What I'm trying to do, is probably very simple. I hope.
In the following code which works fine.
I want to scan not using Coded PHY
Then change back to using Coded PHY
I'd be grateful if you would show me the proper way to achieve this please.
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, NULL, NULL);
void initialise_Coded_PHY_scan(void) {
struct bt_le_scan_param scan_param = {
.type = BT_HCI_LE_SCAN_PASSIVE,
.options = BT_LE_SCAN_OPT_CODED,
// JC .options = BT_LE_SCAN_OPT_CODED, BT_LE_SCAN_OPT_FILTER_DUPLICATE,
.interval = BT_GAP_SCAN_FAST_INTERVAL,
.window = BT_GAP_SCAN_FAST_WINDOW,
struct bt_scan_init_param scan_init = {
.connect_if_match = 0,
.scan_param = &scan_param,
.conn_param = NULL
int err = 0;
bt_scan_init(&scan_init);
bt_scan_cb_register(&scan_cb);
/* Set Scan filter */
err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME, dev_name);
if (err) {
printk("Scanning Name filter cannot be set (err %d)\n", err);
return;
// err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_MANUFACTURER_DATA, MANUFACTURER_ID);
// if (err) {
// printk("Scanning filter Manufacturer ID cannot be set (err %d)\n", err);
// return;
/* Apply scan filter */
err = bt_scan_filter_enable(BT_SCAN_NAME_FILTER, false);
// err = bt_scan_filter_enable(BT_SCAN_FILTER_TYPE_MANUFACTURER_DATA, false);
if (err) {
printk("Filters cannot be turned on (err %d)\n", err);
return;
/* Start scanning */
bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
