I have cloned the BLE code from the periperal_uart example provided in the SDK. However, I am using C++ so I am perform my BLE initialization inside a .cpp file (i.e. main.cpp). The problem is how the SDK's internal BT_LE_ADV_PARAM_INIT() macro expands when calling the bt_le_adv_start() method. The macro generates an invalid C++ construct - see the compiler error below. And yes - I have tried moving the offending code to a C file - and it compiles. However, I am not comfortable with this work around since while it compiles - I am not sure the actual generated code will be valid for C++ app (because the array made not really be in scope even though it compiled under my hybrid .c/.cpp files).
Is this a know bug with the SDK? If yes - is there a timeline for a fix?
../src/main.cpp: In function 'void main()':C:/compilers/nordic-nrfconnect/zephyr/include/bluetooth/bluetooth.h:612:30: error: taking address of temporary array 612 | ((struct bt_le_adv_param[]) { \ | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~ 613 | BT_LE_ADV_PARAM_INIT(_options, _int_min, _int_max, _peer) \ | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 614 | }) | ~~C:/compilers/nordic-nrfconnect/zephyr/include/bluetooth/bluetooth.h:621:24: note: in expansion of macro 'BT_LE_ADV_PARAM' 621 | #define BT_LE_ADV_CONN BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, \ | ^~~~~~~~~~~~~~~../src/main.cpp:108:28: note: in expansion of macro 'BT_LE_ADV_CONN' 108 | err = bt_le_adv_start( BT_LE_ADV_CONN, ad, ARRAY_SIZE( ad ), sd, ARRAY_SIZE( sd ) ); | ^~~~~~~~~~~~~~[89/283] Building C object modules/hal_nordic/CMakeFiles/modules__ha...dic-nrfconnect/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.objninja: build stopped: subcommand failed.
Source Code snippet:
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
static const struct bt_data ad[] = { BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)), BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),};
static const struct bt_data sd[] = { BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),};
// Start advertising err = bt_le_adv_start( BT_LE_ADV_CONN, ad, ARRAY_SIZE( ad ), sd, ARRAY_SIZE( sd ) ); if ( err )
Please see this Zephyr issue (specifically this comment).
