nef9160 IMEI
Dear Sir,
Moving to zephyr new installation 1.4.99
The code of getting the IMEI number no longer works.
Modem firmware is mfw_nrf9160_1.2.3
reply_buf_len = at_exec_reply("AT+CGSN=1", 9, &reply_buf[0], 30);
Am I missing something ?.
Is there any example ?.
Please Advise
  • Hello Ephraim,
    I assume that you are using Zephyr 2.4.99.
    Function “at_exec_reply”, is that something you wrote yourself?
    Can you elaborate “no longer works”? Does the application still compile?
    Markus
  • Hi.
    This is the code
    void GetIMEI(void)
    int reply_buf_len;
    reply_buf_len = at_exec_reply("AT+CGSN=1", 9, &reply_buf[0], 30);//NTP_GET_CURR_UNIX_TIME_MAX_REPLY_LEN)
    memcpy(&imei_buf[0] , &reply_buf[8] ,15);
    // imei_buf[15] = NULL;
    imei_buf[15] = 0x2f;
    imei_buf[16] = 0x53;
    imei_buf[17] = 0x54;
    imei_buf[18] = NULL;
    It worked before .
    Now I get the error   [at_exec_reply:59] ERROR: AT commands socket error.
    Please Advise
  • Thanks for the code snippet, Ephraim!
    However, I can’t find any information about the function “at_exec_reply”. What does it do?
    Markus
  • Hi.
    in Main I issue the command   GetIMEI();
    Attached some code
    #include "at.h"
    #include <zephyr.h>
    #include <stdio.h>
    #include <string.h>
    //#include <zephyr.h>
    #include <nrf_socket.h>
    #include <net/socket.h>
    int at_exec(char * at_command, int at_command_strlen)
    	int  at_sock;
    	int  bytes_sent;
    	int  bytes_received;
    	char buf[2];
    	int ret = 0;
    	at_sock = socket(AF_LTE, 0, NPROTO_AT);
    	if (at_sock < 0)
    		printk("[%s:%d] ERROR: AT commands socket error.\n", __func__, __LINE__);
                    return -1;
    	bytes_sent = send(at_sock, at_command, at_command_strlen, 0);
    	if (bytes_sent < 0)
    		close(at_sock);
    		return -1;
    	do
    		bytes_received = recv(at_sock, buf, 2, 0);
    	} while (bytes_received == 0);
    	if (memcmp(buf, "OK", 2) != 0)
    		ret = -1;
    	close(at_sock);
    	return ret;
    	out_reply_str - an allocated string of length out_reply_str_len
    int at_exec_reply(char * at_command, int at_command_strlen, char * out_reply_str, int out_reply_str_len)
    	int  at_sock;
    	int  bytes_sent;
    	int  bytes_received;
    	int ret = 0;
    	if (at_sock < 0)
    		return -1;
    	if (bytes_sent < 0)
    		close(at_sock);
    		return -1;
    	do
    		bytes_received = recv(at_sock, out_reply_str, out_reply_str_len, 0);
    	ret = bytes_received;
    	close(at_sock);
    	return ret;
    The line at_sock = socket(AF_LTE, 0, NPROTO_AT);   in at.c return false.
    Is there another way to get the IMEI number within the code ?.
    Bye.
  • A good way to find out a little bit more about why the socket function returns false, is to print errno. Would you mind doing that?
    Otherwise, there are two alternatives to get the IMEI:
    1. AT command interface library using the function at_cmd_write instead of socket. https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.5.0/nrf/include/modem/at_cmd.html#
    2. Modem interface library using the function modem_info_short_get instead of socket, for instance. https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.5.0/nrf/include/modem/modem_info.html
    Cheers!
    Markus
