Usıng TWI with BLE nRF52dk
I am trying to make ble communication work with I2C  but i cant make it work i dont understand what is the issue the code is being build but it does not advertise can someone help me or show an example for me to work with i cant find any good examples for TWI and BLE being used at the same time.  This is my code please help me see a way
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_drv_twi.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     1
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "4thLayer"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define MYDATA_TIMER_INTERVAL            APP_TIMER_TICKS(500)
#define BME280_ADDRESS_1  0x76
#define BME280_ID         0xD0
#define BME280_PRESS_MSB  0xF7
#define BME280_PRESS_LSB  0xF8
#define BME280_PRESS_XLSB 0xF9
#define BME280_TEMP_MSB   0xFA
#define BME280_TEMP_LSB   0xFB
#define BME280_TEMP_XLSB  0xFC
#define BME280_HUM_MSB    0xFD
#define BME280_HUM_LSB    0xFE
#define BME280_CONFIG     0xF5
#define BME280_CTRL_MEAS  0xF4
#define BME280_STATUS     0xF3
#define BME280_CTRL_HUM   0xF2
#define BME280_RESET      0xE0
#define BME280_CALIB00    0x88
#define BME280_CALIB26    0xE1
enum Posr {P_OSR_00 = 0, /* no op */ P_OSR_01, P_OSR_02, P_OSR_04, P_OSR_08, P_OSR_16};
enum Hosr {H_OSR_00 = 0, /* no op */ H_OSR_01, H_OSR_02, H_OSR_04, H_OSR_08, H_OSR_16};
enum Tosr {T_OSR_00 = 0, /* no op */ T_OSR_01, T_OSR_02, T_OSR_04, T_OSR_08, T_OSR_16};
enum IIRFilter {full = 0,  /* bandwidth at full sample rate */ BW0_223ODR, BW0_092ODR, BW0_042ODR, BW0_021ODR /* bandwidth at 0.021 x sample rate */ };
enum Mode {BME280Sleep = 0, forced, forced2, normal};
enum SBy  {t_00_5ms = 0, t_62_5ms, t_125ms, t_250ms, t_500ms, t_1000ms, t_10ms, t_20ms};
// Read and store calibration data
uint8_t calib26[26];
uint8_t calib7[7];
//from read PTH
static uint8_t rawData[8];  // 20-bit pressure register data stored here
int32_t result[3];
int32_t var1, var2, t_fine, adc_T;
int32_t Temp,Temp1,Temp2,Hum,Hum1,Hum2;
//from Pressure comp
int32_t varP1, varP2;
uint32_t P;
// BME280 compensation parameters
uint8_t  dig_H1, dig_H3, dig_H6;
uint16_t dig_T1, dig_P1, dig_H4, dig_H5;
int16_t  dig_T2, dig_T3, dig_P2, dig_P3, dig_P4, dig_P5, dig_P6, dig_P7, dig_P8, dig_P9, dig_H2;
//uint32_t delt_t = 0, count = 0, sumCount = 0, slpcnt = 0;  // used to control display output rate
// Specify BME280 configuration
// set pressure and temperature output data rate
//uint8_t Posr = P_OSR_16, Hosr = H_OSR_16, Tosr = T_OSR_02, Mode = normal, IIRFilter = BW0_021ODR, SBy = t_62_5ms;
/* @EfektaSB */
uint8_t Posr = P_OSR_01, Hosr = H_OSR_01, Tosr = T_OSR_01, Mode = forced, IIRFilter = full, SBy = t_00_5ms;
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t i2c = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);
APP_TIMER_DEF(m_mydata_timer_id);
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
static void mydata_timeout_handler(void * p_context)
    ret_code_t      err_code;
    UNUSED_PARAMETER(p_context);
    bsp_board_led_on(3);
    nrf_delay_ms(100);
    bsp_board_led_off(3);
    uint8_array_t mydata_value [17] = {0x55,0x10,0x01,0x23,0x99,0xFF,0xFF,0xCC,0xBB,0x00,0x00,0x00,0x00,0x00,0x24,0x24,0x20};
ble_nus_mydata_update(&m_nus, mydata_value, 17, m_conn_handle);
/**@brief Function for initializing the timer module.
static void timers_init(void)
    err_code = app_timer_create(&m_mydata_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                mydata_timeout_handler);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
static void application_timers_start(void)
    err_code = app_timer_start(m_mydata_timer_id, MYDATA_TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
void I2C_init(void)
    const nrf_drv_twi_config_t i2c_config =
       .scl                = 16,
       .sda                = 17,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW,
       .clear_bus_init     = false
    // @brief TWI events handler.
void I2C_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            //todo -difference between read and write???
            m_xfer_done = true;
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
    //last one is some kind of context - no idea what that is....
