Entering Serial DFU mode from the application layer
Hi, I am try to implement UART SERIAL Bootloader for my device and I just need to perform DFU using uart serial
I have tested the code and bootloader. My query is
Without pressing BUTTON_4 and Power reset how to enter to DFU mode from the application layer
Buttonless UART Serial Bootloader!!
    I assume you are referring to the nRF5 SDK now? In that case, you can use GPREGRET to enter DFU mode, in the same way as is used with the BLE buttonless DFU service. Essentially you just ensure that NRF_BL_DFU_ENTER_METHOD_GPREGRET is set to 1 in the bootloader's sdk_config.h and write BOOTLOADER_DFU_START to GPREGRET just as in ble_dfu_buttonless_bootloader_start_finalize() in components\ble\ble_services\ble_dfu\ble_dfu.c before you do a soft reset.
    Yes, It is working in nRF5 SDK
    these lines
    where i need to perform
    In Application code?
  • Sunil vignesh said:
    these lines
     Yes
  • i worked in BLE buttonless
    there i use  code
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
    case NRF_PWR_MGMT_EVT_PREPARE_DFU:
    NRF_LOG_INFO("Power management wants to reset to DFU mode\r\n");
    return true;
    NRF_LOG_INFO("Power management allowed to reset to DFU mode\r\n");
    return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    static void ble_dfu_buttonless_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    dfu_init() i called in service_init()
    where i can use this
  • You do not need to do all that. To just enter DFU mode, simply:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    err_code = sd_power_gpregret_clr(0, 0xffffffff);
    VERIFY_SUCCESS(err_code);
    err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
    NVIC_SystemReset();
1 2
