.com", this is custom CNAME on Amazon CloudFront, configured with SNI option.
4. Certificates is root CA from "openssl s_client -showcerts -tls1_2  -connect socket.nouslogic.com:443". (We did try to support 3 certificate chain in 3 different security tags also)
5. In configuration, select mbedtls support( zephyr built-in) to enable the SNI option. ( tried enable all cipher suites as well)
Result:
- other sites work well: google.com, amazon.com or any website without CloudFront configured (tested with vn.yahoo.com, vnexpress.net, mqtt.eclipseprojects.io ( correct certificate))
- our cloudfront host ( socket.nouslogic.com) or "nrfcloud.com" or even direct domain "dsmatvilvjgnu.cloudfront.net": connect fail with error 45.
Question:
- Does NCS v1.5.0 support TLS/SSL connection to Amazon CloudFront yet?
- If above question is YES,  so please help to solve the problem.
- If you have any example that successfully connect to our site ( socket.nouslogic.com:443) or any CloudFront site , please share the configuration file or source code.
Thanks in advance.
Best Regards.
Viet Nguyen
  • Thanks, It works.
    And attached file are modem trace and LTE link monitor, pls check.
    trace-2021-04-13T12-04-13.026Z.bin
    2021-04-13T12:04:14.952Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs1  ***
    2021-04-13T12:04:14.985Z DEBUG modem << Flash regionsDomainPermissions
    2021-04-13T12:04:14.990Z DEBUG modem << 00 00 0x00000 0x08000 Securerwxl
    2021-04-13T12:04:14.991Z DEBUG modem << 01 31 0x08000 0x100000 Non-Securerwxl
    2021-04-13T12:04:14.992Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.
    2021-04-13T12:04:15.139Z DEBUG modem << SRAM regionDomainPermissions
    2021-04-13T12:04:15.156Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl
    2021-04-13T12:04:15.159Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl
    2021-04-13T12:04:15.160Z DEBUG modem << PeripheralDomainStatus
    2021-04-13T12:04:15.162Z DEBUG modem << 00 NRF_P0               Non-SecureOK
    2021-04-13T12:04:15.163Z DEBUG modem << 01 NRF_CLOCK            Non-SecureOK
    2021-04-13T12:04:15.165Z DEBUG modem << 02 NRF_RTC0             Non-SecureOK
    2021-04-13T12:04:15.172Z DEBUG modem << 03 NRF_RTC1             Non-SecureOK
    2021-04-13T12:04:15.175Z DEBUG modem << 04 NRF_NVMC             Non-SecureOK
    2021-04-13T12:04:15.176Z DEBUG modem << 05 NRF_UARTE1           Non-SecureOK
    2021-04-13T12:04:15.177Z DEBUG modem << 06 NRF_UARTE2           SecureSKIP
    2021-04-13T12:04:15.180Z DEBUG modem << 07 NRF_TWIM2            Non-SecureOK
    2021-04-13T12:04:15.182Z DEBUG modem << 08 NRF_SPIM3            Non-SecureOK
    2021-04-13T12:04:15.183Z DEBUG modem << 09 NRF_TIMER0           Non-SecureOK
    2021-04-13T12:04:15.191Z DEBUG modem << 10 NRF_TIMER1           Non-SecureOK
    2021-04-13T12:04:15.193Z DEBUG modem << 11 NRF_TIMER2           Non-SecureOK
    2021-04-13T12:04:15.194Z DEBUG modem << 12 NRF_SAADC            Non-SecureOK
    2021-04-13T12:04:15.196Z DEBUG modem << 13 NRF_PWM0             Non-SecureOK
    2021-04-13T12:04:15.204Z DEBUG modem << 14 NRF_PWM1             Non-SecureOK
    2021-04-13T12:04:15.206Z DEBUG modem << 15 NRF_PWM2             Non-SecureOK
    2021-04-13T12:04:15.208Z DEBUG modem << 16 NRF_PWM3             Non-SecureOK
    2021-04-13T12:04:15.210Z DEBUG modem << 17 NRF_WDT              Non-SecureOK
    2021-04-13T12:04:15.211Z DEBUG modem << 18 NRF_IPC              Non-SecureOK
    2021-04-13T12:04:15.213Z DEBUG modem << 19 NRF_VMC              Non-SecureOK
    2021-04-13T12:04:15.222Z DEBUG modem << 20 NRF_FPU              Non-SecureOK
    2021-04-13T12:04:15.224Z DEBUG modem << 21 NRF_EGU1             Non-SecureOK
    2021-04-13T12:04:15.226Z DEBUG modem << 22 NRF_EGU2             Non-SecureOK
    2021-04-13T12:04:15.229Z DEBUG modem << 23 NRF_DPPIC            Non-SecureOK
    2021-04-13T12:04:15.236Z DEBUG modem << 24 NRF_REGULATORS       Non-SecureOK
    2021-04-13T12:04:15.240Z DEBUG modem << 25 NRF_GPIOTE1          Non-SecureOK
    2021-04-13T12:04:15.241Z DEBUG modem << SPM: NS image at 0xc000
    2021-04-13T12:04:15.242Z DEBUG modem << SPM: NS MSP at 0x2001d9d8
    2021-04-13T12:04:15.244Z DEBUG modem << SPM: NS reset vector at 0xed79
    2021-04-13T12:04:15.246Z DEBUG modem << SPM: prepare to jump to Non-Secure image.
    2021-04-13T12:04:15.255Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs1  ***
    2021-04-13T12:04:15.258Z DEBUG modem << HTTPS client sample started
    2021-04-13T12:04:15.541Z DEBUG modem << Provisioning certificate
    2021-04-13T12:04:41.296Z DEBUG modem << Waiting for network.. OK
    2021-04-13T12:04:42.228Z DEBUG modem << Connecting to socket.nouslogic.com
    2021-04-13T12:04:42.977Z DEBUG modem << connect() failed, err: 45
    Regards
    V Nguyen
  • The trace shows that you are not using SNI.
    SNI support was added to the modem FW in version 1.2.1, and it doesn't seem like it was backported to the 1.1.x branch.
    Is it possible for you to update to the 1.2.x branch?
  • Great, You make my day!
    After updating modem fw to v1.2.3 ( latest). It's now able to connect to our cloud "socket.nouslogic.com" successfully.
    ( I thought mfw1.1.3/1.1.4 was backported  from 1.2.x , as Michael Sly mentioned last August)
    BTW, Does Nordic have plan to backported all from mfw 1.2.x to 1.1.x, b/c we have many devices at the customer which are running mfw1.1.2/1.1.3 , and they cannot be OTA update to 1.2.x due to limitation of modem updating.
    Again, thanks alot.
    V. Nguyen
     That's great to hear! Happy to help.
     Roadmap related questions should in general be directed to your RSM. But no, it is not possible to backport all the features from the 1.2.x branch to the 1.1.x branch.