    //documentation is vague/nonexistant
    err_code = nrf_drv_twi_init(&i2c, &i2c_config, I2C_handler, NULL);
    nrf_drv_twi_enable(&i2c);
void writeByte(uint8_t address, uint8_t subAddress, uint8_t data)
    uint8_t temp[2];
    temp[0] = subAddress;
    temp[1] = data;
    err_code = nrf_drv_twi_tx(&i2c, address, &temp[0], 2, true);
    while (m_xfer_done == false); //wait until end of transfer
uint8_t readByte(uint8_t address, uint8_t subAddress)
    ret_code_t err_code = 0;
    uint8_t value;
    err_code = nrf_drv_twi_tx(&i2c, address, &subAddress, 1, true);
    if (err_code == NRF_SUCCESS)
        err_code = nrf_drv_twi_rx(&i2c, address, &value, 1);
    return value;
void readBytes(uint8_t address, uint8_t subAddress, uint8_t * dest, uint8_t n_bytes )
    while (m_xfer_done == false) {};
        err_code = nrf_drv_twi_rx(&i2c, address, dest, n_bytes);
void BME280_Turn_On(void)
    uint8_t e = readByte(BME280_ADDRESS_1, BME280_ID);
    NRF_LOG_INFO("BME280 ID:%d Should be = 96\n", e);
    if(e == 0x60) {
        writeByte( BME280_ADDRESS_1, BME280_RESET, 0xB6 ); // reset BME280 before initialization
        nrf_delay_ms(100);
        BME280_Configure( BME280_ADDRESS_1 ); // Initialize BME280 altimeter
        nrf_delay_ms(100);
void BME280_Configure( uint8_t address )
  // Configure the BME280
  // Set H oversampling rate
  writeByte(address, BME280_CTRL_HUM, 0x07 & Hosr);
  // Set T and P oversampling rates and sensor mode
  writeByte(address, BME280_CTRL_MEAS, Tosr << 5 | Posr << 2 | Mode);
  // Set standby time interval in normal mode and bandwidth
  writeByte(address, BME280_CONFIG, SBy << 5 | IIRFilter << 2);
  readBytes(address, BME280_CALIB00, calib26, 26);
  dig_T1 = (uint16_t)(((uint16_t) calib26[ 1] << 8) | calib26[ 0]);
  //NRF_LOG_DEBUG("BME280T1:%d\r\n",dig_T1);
  dig_T2 = ( int16_t)((( int16_t) calib26[ 3] << 8) | calib26[ 2]);
  //NRF_LOG_DEBUG("BME280T2:%d\r\n",dig_T2);
  dig_T3 = ( int16_t)((( int16_t) calib26[ 5] << 8) | calib26[ 4]);
  //NRF_LOG_DEBUG("BME280T3:%d\r\n",dig_T3);
  dig_P1 = (uint16_t)(((uint16_t) calib26[ 7] << 8) | calib26[ 6]);
  //NRF_LOG_DEBUG("BME280P1:%d\r\n",dig_P1);
  dig_P2 = ( int16_t)((( int16_t) calib26[ 9] << 8) | calib26[ 8]);
  dig_P3 = ( int16_t)((( int16_t) calib26[11] << 8) | calib26[10]);
  dig_P4 = ( int16_t)((( int16_t) calib26[13] << 8) | calib26[12]);
  dig_P5 = ( int16_t)((( int16_t) calib26[15] << 8) | calib26[14]);
  dig_P6 = ( int16_t)((( int16_t) calib26[17] << 8) | calib26[16]);
  dig_P7 = ( int16_t)((( int16_t) calib26[19] << 8) | calib26[18]);
  dig_P8 = ( int16_t)((( int16_t) calib26[21] << 8) | calib26[20]);
  dig_P9 = ( int16_t)((( int16_t) calib26[23] << 8) | calib26[22]);
  //24 is missing - this is not typo - complain to Bosch
  dig_H1 = calib26[25];
  readBytes(address, BME280_CALIB26, calib7, 7);
  dig_H2 = ( int16_t)((( int16_t) calib7[1] << 8) | calib7[0]);
  dig_H3 = calib7[2];
  dig_H4 = ( int16_t)(((( int16_t) calib7[3] << 8) | (0x0F & calib7[4]) << 4) >> 4);
  dig_H5 = ( int16_t)(((( int16_t) calib7[5] << 8) | (0xF0 & calib7[4]) ) >> 4 );
  dig_H6 = calib7[6];
void BME280_Get_Data(int32_t * resultPTH)
  writeByte(BME280_ADDRESS_1, BME280_CTRL_MEAS, Tosr << 5 | Posr << 2 | Mode);
