SPI0 with EASYDMA sending corrupted data
Hello Guys,
I'm developping and st7789 IPS screen driver and i'm having problem with SPI0 .  I'm using NRF52840 DK 2.0.1
First I took SPI example from sdk 17.0.2 configured it to Eclipse IDE .
Tested the example is working.
Reworked the spi example for my need like this
static void ST7789_HwInit(void){
/* Configure DCX and RST PIN as output */
	nrf_gpio_cfg_output(LLDISPLAY_RST_PIN);
	nrf_gpio_cfg_output(LLDISPLAY_DCX_PIN);
/* Set DCX and RST PIN accoridng to ST7789 datasheet */
	nrf_gpio_pin_clear(LLDISPLAY_RST_PIN);
	nrf_gpio_pin_set(LLDISPLAY_DCX_PIN);
/* Configure SPI instance with 1MHZ and Mode0 */
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.mosi_pin = LLDISPLAY_MOSI_PIN;
    spi_config.sck_pin  = LLDISPLAY_SCK_PIN;
    spi_config.frequency    = NRF_DRV_SPI_FREQ_1M;
    spi_config.mode         = NRF_DRV_SPI_MODE_0;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
Here's the end of transmission event handler :
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
Here's the functions I use for data/command sending  :
 * @brief Write command to ST7789 controller
 * @param cmd -> command to write
 * @param buff -> pointer of data buffer
 * @param buff_size -> size of the data buffer
 * @return none
static void ST7789_WriteFullCommand(uint8_t cmd, uint8_t const * pData, uint8_t dataLength)
	nrf_gpio_pin_clear(LLDISPLAY_DCX_PIN);
	spi_xfer_done = false;
	nrf_drv_spi_transfer(&spi, &cmd, 1, NULL, 0);
    while (!spi_xfer_done)
        __WFE();
	nrf_drv_spi_transfer(&spi, pData, dataLength, NULL, 0);
        __WFE();
 * @brief Write data to ST7789 controller
 * @return none
static void ST7789_WriteData(uint8_t *buff, size_t buff_size)
	nrf_drv_spi_transfer(&spi, buff, buff_size, NULL, 0);
        __WFE();
The pin definition are
#define LLDISPLAY_SCK_PIN  			3
#define LLDISPLAY_MOSI_PIN			4
#define LLDISPLAY_DCX_PIN  			29
#define LLDISPLAY_RST_PIN  			30
So my code compiles well and I do receive a buffer which contains some corrupted bytes. For exapmle, in the initialisation sequence somewhere in the middle i send " ....0xB6 0x0A 0x82  0x3A 0x55...." how ever what i do receive in the logic analyser is " ....0xB6 0x0A 0x82  0x22 0x05...." with corrupted clock cycle(see the picture)
