Checking if data is correct in pstorage callback
As i wrote in the topic, after calling pstorage_update I would like to check if the data was stored correctly. Can I call another pstorage_update in pstorage callback, if the data was corrupted?
For now the callback looks like this, but I can't make it work properly if I simulate an error:
void PStorage_SerialNumberRetVal_Handler(pstorage_handle_t  * handle, uint8_t op_code, uint32_t result, uint8_t * p_data, uint32_t data_len)
	  switch(op_code)
		 case PSTORAGE_UPDATE_OP_CODE:
           if (result == NRF_SUCCESS)		//	Check if the data were correctly flashed
		//	The max stored data lenght is for eventLog == sizeof(deviceState.eventlog_data)
		 uint8_t temp[8]={0};	//	The table where I store loaded data from flash to validate them
		 uint8_t p_dataCheck[8] = {0}; //The table where I copy the data which were just stored in flash (for debug)
		for(uint8_t i=0; i<8; i++)
		      p_dataCheck[i] = p_data[i];		//	Copy the data which were just stored, for debug
		pstorage_load(temp, handle, data_len, 0);		//	Read the data from flash
		//	Check if the data is correct
	        for(uint8_t i=0; i<data_len; i++)
			 if(p_dataCheck[i] != temp[i])	//	If the data was corrupted
				 //	return an error in order to try flashing the data again
					pstorage_update(handle, p_dataCheck, data_len, 0);
					for(uint16_t i=0; i<30000;i++)		//	Wait until the operation was completed
               // Store operation failed.
           // Source memory can now be reused or freed.
