Has anyone had success getting triggers on motion to work with the LIS2DH? I only have INT1 wired so I modified the drivers to work on INT1 as the spec document says it should. I've added the appropriate registers: to list2dh.h:
Have you also configured these pins in your overlay? Do you get an error message or does it not communicate with the device correctly? Have a look at my colleague Simon's answer here, note that it was for NCS tag 1.3.1.
Øyvind
INT1 is in the overlay:
lis2dh@18 {
compatible = "st,lis2dh";
reg = <0x18>;
irq-gpios = <&gpio0 12 0>; // GPIO_ACTIVE_HIGH>;
label = "LIS2DH";
It does trigger for SENSOR_TRIG_DATA_READY and that works fine. Trying to get it to trigger on movement.
Also, how do you add the send interrupt to the irq-gpios line?
NautDesigner said:It does trigger for SENSOR_TRIG_DATA_READY and that works fine. Trying to get it to trigger on movement.
Have you configured INT1 to movement recognition? As LIS2DH datasheet, page 39, states:
"AOI-6D = ‘01’ is movement recognition. An interrupt is generate when orientation move from unknown zone to known zone. The interrupt signal stay for a duration ODR."
From sensor.h, SENSOR_TRIG_DATA_READY states:
/** Trigger fires whenever new data is ready. */
What I am finding is that if I just setup the trigger, nothing happens. However, if I call fetch_and_display(sensor) before going into a wait loop, the trigger does fire. But then it never stops firing.
This is the output:
Sampling at 10 Hz
[00:00:00.024,780] [0m<inf> lis2dh: slope_config
[00:00:00.030,334] [0m<inf> lis2dh: int1_ths=0x49 range_g=16 ums2=89999999
[00:00:00.038,146] [0m<inf> lis2dh: slope_config
[00:00:00.043,182] [0m<inf> lis2dh: int1_dur=0x4
[00:00:00.048,614] [0m<inf> lis2dh: trigger_set
[00:00:00.053,558] [0m<inf> lis2dh: trigger_anym_set
[00:00:00.058,959] [0m<inf> lis2dh: setup_int1
[00:00:00.064,697] [0m<inf> lis2dh: start_trigger_int1
[00:00:00.070,281] [0m<inf> lis2dh: setup_int1
Waiting for triggers
#1 @ 78 ms: , x 3.22 , y 99.29 , z 64.36, g 108.6
MOTION - #2 @ 117 ms: , x 0.00 , y 8.27 , z 5.06, g 0.1
MOTION - #3 @ 215 ms: , x 0.00 , y 8.27 , z 5.06, g 0.1
MOTION - #4 @ 312 ms: , x -0.46 , y 7.35 , z 5.52, g 0.6
MOTION - #5 @ 409 ms: , x 0.00 , y 8.27 , z 5.06, g 0.1
MOTION - #6 @ 507 ms: , x -0.46 , y 7.81 , z 5.06, g 0.5
MOTION - #7 @ 604 ms: , x 0.46 , y 7.35 , z 5.52, g 0.6
MOTION - #8 @ 701 ms: , x 0.00 , y 7.35 , z 5.52, g 0.6
MOTION - #9 @ 799 ms: , x 0.00 , y 7.81 , z 4.60, g 0.7
MOTION - #10 @ 896 ms: , x -0.46 , y 8.27 , z 5.52, g 0.2
MOTION - #11 @ 993 ms: , x 0.00 , y 7.81 , z 5.52, g 0.2
I do have the movement specified:
I need to ask, but have you looked at the LIS2DH sample?
https://github.com/nrfconnect/sdk-zephyr/blob/v2.4.99-ncs-branch/drivers/sensor/lis2dh/lis2dh.c
If this does not help, then I would suggest asking the Zephyr forum. See Asking for help in the Zephyr docs
Øyvind
