Hallo,
I am trying to communicate MAX86140 sensor with nrf52840DK. This is the link to the datasheet of MAX86140/1. I am able to write and read MAX registers successfully.
MAX86140 consist of a 128 byte FIFO which has to be burst read for data, The first byte is the address, second byte the command and from third byte onwards i am suppose to read values of MISO lines according to the datasheet (Page 53).
I saw in the nrf SPI example that we use nrf_drv_spi_transfer() function. Is it possible to burst read the FIFO using the available nrf SPI driver in the example? Could you please suggest the functions and the method that I have to consider here. So I can read and learn those important functions and make use of them.
Thank you for your time.
Karlz
