I am trying to make ble communication work with I2C but i cant make it work i dont understand what is the issue the code is being build but it does not advertise can someone help me or show an example for me to work with i cant find any good examples for TWI and BLE being used at the same time. This is my code please help me see a way
#include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "ble_hci.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "nrf_sdh.h" #include "nrf_sdh_soc.h" #include "nrf_sdh_ble.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "app_timer.h" #include "ble_nus.h" #include "app_uart.h" #include "app_util_platform.h" #include "bsp_btn_ble.h" #include "nrf_pwr_mgmt.h" #include "nrf_delay.h" #include "nrf_drv_twi.h" #if defined (UART_PRESENT) #include "nrf_uart.h" #endif #if defined (UARTE_PRESENT) #include "nrf_uarte.h" #endif #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" /* TWI instance ID. */ #define TWI_INSTANCE_ID 1 #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define DEVICE_NAME "4thLayer" /**< Name of device. Will be included in the advertising data. */ #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */ #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */ #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */ #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ #define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */ #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */ #define MYDATA_TIMER_INTERVAL APP_TIMER_TICKS(500) #define BME280_ADDRESS_1 0x76 #define BME280_ID 0xD0 #define BME280_PRESS_MSB 0xF7 #define BME280_PRESS_LSB 0xF8 #define BME280_PRESS_XLSB 0xF9 #define BME280_TEMP_MSB 0xFA #define BME280_TEMP_LSB 0xFB #define BME280_TEMP_XLSB 0xFC #define BME280_HUM_MSB 0xFD #define BME280_HUM_LSB 0xFE #define BME280_CONFIG 0xF5 #define BME280_CTRL_MEAS 0xF4 #define BME280_STATUS 0xF3 #define BME280_CTRL_HUM 0xF2 #define BME280_RESET 0xE0 #define BME280_CALIB00 0x88 #define BME280_CALIB26 0xE1 enum Posr {P_OSR_00 = 0, /* no op */ P_OSR_01, P_OSR_02, P_OSR_04, P_OSR_08, P_OSR_16}; enum Hosr {H_OSR_00 = 0, /* no op */ H_OSR_01, H_OSR_02, H_OSR_04, H_OSR_08, H_OSR_16}; enum Tosr {T_OSR_00 = 0, /* no op */ T_OSR_01, T_OSR_02, T_OSR_04, T_OSR_08, T_OSR_16}; enum IIRFilter {full = 0, /* bandwidth at full sample rate */ BW0_223ODR, BW0_092ODR, BW0_042ODR, BW0_021ODR /* bandwidth at 0.021 x sample rate */ }; enum Mode {BME280Sleep = 0, forced, forced2, normal}; enum SBy {t_00_5ms = 0, t_62_5ms, t_125ms, t_250ms, t_500ms, t_1000ms, t_10ms, t_20ms}; // Read and store calibration data uint8_t calib26[26]; uint8_t calib7[7]; //from read PTH static uint8_t rawData[8]; // 20-bit pressure register data stored here int32_t result[3]; int32_t var1, var2, t_fine, adc_T; int32_t Temp,Temp1,Temp2,Hum,Hum1,Hum2; //from Pressure comp int32_t varP1, varP2; uint32_t P; // BME280 compensation parameters uint8_t dig_H1, dig_H3, dig_H6; uint16_t dig_T1, dig_P1, dig_H4, dig_H5; int16_t dig_T2, dig_T3, dig_P2, dig_P3, dig_P4, dig_P5, dig_P6, dig_P7, dig_P8, dig_P9, dig_H2; //uint32_t delt_t = 0, count = 0, sumCount = 0, slpcnt = 0; // used to control display output rate // Specify BME280 configuration // set pressure and temperature output data rate //uint8_t Posr = P_OSR_16, Hosr = H_OSR_16, Tosr = T_OSR_02, Mode = normal, IIRFilter = BW0_021ODR, SBy = t_62_5ms; /* @EfektaSB */ uint8_t Posr = P_OSR_01, Hosr = H_OSR_01, Tosr = T_OSR_01, Mode = forced, IIRFilter = full, SBy = t_00_5ms; /* Indicates if operation on TWI has ended. */ static volatile bool m_xfer_done = false; /* TWI instance. */ static const nrf_drv_twi_t i2c = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID); BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */ NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ BLE_ADVERTISING_DEF(m_advertising); APP_TIMER_DEF(m_mydata_timer_id); static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */ static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */ { {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE} }; /**@brief Function for assert macro callback. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyse * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] p_file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } static void mydata_timeout_handler(void * p_context) { ret_code_t err_code; UNUSED_PARAMETER(p_context); bsp_board_led_on(3); nrf_delay_ms(100); bsp_board_led_off(3); /* uint8_array_t mydata_value [17] = {0x55,0x10,0x01,0x23,0x99,0xFF,0xFF,0xCC,0xBB,0x00,0x00,0x00,0x00,0x00,0x24,0x24,0x20}; ble_nus_mydata_update(&m_nus, mydata_value, 17, m_conn_handle); if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) && (err_code != NRF_ERROR_NOT_FOUND)) { APP_ERROR_CHECK(err_code); } */ } /**@brief Function for initializing the timer module. */ static void timers_init(void) { ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); err_code = app_timer_create(&m_mydata_timer_id, APP_TIMER_MODE_REPEATED, mydata_timeout_handler); APP_ERROR_CHECK(err_code); } /**@brief Function for the GAP initialization. * * @details This function will set up all the necessary GAP (Generic Access Profile) parameters of * the device. It also sets the permissions and appearance. */ static void gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *) DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for handling the data from the Nordic UART Service. * * @details This function will process the data received from the Nordic UART BLE Service and send * it to the UART module. * * @param[in] p_evt Nordic UART Service event. */ /**@snippet [Handling the data received over BLE] */ static void nus_data_handler(ble_nus_evt_t * p_evt) { if (p_evt->type == BLE_NUS_EVT_RX_DATA) { uint32_t err_code; NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART."); NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length); for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) { do { err_code = app_uart_put(p_evt->params.rx_data.p_data[i]); if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) { NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code); APP_ERROR_CHECK(err_code); } } while (err_code == NRF_ERROR_BUSY); } if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') { while (app_uart_put('\n') == NRF_ERROR_BUSY); } } } /**@snippet [Handling the data received over BLE] */ /**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { uint32_t err_code; ble_nus_init_t nus_init; nrf_ble_qwr_init_t qwr_init = {0}; // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); // Initialize NUS. memset(&nus_init, 0, sizeof(nus_init)); nus_init.data_handler = nus_data_handler; err_code = ble_nus_init(&m_nus, &nus_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling an event from the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module * which are passed to the application. * * @note All this function does is to disconnect. This could have been done by simply setting * the disconnect_on_fail config parameter, but instead we use the event handler * mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { uint32_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling errors from the Connection Parameters module. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { uint32_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } static void application_timers_start(void) { ret_code_t err_code; err_code = app_timer_start(m_mydata_timer_id, MYDATA_TIMER_INTERVAL, NULL); APP_ERROR_CHECK(err_code); } /**@brief Function for putting the chip into sleep mode. * * @note This function will not return. */ static void sleep_mode_enter(void) { uint32_t err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. err_code = bsp_btn_ble_sleep_mode_prepare(); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling advertising events. * * @details This function will be called for advertising events which are passed to the application. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { uint32_t err_code; switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); break; case BLE_ADV_EVT_IDLE: sleep_mode_enter(); break; default: break; } } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { uint32_t err_code; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected"); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected"); // LED indication will be changed when advertising starts. m_conn_handle = BLE_CONN_HANDLE_INVALID; break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: // Pairing not supported err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: // No system attributes have been stored. err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; default: // No implementation needed. break; } } /**@brief Function for the SoftDevice initialization. * * @details This function initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for handling events from the GATT library. */ void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt) { if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) { m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH; NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len); } NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x", p_gatt->att_mtu_desired_central, p_gatt->att_mtu_desired_periph); } /**@brief Function for initializing the GATT library. */ void gatt_init(void) { ret_code_t err_code; err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler); APP_ERROR_CHECK(err_code); err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE); APP_ERROR_CHECK(err_code); } /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated by button press. */ void bsp_event_handler(bsp_event_t event) { uint32_t err_code; switch (event) { case BSP_EVENT_SLEEP: sleep_mode_enter(); break; case BSP_EVENT_DISCONNECT: err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } break; case BSP_EVENT_WHITELIST_OFF: if (m_conn_handle == BLE_CONN_HANDLE_INVALID) { err_code = ble_advertising_restart_without_whitelist(&m_advertising); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } } break; default: break; } } /**@brief Function for handling app_uart events. * * @details This function will receive a single character from the app_uart module and append it to * a string. The string will be be sent over BLE when the last character received was a * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length. */ /**@snippet [Handling the data received over UART] */ void uart_event_handle(app_uart_evt_t * p_event) { static uint8_t data_array[BLE_NUS_MAX_DATA_LEN]; static uint8_t index = 0; uint32_t err_code; switch (p_event->evt_type) { case APP_UART_DATA_READY: UNUSED_VARIABLE(app_uart_get(&data_array[index])); index++; if ((data_array[index - 1] == '\n') || (data_array[index - 1] == '\r') || (index >= m_ble_nus_max_data_len)) { if (index > 1) { NRF_LOG_DEBUG("Ready to send data over BLE NUS"); NRF_LOG_HEXDUMP_DEBUG(data_array, index); do { uint16_t length = (uint16_t)index; err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle); if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) && (err_code != NRF_ERROR_NOT_FOUND)) { APP_ERROR_CHECK(err_code); } } while (err_code == NRF_ERROR_RESOURCES); } index = 0; } break; case APP_UART_COMMUNICATION_ERROR: APP_ERROR_HANDLER(p_event->data.error_communication); break; case APP_UART_FIFO_ERROR: APP_ERROR_HANDLER(p_event->data.error_code); break; default: break; } } /**@snippet [Handling the data received over UART] */ /**@brief Function for initializing the UART module. */ /**@snippet [UART Initialization] */ static void uart_init(void) { uint32_t err_code; app_uart_comm_params_t const comm_params = { .rx_pin_no = RX_PIN_NUMBER, .tx_pin_no = TX_PIN_NUMBER, .rts_pin_no = RTS_PIN_NUMBER, .cts_pin_no = CTS_PIN_NUMBER, .flow_control = APP_UART_FLOW_CONTROL_DISABLED, .use_parity = false, #if defined (UART_PRESENT) .baud_rate = NRF_UART_BAUDRATE_115200 #else .baud_rate = NRF_UARTE_BAUDRATE_115200 #endif }; APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_event_handle, APP_IRQ_PRIORITY_LOWEST, err_code); APP_ERROR_CHECK(err_code); } /**@snippet [UART Initialization] */ /**@brief Function for initializing the Advertising functionality. */ static void advertising_init(void) { uint32_t err_code; ble_advertising_init_t init; memset(&init, 0, sizeof(init)); init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = false; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE; init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); init.srdata.uuids_complete.p_uuids = m_adv_uuids; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = APP_ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); } /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up. */ static void buttons_leds_init(bool * p_erase_bonds) { bsp_event_t startup_event; uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /**@brief Function for initializing the nrf log module. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). * * @details If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } void I2C_init(void) { ret_code_t err_code; const nrf_drv_twi_config_t i2c_config = { .scl = 16, .sda = 17, .frequency = NRF_DRV_TWI_FREQ_100K, .interrupt_priority = APP_IRQ_PRIORITY_LOW, .clear_bus_init = false }; // @brief TWI events handler. void I2C_handler(nrf_drv_twi_evt_t const * p_event, void * p_context) { switch (p_event->type) { case NRF_DRV_TWI_EVT_DONE: //todo -difference between read and write??? m_xfer_done = true; if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX) { } break; default: break; } } //last one is some kind of context - no idea what that is.... //documentation is vague/nonexistant err_code = nrf_drv_twi_init(&i2c, &i2c_config, I2C_handler, NULL); APP_ERROR_CHECK(err_code); nrf_drv_twi_enable(&i2c); } void writeByte(uint8_t address, uint8_t subAddress, uint8_t data) { uint8_t temp[2]; temp[0] = subAddress; temp[1] = data; ret_code_t err_code; m_xfer_done = false; err_code = nrf_drv_twi_tx(&i2c, address, &temp[0], 2, true); APP_ERROR_CHECK(err_code); while (m_xfer_done == false); //wait until end of transfer } uint8_t readByte(uint8_t address, uint8_t subAddress) { ret_code_t err_code = 0; uint8_t value; m_xfer_done = false; err_code = nrf_drv_twi_tx(&i2c, address, &subAddress, 1, true); APP_ERROR_CHECK(err_code); while (m_xfer_done == false); //wait until end of transfer if (err_code == NRF_SUCCESS) { m_xfer_done = false; err_code = nrf_drv_twi_rx(&i2c, address, &value, 1); APP_ERROR_CHECK(err_code); while (m_xfer_done == false); }; return value; } void readBytes(uint8_t address, uint8_t subAddress, uint8_t * dest, uint8_t n_bytes ) { ret_code_t err_code = 0; m_xfer_done = false; err_code = nrf_drv_twi_tx(&i2c, address, &subAddress, 1, true); while (m_xfer_done == false) {}; if (err_code == NRF_SUCCESS) { m_xfer_done = false; err_code = nrf_drv_twi_rx(&i2c, address, dest, n_bytes); while (m_xfer_done == false) {}; }; } void BME280_Turn_On(void) { uint8_t e = readByte(BME280_ADDRESS_1, BME280_ID); NRF_LOG_INFO("BME280 ID:%d Should be = 96\n", e); if(e == 0x60) { writeByte( BME280_ADDRESS_1, BME280_RESET, 0xB6 ); // reset BME280 before initialization nrf_delay_ms(100); BME280_Configure( BME280_ADDRESS_1 ); // Initialize BME280 altimeter nrf_delay_ms(100); }; } void BME280_Configure( uint8_t address ) { // Configure the BME280 // Set H oversampling rate writeByte(address, BME280_CTRL_HUM, 0x07 & Hosr); // Set T and P oversampling rates and sensor mode writeByte(address, BME280_CTRL_MEAS, Tosr << 5 | Posr << 2 | Mode); // Set standby time interval in normal mode and bandwidth writeByte(address, BME280_CONFIG, SBy << 5 | IIRFilter << 2); readBytes(address, BME280_CALIB00, calib26, 26); dig_T1 = (uint16_t)(((uint16_t) calib26[ 1] << 8) | calib26[ 0]); //NRF_LOG_DEBUG("BME280T1:%d\r\n",dig_T1); dig_T2 = ( int16_t)((( int16_t) calib26[ 3] << 8) | calib26[ 2]); //NRF_LOG_DEBUG("BME280T2:%d\r\n",dig_T2); dig_T3 = ( int16_t)((( int16_t) calib26[ 5] << 8) | calib26[ 4]); //NRF_LOG_DEBUG("BME280T3:%d\r\n",dig_T3); dig_P1 = (uint16_t)(((uint16_t) calib26[ 7] << 8) | calib26[ 6]); //NRF_LOG_DEBUG("BME280P1:%d\r\n",dig_P1); dig_P2 = ( int16_t)((( int16_t) calib26[ 9] << 8) | calib26[ 8]); dig_P3 = ( int16_t)((( int16_t) calib26[11] << 8) | calib26[10]); dig_P4 = ( int16_t)((( int16_t) calib26[13] << 8) | calib26[12]); dig_P5 = ( int16_t)((( int16_t) calib26[15] << 8) | calib26[14]); dig_P6 = ( int16_t)((( int16_t) calib26[17] << 8) | calib26[16]); dig_P7 = ( int16_t)((( int16_t) calib26[19] << 8) | calib26[18]); dig_P8 = ( int16_t)((( int16_t) calib26[21] << 8) | calib26[20]); dig_P9 = ( int16_t)((( int16_t) calib26[23] << 8) | calib26[22]); //24 is missing - this is not typo - complain to Bosch dig_H1 = calib26[25]; readBytes(address, BME280_CALIB26, calib7, 7); dig_H2 = ( int16_t)((( int16_t) calib7[1] << 8) | calib7[0]); dig_H3 = calib7[2]; dig_H4 = ( int16_t)(((( int16_t) calib7[3] << 8) | (0x0F & calib7[4]) << 4) >> 4); dig_H5 = ( int16_t)(((( int16_t) calib7[5] << 8) | (0xF0 & calib7[4]) ) >> 4 ); dig_H6 = calib7[6]; } void BME280_Get_Data(int32_t * resultPTH) { writeByte(BME280_ADDRESS_1, BME280_CTRL_MEAS, Tosr << 5 | Posr << 2 | Mode); readBytes(BME280_ADDRESS_1, BME280_PRESS_MSB, rawData, 8); //Pressure result[0] = (uint32_t) (((uint32_t) rawData[0] << 16 | (uint32_t) rawData[1] << 8 | rawData[2]) >> 4); result[1] = (uint32_t) (((uint32_t) rawData[3] << 16 | (uint32_t) rawData[4] << 8 | rawData[5]) >> 4); result[2] = (uint16_t) (((uint16_t) rawData[6] << 8 | rawData[7]) ); //Need t_fine for all three compensations adc_T = result[1]; var1 = (((( adc_T >> 3) - ((int32_t)dig_T1 << 1))) * ((int32_t)dig_T2)) >> 11; var2 = (((((adc_T >> 4) - ((int32_t)dig_T1)) * ((adc_T >> 4) - ((int32_t)dig_T1))) >> 12) * ((int32_t)dig_T3)) >> 14; t_fine = var1 + var2; // Returns humidity in %RH as unsigned 32 bit integer in Q22.10 format (22integer and 10fractional bits). // Output value of “47445”represents 47445/1024= 46.333%RH uint32_t BME280_Compensate_H(int32_t adc_H, int32_t t_fine) { int32_t varH; varH = (t_fine - ((int32_t)76800)); varH = (((((adc_H << 14) - (((int32_t)dig_H4) << 20) - (((int32_t)dig_H5) * varH)) + ((int32_t)16384)) >> 15) * (((((((varH * ((int32_t)dig_H6)) >> 10) * (((varH * ((int32_t)dig_H3)) >> 11) + ((int32_t)32768))) >> 10) + ((int32_t)2097152)) * ((int32_t)dig_H2) + 8192) >> 14)); varH = (varH - (((((varH >> 15) * (varH >> 15)) >> 7) * ((int32_t)dig_H1)) >> 4)); varH = (varH < 0 ? 0 : varH); varH = (varH > 419430400 ? 419430400 : varH); return(uint32_t)(varH >> 12); } // Returns temperature in DegC, resolution is 0.01 DegC. Output value of // “5123” equals 51.23 DegC. int32_t BME280_Compensate_T(int32_t t_fine) { int32_t T; //var1 = ((((adc_T >> 3) - ((int32_t)dig_T1 << 1))) * ((int32_t)dig_T2)) >> 11; //var2 = (((((adc_T >> 4) - ((int32_t)dig_T1)) * ((adc_T >> 4) - ((int32_t)dig_T1))) >> 12) * ((int32_t)dig_T3)) >> 14; //t_fine = var1 + var2; T = (t_fine * 5 + 128) >> 8; return T; } // Returns pressure in Pa as unsigned 32 bit integer. Output value of “96386” equals 96386 Pa = 963.86 hPa uint32_t BME280_Compensate_P(int32_t adc_P, int32_t t_fine) { varP1 = (t_fine>>1) - (int32_t)64000; varP2 = (((varP1>>2) * (varP1>>2)) >> 11 ) * ((int32_t)dig_P6); varP2 = varP2 + ((varP1*((int32_t)dig_P5))<<1); varP2 = (varP2>>2)+(((int32_t)dig_P4)<<16); varP1 = (((dig_P3 * (((varP1>>2) * (varP1>>2)) >> 13 )) >> 3) + ((((int32_t)dig_P2) * varP1)>>1))>>18; varP1 = ((((32768+varP1))*((int32_t)dig_P1))>>15); if (varP1 == 0) { return 0; // avoid exception caused by division by zero } P = (((uint32_t)(((int32_t)1048576)-adc_P)-(varP2>>12)))*3125; if (P < 0x80000000) { P = (P << 1) / ((uint32_t)varP1); } else { P = (P / (uint32_t)varP1) * 2; } varP1 = (((int32_t)dig_P9) * ((int32_t)(((P>>3) * (P>>3))>>13)))>>12; varP2 = (((int32_t)(P>>2)) * ((int32_t)dig_P8))>>13; P = (uint32_t)((int32_t)P + ((varP1 + varP2 + dig_P7) >> 4)); return P; } resultPTH[0] = BME280_Compensate_P(result[0], t_fine); resultPTH[1] = BME280_Compensate_T( t_fine); resultPTH[2] = BME280_Compensate_H(result[2], t_fine); //resultPTH[0]/=100; resultPTH[1]/=100; resultPTH[2]/=1000; NRF_LOG_INFO("BME280:Pressure= %d , Tempreture= %d , Humidity= %d\n", resultPTH[0], resultPTH[1], resultPTH[2]); NRF_LOG_FLUSH(); } /**@brief Function for starting advertising. */ static void advertising_start(void) { uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); } /**@brief Application main function. */ int main(void) { bool erase_bonds; int32_t *sonuc; int32_t bme280value[3]; I2C_init(); nrf_delay_ms(50); BME280_Turn_On(); nrf_delay_ms(1000); uint8_t name= readByte(0x76, 0xD0); printf("BME280 initilized and its id= %d", name ); // Initialize. uart_init(); log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); // Start execution. printf("\r\nUART started.\r\n"); NRF_LOG_INFO("Debug logging for UART over RTT started."); application_timers_start(); advertising_start(); // Enter main loop. for (;;) { idle_state_handle(); // length1 = sprintf(str, "x:%x ", x); // ble_nus_data_send(&m_nus, str, &length1,m_conn_handle); } } /** * @} */