  readBytes(BME280_ADDRESS_1, BME280_PRESS_MSB, rawData, 8);
  //Pressure
  result[0] = (uint32_t) (((uint32_t) rawData[0] << 16 | (uint32_t) rawData[1] << 8 | rawData[2]) >> 4);
  result[1] = (uint32_t) (((uint32_t) rawData[3] << 16 | (uint32_t) rawData[4] << 8 | rawData[5]) >> 4);
  result[2] = (uint16_t) (((uint16_t) rawData[6] <<  8 |            rawData[7]) );
  //Need t_fine for all three compensations
  adc_T = result[1];
  var1 = (((( adc_T >> 3) - ((int32_t)dig_T1 << 1))) * ((int32_t)dig_T2)) >> 11;
  var2 = (((((adc_T >> 4) - ((int32_t)dig_T1)) * ((adc_T >> 4) - ((int32_t)dig_T1))) >> 12) * ((int32_t)dig_T3)) >> 14;
  t_fine = var1 + var2;
  // Returns humidity in %RH as unsigned 32 bit integer in Q22.10 format (22integer and 10fractional bits).
  // Output value of “47445”represents 47445/1024= 46.333%RH
  uint32_t BME280_Compensate_H(int32_t adc_H, int32_t t_fine)
  int32_t varH;
  varH = (t_fine - ((int32_t)76800));
  varH = (((((adc_H << 14) - (((int32_t)dig_H4) << 20) - (((int32_t)dig_H5) * varH)) +
    ((int32_t)16384)) >> 15) * (((((((varH * ((int32_t)dig_H6)) >> 10) * (((varH *
    ((int32_t)dig_H3)) >> 11) + ((int32_t)32768))) >> 10) + ((int32_t)2097152)) * ((int32_t)dig_H2) + 8192) >> 14));
  varH = (varH - (((((varH >> 15) * (varH >> 15)) >> 7) * ((int32_t)dig_H1)) >> 4));
  varH = (varH < 0 ? 0 : varH);
  varH = (varH > 419430400 ? 419430400 : varH);
  return(uint32_t)(varH >> 12);
  // Returns temperature in DegC, resolution is 0.01 DegC. Output value of
  // “5123” equals 51.23 DegC.
  int32_t BME280_Compensate_T(int32_t t_fine)
  int32_t T;
  //var1 = ((((adc_T >> 3) - ((int32_t)dig_T1 << 1))) * ((int32_t)dig_T2)) >> 11;
  //var2 = (((((adc_T >> 4) - ((int32_t)dig_T1)) * ((adc_T >> 4) - ((int32_t)dig_T1))) >> 12) * ((int32_t)dig_T3)) >> 14;
  //t_fine = var1 + var2;
  T = (t_fine * 5 + 128) >> 8;
  return T;
  // Returns pressure in Pa as unsigned 32 bit integer. Output value of “96386” equals 96386 Pa = 963.86 hPa
  uint32_t BME280_Compensate_P(int32_t adc_P, int32_t t_fine)
    varP1 = (t_fine>>1) - (int32_t)64000;
    varP2 = (((varP1>>2) * (varP1>>2)) >> 11 ) * ((int32_t)dig_P6);
    varP2 = varP2 + ((varP1*((int32_t)dig_P5))<<1);
    varP2 = (varP2>>2)+(((int32_t)dig_P4)<<16);
    varP1 = (((dig_P3 * (((varP1>>2) * (varP1>>2)) >> 13 )) >> 3) + ((((int32_t)dig_P2) * varP1)>>1))>>18;
    varP1 = ((((32768+varP1))*((int32_t)dig_P1))>>15);
    if (varP1 == 0)
        return 0; // avoid exception caused by division by zero
    P = (((uint32_t)(((int32_t)1048576)-adc_P)-(varP2>>12)))*3125;
    if (P < 0x80000000)
        P = (P << 1) / ((uint32_t)varP1);
        P = (P / (uint32_t)varP1) * 2;
    varP1 = (((int32_t)dig_P9) * ((int32_t)(((P>>3) * (P>>3))>>13)))>>12;
    varP2 = (((int32_t)(P>>2)) * ((int32_t)dig_P8))>>13;
    P = (uint32_t)((int32_t)P + ((varP1 + varP2 + dig_P7) >> 4));
    return P;
  resultPTH[0] = BME280_Compensate_P(result[0], t_fine);
  resultPTH[1] = BME280_Compensate_T(           t_fine);
  resultPTH[2] = BME280_Compensate_H(result[2], t_fine);
  //resultPTH[0]/=100;
  resultPTH[1]/=100;
  resultPTH[2]/=1000;
  NRF_LOG_INFO("BME280:Pressure= %d , Tempreture= %d , Humidity= %d\n", resultPTH[0], resultPTH[1], resultPTH[2]);
  NRF_LOG_FLUSH();
/**@brief Application main function.
    bool erase_bonds;
    int32_t *sonuc;
    int32_t bme280value[3];
    I2C_init();
    nrf_delay_ms(50);
    BME280_Turn_On();
    nrf_delay_ms(1000);
    uint8_t name= readByte(0x76, 0xD0);
    printf("BME280 initilized and its id= %d", name );
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    application_timers_start();
    advertising_start();
    // Enter main loop.
    for (;;)
      idle_state_handle();
//     length1 = sprintf(str, "x:%x ", x);
//     ble_nus_data_send(&m_nus, str, &length1,m_conn_handle);
  • So what code is executing on line 29 of mpu6050.c? Next step would be to find from the API description what the error code 104 may mean. However, I can find from mpu6050.c the following comment:
    #define ADDRESS_WHO_AM_I          (0x75U) // !< WHO_AM_I register identifies the device. Expected value is 0x68.
    The value 0x68 is 104 (decimal), maybe this is not an error code.
    A logic analyzer trace is very useful.
    Kenneth
  • yes you were right the 104 was not an error code but it was the value of mpu who am i result so i just comment the part for
     //   err_code=readByte(MPU6050_ADDRESS, ADDRESS_WHO_AM_I);
     //   APP_ERROR_CHECK(err_code);
    and i checked the results of who am i myself and they are both 104 so thecniquely I2C is working so thanks for that ( i still dont know why it gave error like it was fine when i was using thiss code for just TWI )i still have a problem with BLE tough it sends random data again i am fine with that i didnt give any init_value for that but i cant update it ( change the value as i wish) it gets stuck and says this on logger
    <info> app: In ble_cus_custom_value_update.
    <info> app: sd_ble_gatts_hvx result: 0.
    <info> app: BLE event received. Event type = 87
    do you have any suggestions about this without A logic analyzer because i dont own one and cant go anywhere because of the pandemic
    Best regards
    Efe
    Sorry for taking this much of your time .
  • Event type (decimal) 87 is 0x57, and if you look at ble_ranges.h you can find it's a BLE_GATTS_EVT_BASE event. If you open ble_gatts.h you can find all events that start from BLE_GATTS_EVT_BASE:
    enum BLE_GATTS_EVTS
      BLE_GATTS_EVT_WRITE = BLE_GATTS_EVT_BASE,       /**< Write operation performed.                                           \n See @ref ble_gatts_evt_write_t.                 */
      BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST,             /**< Read/Write Authorization request.                                    \n Reply with @ref sd_ble_gatts_rw_authorize_reply. \n See @ref ble_gatts_evt_rw_authorize_request_t. */
      BLE_GATTS_EVT_SYS_ATTR_MISSING,                 /**< A persistent system attribute access is pending.                     \n Respond with @ref sd_ble_gatts_sys_attr_set.     \n See @ref ble_gatts_evt_sys_attr_missing_t.     */
      BLE_GATTS_EVT_HVC,                              /**< Handle Value Confirmation.                                           \n See @ref ble_gatts_evt_hvc_t.                   */
      BLE_GATTS_EVT_SC_CONFIRM,                       /**< Service Changed Confirmation.                                        \n No additional event structure applies.          */
      BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST,             /**< Exchange MTU Request.                                                \n Reply with @ref sd_ble_gatts_exchange_mtu_reply. \n See @ref ble_gatts_evt_exchange_mtu_request_t. */
      BLE_GATTS_EVT_TIMEOUT,                          /**< Peer failed to respond to an ATT request in time.                    \n See @ref ble_gatts_evt_timeout_t.               */
      BLE_GATTS_EVT_HVN_TX_COMPLETE                   /**< Handle Value Notification transmission complete.                     \n See @ref ble_gatts_evt_hvn_tx_complete_t.       */
    This means 0x57 is BLE_GATTS_EVT_HVN_TX_COMPLETE, and the notification have been sent with success (yay!). I guess you need to look at the handle, data and length you tried to pass to sd_ble_gatts_hvx(), and why that was random?
    Kenneth
